trawlers@lists.trawlering.com
TRAWLERS & TRAWLERING LIST
Re: TWL: Prop shaft
RP
Richter-Pooh@rocketmail.com
Mon, Sep 18, 2000 3:30 PM
<<After two seasons  of chasing down driveline vibration,
the yard finally dialed the shaft  and it was bent (.005").
"Dialing the shaft", or putting a dial indicator on the
shaft and rotating the shaft to check for true running, is
not difficult and should be done when aligning the engine
if there is the slightest hint of a problem (hit any logs
lately?).  Assuming reasonable access to the transmission
coupler area, (a big assumption on many boats) <30 mins
should do it (when doing the alignment at the same time).
Mark Richter, M.E., Mark's Mobile Marine
Do You Yahoo!?
Yahoo! Mail - Free email you can access from anywhere!
http://mail.yahoo.com/
<<After two seasons of chasing down driveline vibration, the yard finally dialed the shaft and it was bent (.005"). >> "Dialing the shaft", or putting a dial indicator on the shaft and rotating the shaft to check for true running, is not difficult and should be done when aligning the engine if there is the slightest hint of a problem (hit any logs lately?). Assuming reasonable access to the transmission coupler area, (a big assumption on many boats) <30 mins should do it (when doing the alignment at the same time). Mark Richter, M.E., Mark's Mobile Marine __________________________________________________ Do You Yahoo!? Yahoo! Mail - Free email you can access from anywhere! http://mail.yahoo.com/
Y
yourcaptain@earthlink.net
Mon, Sep 18, 2000 4:50 PM
Mark--------How can you tell a shaft is bent by measuring at the coupling
and not that the coupling is out. Please tell me the procedure used.
Captain Al Pilvinis
"M/V Driftwood"--Prairie 47
2630 N.E. 41st Street
Lighthouse Point, Fl 33064-8064
Voice 954-941-2556 Fax 954 788-2666
Email  yourcaptain@earthlink.net
Website http://home.earthlink.net/~yourcaptain
At 08:30 AM 9/18/00 -0700, you wrote: ><<After two seasons of chasing down driveline vibration, >the yard finally dialed the shaft and it was bent (.005"). >>> > >"Dialing the shaft", or putting a dial indicator on the >shaft and rotating the shaft to check for true running, is >not difficult and should be done when aligning the engine >if there is the slightest hint of a problem (hit any logs >lately?). Assuming reasonable access to the transmission >coupler area, (a big assumption on many boats) <30 mins >should do it (when doing the alignment at the same time). > >Mark Richter, M.E., Mark's Mobile Marine ========================================================= Mark--------How can you tell a shaft is bent by measuring at the coupling and not that the coupling is out. Please tell me the procedure used. . Captain Al Pilvinis "M/V Driftwood"--Prairie 47 2630 N.E. 41st Street Lighthouse Point, Fl 33064-8064 Voice 954-941-2556 Fax 954 788-2666 Email yourcaptain@earthlink.net Website http://home.earthlink.net/~yourcaptain
