DD
Dr. David Kirkby
Sat, Jun 25, 2011 7:19 PM
I've got one of the cheap radio-controlled clocks? I was listing to radio 4 the
other day and herd the time signal. The radio controlled clock was about 3
seconds off. I was a bit surprised it was so far off. I'm just wondering how
accurate these things are.
A: Because it messes up the order in which people normally read text.
Q: Why is top-posting such a bad thing?
A: Top-posting.
Q: What is the most annoying thing in e-mail?
A: Top-posting.
BC
Brooke Clarke
Sat, Jun 25, 2011 7:34 PM
Hi David:
I've got a number of the WWVB clocks and can see a few of them at the
same time. It's common that they disagree by a few seconds.
Have Fun,
Brooke Clarke
http://www.PRC68.com
radio 4 the other day and herd the time signal. The radio controlled
clock was about 3 seconds off. I was a bit surprised it was so far
off. I'm just wondering how accurate these things are.
Hi David:
Have Fun,
Brooke Clarke
JF
J. Forster
Sat, Jun 25, 2011 7:38 PM
WWVB clocks look at the Time Code treansmitted by WWVB, not at the carrier
which is used for precision timing.
-John
Hi David:
Have Fun,
Brooke Clarke
-John
> Hi David:
> Have Fun,
> Brooke Clarke
> _______________________________________________
> time-nuts mailing list -- time-nuts@febo.com
> To unsubscribe, go to
> https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts
> and follow the instructions there.
ES
Eamon Skelton
Sat, Jun 25, 2011 7:45 PM
clock was about 3 seconds off. I was a bit surprised it was so far off.
Typically better than 1s. If there is interference or the radio is disabled,
it won't be able to receive the time signal. Switch mode PSUs and CRT TVs
or computer monitors can interfere with the 60kHz time signal.
The clocks with an LCD display usually have an indicator which shows
signal strength if the clock successfully updated in the last hour.
If you have reception problems, try moving the clock. The built-in
ferrite rod is very directional.
Were you receiving Radio 4 on LW or via a digital service. You could
easily see a 3s delay on digital radio or TV.
Linux 2.6.32
Linux 2.6.32
RS
Ron Smith
Sat, Jun 25, 2011 7:46 PM
I have two r-c clocks in the house and they both keep accurate time. One
clock is made by KLIK, the other by STAIGER - both from ARGOS.
The second-hand moves at the very moment I hear the pip, or as exactly as
the eye can tell. But I do not use Radio 4. Instead I check my times using
the pip sequence from RWM's time service broadcasts on either 4.996 or 9.996
MHz (good signal strengths in UK).
There is a danger with broadcasters these days that their studio source goes
through digital buffering and will be subject to delays. The time difference
between identical broadcasts via analogue circuits and digital circuits is
in the order of two seconds.
BBC time pip accuracy can be checked by listening to them at the same time
as listening to RWM.
Ron
G3SVW
----- Original Message -----
To: "Discussion of precise time and frequency measurement"
time-nuts@febo.com
Sent: Saturday, June 25, 2011 8:19 PM
Subject: [time-nuts] How accurate are cheap radio controlled clocks?
4 the other day and herd the time signal. The radio controlled clock was
about 3 seconds off. I was a bit surprised it was so far off. I'm just
A: Top-posting.
Ron
G3SVW
<time-nuts@febo.com>
> A: Top-posting.
DM
David Martindale
Sat, Jun 25, 2011 8:02 PM
the other day and herd the time signal. The radio controlled clock was about
3 seconds off. I was a bit surprised it was so far off. I'm just wondering
I have a Casio watch that syncs to WWVB when I leave it near a window
overnight. There's an indicator on the display that shows if it
synced sometime since midnight today (local time), as well as a mode
that will tell you the last time it did successfully sync. So far,
whenever it has synced today, the difference between it and a
NTP-synced computer time display has always been a fraction of a
second. Not zero, but well below a half second. (And when comparing
to a computer, remember that graphics cards and LCD monitors may add
multiple frames of delay).
If the watch doesn't sync for a few days, its timekeeping slowly
drifts but it still takes days to accumulate one second of error.
When I first purchased it, it was 25 seconds fast but the status
display said that the last successful sync was about 8 months ago, so
the internal crystal is likely good to about 3 seconds per month.
On the other hand, I have often heard over-the-air time beeps from
radio stations that are off by 5 seconds or more, usually late. I
don't know if they are generated by the studio's own clock that is
hand-set and not very accurate, or if the beep is accurately generated
at the mixing board but then fed through something that causes a
significant delay. (For example, live radio programs have a
multi-second delay between studio and transmitter so they can bleep
out "bad words" that a caller might say before they are broadcast).
So I wouldn't trust a radio time beep for anything without first
comparing it to another source.
Dave
On Sat, Jun 25, 2011 at 12:19 PM, Dr. David Kirkby
Dave
CP
Charles P. Steinmetz
Sat, Jun 25, 2011 8:51 PM
The ones I have do not monitor WWVB constantly -- they do it once a
day in the middle of the night (signal permitting), at which time
they synch up and update an oscillator correction factor based on how
far they were off since the previous update. Mine seem to stay
within 500 mS over 24 hours compared to 1PPS "ticks" from a
Thunderbolt (subject to the resolution limits of using my eyes and
ears as the two measurement inputs and the comparator between my
ears), which is as close as the Lady Heather display clock on my system.
Perhaps some newer WWVB clocks monitor more often than that, or even
constantly, but I have not seen any that synch more often than once
every 24 hours. On one of mine, you can turn the WWVB Rx off. The
instructions indicate that the expected battery life goes up 12-fold
if you do, which may explain why they don't recalibrate more often.
Best regards,
Charles
Best regards,
Charles
H
Had
Sat, Jun 25, 2011 8:52 PM
Hey Ed,
How are things in the land of mold, mildew and Jamesions?
Best 73,
Had
K7MLR
Linux 2.6.32
A fine is a tax for doing wrong. A tax is a fine for doing well.
Peter Cooper, of Fermi Lab, says, "Every experimentalist knows
that the apparatus, or at least your understanding of it, is
always at fault until demonstrated otherwise." He also says,
"Nature is really unmoved by what I, or anyone else, believes."
Hey Ed,
Best 73,
Had
K7MLR
>Linux 2.6.32
DD
Dr. David Kirkby
Sat, Jun 25, 2011 8:53 PM
disabled,
I don't think there's an SMPS nearby, but there was a 100 W amateur transceiver.
198 kHz longwave - using a Kenwood HF transceiver which has general coverage
receive.
A: Top-posting.
> disabled,
Thanks.
receive.
A: Top-posting.
CA
Chris Albertson
Sat, Jun 25, 2011 9:57 PM
Ideally they are supposed to have less then 1/2 second of drift per
day and this get corrected to the nearest second every night when they
can connect to WWVB. But some might have more than 1 sec per day
drift and they might not be able to receice the WWV signal. Try
placing the clock some place far from other electronics, like on the
back yard fence and letting it set there over night
Chris Albertson
Redondo Beach, California
Chris Albertson
