time-nuts@lists.febo.com
Re: [time-nuts] Glitches in data
I
iovane@inwind.it
Thu, Jul 9, 2009 8:38 AM
I had the same problem with a Racal 1992 and a NI GPIB to RS232.
Syncerely I'm now pleased that the problem was not only of
mine :-). In my case sometimes the glitches took two adjacent
readings (even if with different values), but I was sampling every 10 seconds, so my probality to get ones was much higher. I've not explained them, and was satisfied thinking of a loss
of single bits somewhere in the serial stream due to some
electrical disturbance. I modified my programs to ignore them.
Glitches were sporadic, some days none, some days even three.
(I take the opportunity to thank those who commented on
orbiting crystals and crystal orientation. I've got good info)
Antonio I8IOV
I've got an HP 5334B collecting data via a Prologix USB setup.  It's been
running for months.
Mostly, it's doing what I expect.  But then I got 2 glitches in the last two
days.
I had the same problem with a Racal 1992 and a NI GPIB to RS232. Syncerely I'm now pleased that the problem was not only of mine :-). In my case sometimes the glitches took two adjacent readings (even if with different values), but I was sampling every 10 seconds, so my probality to get ones was much higher. I've not explained them, and was satisfied thinking of a loss of single bits somewhere in the serial stream due to some electrical disturbance. I modified my programs to ignore them. Glitches were sporadic, some days none, some days even three. (I take the opportunity to thank those who commented on orbiting crystals and crystal orientation. I've got good info) Antonio I8IOV > I've got an HP 5334B collecting data via a Prologix USB setup. It's been > running for months. > > Mostly, it's doing what I expect. But then I got 2 glitches in the last two > days. >
