jimlux@earthlink.net said:
If it gets cold enough (without power from solar cells, it won't generate
enough internal heat to keep warm), it will die. That's probably what
happened to Spirit on Mars. It got cold enough during the Martian winter,
and with not enough solar power, enough things drifted cold enough that we
couldn't get commands in.
What stops working when things get cold?
On Mars, the solar cells are pointed in the right direction. Why doesn't it
recover when the sun comes back in the Spring?
These are my opinions. I hate spam.
Lots of things. Mars gets really cold in the winter (-50C and lower)
There's an issue with plastic packages where it gets brittle. CTE
mismatches cause cracks, etc. Electrolytic capacitors freeze.
for Spirit, because of the issues with the wheel drive motors, it
couldn't get into the right position to face the sun (on a south facing
hillside, basically)
That 10-20 degrees makes a big difference because of the cosine (angle)
problem/
They run out of power for running the battery heaters, then the
battery freezes and fails. The batteries get to such a low
temperature that they are unable to be charged. The rover was never
designed so that it could move and operate under solar power. It is
really battery powered and uses the panel for charging.
Chris Albertson
Redondo Beach, California
There is a major problem with Radioisotope Thermoelectric Generators
Our stocks of Plutonium-238 are very low -- less than 40 pounds remain
available to NASA and this is all spoken for future missions.
We are restarting the manufacture and it is supposed to come online sometime
around 2017.
One gram of Plutonium-238 gives about 0.5 watts of deliverable electricity.
Half-life of 87.7 years. P-238 does not go KaBoom! -- you are thinking of
P-239.
http://en.wikipedia.org/wiki/Plutonium-238
http://www.space.com/20290-plutonium-spacecraft-nasa-fuel.html
http://www.wired.com/wiredscience/2013/09/plutonium-238-history-timeline/
-----Original Message-----
[mailto:time-nuts-bounces@febo.com] On Behalf Of Chris Albertson
Sent: Saturday, September 21, 2013 20:34
To: Discussion of precise time and frequency measurement
Subject: Re: [time-nuts] Space mission comes to an end
becuase of a "computer time tagging" problem
Chris Albertson
To unsubscribe, go to
