DolphM@aol.com wrote:
Peggy,
We have an auto halon system in the engine room and it is serviced regularly.
It doesn't have an automatic engine shut down feature.
It's the engines & gensets themselves, not the extinguishing system,
that should have an automatic shut down, and an alarm that goes off on
the helm, if/when they do. The temperature is below combustion
temperature...so the halon system won't go off. That feature is meant
to save an engine as much as it is to prevent fires...for instance,
it'll shut down an engine if a water intake impeller fails. If your
engines/genset don't have that feature, it's been disabled at some
point...'cuz it's a required safety feature, and needs to be restored.
Btw...in deciding where to put fire extinguishers throughout a boat,
always think in terms of having one between a place where fire is likely
to start and an escape hatch from the boat...it should never be
necessary to go through a fire to get to an extinguisher or get out.
That usually means a few more fire extinguishers than CG regs call
for...which certainly doesn't hurt--nor does it hurt to have a fire
drill to make sure you--and the kids and pets--know how to get out
quickly from any location in the boat. And it's always a good idea to
put valuables--watches, wallets, keys etc--together in a bag or box that
can be grabbed easily if you're ever--God forbid!--ever awakened and
have to get out quick.
The only way I would
know if it went off is if I notice the pop or I notice that the little led has
gone out. The smoke detector I can hear and see easily. Should it go off I
would shut down the engine and or gen set immediately and investigate.
Once a fire has started in a closed compartment, it can be dangerous to
open that compartment, 'cuz opening it can provide the additional oxygen
that a smoldering fire needs to explode (almost literally) into full
blaze. Experts advise against ever opening a hatch that's more than just
warm or one that has smoke curling out from the edges. That's why
automatic extinguishing systems are so important in engine rooms...and
if halon is inappropriate, there are other chemicals that effectively
smother fires.
Peggie
Diesels
are quite happy burning halon and will quickly suck it out of the engine room
if left running. The fire can then re flash.
In addition I have detectors in every other place that I thought a fire might
start. I can hear the alarms quite well in the stateroom at anchor. If we are
running there is always someone on watch in the pilot house. I want to know
about any conflagration well before there is enough smoke in my stateroom to
cause a smoke detector in that area to go off. We have hand held extinguishers
through out the boat and we know how to use them, if given the chance.
Hope this answers your questions.
Dolph
M/V The Right Whale
