A general "problem-found" note on an engine coolant pump problem we finally
solved, for your edification - Perseverance has Cummins 855's on keel
coolers (sealed system, no risk of taking in foreign matter), and the
starboard engine began to randomly spike high temp alarms. We'd be underway
for an hour or two, then all of a sudden the stbd temp would very suddenly
spike. I discovered if I shut the engine down for even 5 minutes, I could
usually re-start and run normally.
Our mechanic was puzzled - we first replaced the thermostat, but the problem
reappeared. We then replaced the water pump, and after doing so he reported
that he could see no obvious reason - the impeller seemed firm on the
shaft - so he asked me if I wanted to reinstall the old pump or keep the new
one.
Knowing my own "Admiral" would prefer safe to sorry I decided to keep the
new pump, and the problem has not reappeared. It appears that a visual
inspection of an impeller on the shaft may not always tell the whole story.
On another topic, based on recommendations on this list, we purchased some
Senco Home Model One battery-powered CO detectors before our summer trip,
and I was very happy with this model. We mounted one in the unfinished
master stateroom on the steel bulkhead it shares with the lazarette, which
contains a night generator. We're somehow getting CO infiltration into the
stateroom, and I found the LCD readout to be very sensitive and gave me
quick response to both increases and decreases in the CO level. Now I've
got to figure out where this stuff is getting through. FYI - we ran on
inverters through the night, rather than this generator!
Finally, we purchased a Little Jumbo 4-step folding ladder
(http://www.ladders.com/jumbo1.html) based on recommendations on this list,
and I have to say that the recommendation was accurate - it's the most solid
and well-constructed folding ladder I've ever seen. It doesn't take much
space when folded but is as solid as our steel boat when erected.
I've sure appreciated the recommendations I've seen and the knowledge I've
gained while following this list. I wouldn't even have known about the CO
problem if I hadn't been motivated to get a detector in there by one of the
discussion strings here. To coin a really corny slogan, "it's nifty to be a
listee!".
Jeff Patton
Perseverance
Seattle
