time-nuts@lists.febo.com
Precision AC source - build one ?
RL
Randy Leifer
Tue, Dec 25, 2007 7:21 PM
Hello everyone, Merry Holidays.
I am young at test gear knowledge, keep this in mind.
I'd like to calibrate some older test gear, and one
of the required items that I don't have, is an AC
voltage source -- w/adjustable volts and frequency.
Ebay items cost $200-$2000.
But I figure I can send an adjustable sine wave into a
"power amplifier", to get what I need......and an
analog AC voltmeter, to read/check the voltage on the
amp's output.
Does this sound correct?
Are there other ways ?
thanks,
=Randy=
  ____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile.  Try it now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
Hello everyone, Merry Holidays. I am young at test gear knowledge, keep this in mind. I'd like to calibrate some older test gear, and one of the required items that I don't have, is an AC voltage source -- w/adjustable volts and frequency. Ebay items cost $200-$2000. But I figure I can send an adjustable sine wave into a "power amplifier", to get what I need......and an analog AC voltmeter, to read/check the voltage on the amp's output. Does this sound correct? Are there other ways ? thanks, =Randy= ____________________________________________________________________________________ Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
W
WB6BNQ
Tue, Dec 25, 2007 8:08 PM
Hello Randy,
Can you give more information on the equipment you are trying to calibrate ?  For example the make and model
and what level of accuracy you expect to reach.  What is your intended use of this equipment, i.e., general
hobby use or more serious purposes ?
Bill....WB6BNQ
amp's output.
thanks,
=Randy=
Hello Randy, Can you give more information on the equipment you are trying to calibrate ? For example the make and model and what level of accuracy you expect to reach. What is your intended use of this equipment, i.e., general hobby use or more serious purposes ? Bill....WB6BNQ Randy Leifer wrote: > Hello everyone, Merry Holidays. > > I am young at test gear knowledge, keep this in mind. > I'd like to calibrate some older test gear, and one > of the required items that I don't have, is an AC > voltage source -- w/adjustable volts and frequency. > > Ebay items cost $200-$2000. > But I figure I can send an adjustable sine wave into a > "power amplifier", to get what I need......and an > analog AC voltmeter, to read/check the voltage on the > amp's output. > Does this sound correct? > Are there other ways ? > > thanks, > =Randy= > > > > ____________________________________________________________________________________ > Be a better friend, newshound, and > know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there.
