AM
Arpit Mehta
Wed, Nov 28, 2007 6:34 AM
Hello all,
I am new to this windows mobile/visual studio and this might be a very
silly error for some of you.
I was trying to build pjsip in visual studio 2005. Well the build
process goes on smoothly for sometime but then at the end it does not
link to one of the libraries
16>LINK : fatal error LNK1181: cannot open input file
'......\third_party\lib\libportaudio-i386-win32-vc8-debug.lib'
This library is not created/present in this path.
Steps I followed
--> When I load the pjsip-apps/build/wince-evc4/wince_demos.vcw
project , visual studio 2005 converts it into the .sln
--> Choose Debug, Windows Mobile 6 Professional as the sdk (should i
choose 'Windows Mobile 6 Professional' or 'Mixed Platforms' in vs2005
configuration manager?)
--> Did Build--> Build Solution
The problem I think is that, when I choose windows mobile 6
professional the targets which are supposed to be built for win32 are
obviously not built. These targets are
Project: libgsmcodec
Project: libspeex
Project: libresample
Project: libportaudio
Project: libmilenage
Project: libilbccodec
Hence the corresponding libraries are also not built which is giving
the link error.
The build log is pasted below. The errors (which I suspect to be
creating the problem) I got are shown with some empty space above and
below it. Please let me know if any more information is needed.
Thanks
Regards
Arpit Mehta
1>------ Build started: Project: pjlib_wince, Configuration: Debug
Windows Mobile 6 Professional SDK (ARMV4I) ------
2>------ Build started: Project: pjmedia_codec_wince, Configuration:
Debug Windows Mobile 6 Professional SDK (ARMV4I) ------
2>Compiling...
1>Compiling...
1>addr_resolv_sock.c
2>gsm.c
2>speex_codec.c
2>l16.c
2>ilbc.c
1>unicode_win32.c
2>Generating Code...
2>Creating library...
1>types.c
1>timer.c
1>string.c
2>Build log was saved at
"file://c:\pjproject-0.8.0\pjmedia\build\wince-evc4\Windows Mobile 6
Professional SDK (ARMV4I)\Debug\BuildLog.htm"
2>pjmedia_codec_wince - 0 error(s), 0 warning(s)
3>------ Build started: Project: pjsip_ua_wince, Configuration: Debug
3>Compiling...
3>sip_100rel.c
1>sock_select.c
1>sock_common.c
1>sock_bsd.c
1>rbtree.c
3>sip_xfer.c
1>rand.c
1>pool_policy_malloc.c
1>pool_caching.c
3>sip_replaces.c
1>pool_buf.c
1>pool.c
3>sip_reg.c
1>os_timestamp_win32.c
3>sip_inv.c
3>Generating Code...
1>os_timestamp_common.c
1>os_time_win32.c
3>Creating library...
3>Build log was saved at
"file://c:\pjproject-0.8.0\pjsip\build\wince-evc4\Windows Mobile 6
3>pjsip_ua_wince - 0 error(s), 0 warning(s)
1>os_error_win32.c
1>os_core_win32.c
1>log_writer_stdout.c
1>Generating Code...
4>------ Build started: Project: pjsip_simple_wince, Configuration:
4>Compiling...
4>errno.c
4>xpidf.c
1>Compiling...
1>log.c
1>lock.c
1>list.c
4>rpid.c
1>ip_helper_win32.c
4>publishc.c
4>presence_body.c
4>presence.c
1>ioqueue_select.c
4>pidf.c
4>iscomposing.c
1>hash.c
4>evsub_msg.c
1>guid_simple.c
4>evsub.c
1>guid.c
1>file_io_win32.c
4>Generating Code...
1>file_access_win32.c
4>Creating library...
4>Build log was saved at
4>pjsip_simple_wince - 0 error(s), 0 warning(s)
1>fifobuf.c
1>except.c
1>errno.c
5>------ Build started: Project: pjsip_core_wince, Configuration:
5>Compiling...
1>ctype.c
5>sip_auth_aka.c
1>config.c
1>array.c
5>sip_util_statefull.c
1>Creating library...
5>sip_util_proxy.c
5>sip_util.c
5>....\src\pjsip\sip_util.c(666) : warning C4102:
'TODO___SUPPORT_REQUEST_ADDR_RESOLUTION_FOR_TEL_URI' : unreferenced
label
5>sip_uri.c
1>Build log was saved at
"file://c:\pjproject-0.8.0\pjlib\build\wince-evc4\Windows Mobile 6
1>pjlib_wince - 0 error(s), 0 warning(s)
5>sip_ua_layer.c
5>sip_transport_udp.c
6>------ Build started: Project: pjlib_util_wince, Configuration:
6>Compiling...
6>base64.c
5>sip_transport_tcp.c
6>xml.c
6>stun_simple_client.c
6>stun_simple.c
6>string.c
6>srv_resolver.c
5>sip_transport_loop.c
6>sha1.c
6>scanner.c
5>sip_transport.c
6>resolver.c
6>md5.c
5>sip_transaction.c
6>hmac_sha1.c
6>hmac_md5.c
6>getopt.c
5>....\src\pjsip\sip_transaction.c(604) : warning C4102:
'TODO___FIX_RACE_CONDITION_HERE' : unreferenced label
5>....\src\pjsip\sip_transaction.c(732) : warning C4102:
5>....\src\pjsip\sip_transaction.c(781) : warning C4102:
5>sip_tel_uri.c
6>errno.c
6>dns_dump.c
5>sip_resolve.c
6>dns.c
5>....\src\pjsip\sip_resolve.c(286) : warning C4102:
'TODO___SUPPORT_DNS_NAPTR' : unreferenced label
5>sip_parser.c
6>crc32.c
6>Generating Code...
5>sip_msg.c
5>sip_errno.c
6>Creating library...
5>sip_endpoint.c
5>....\src\pjsip\sip_endpoint.c(886) : warning C4102:
'TODO___ENDPT_RESPOND_UNHANDLED_REQUEST' : unreferenced label
5>....\src\pjsip\sip_endpoint.c(856) : warning C4102:
'TODO___ENDPT_REPORT_WHEN_DROPPING_MESSAGE' : unreferenced label
5>sip_dialog.c
6>Build log was saved at
"file://c:\pjproject-0.8.0\pjlib-util\build\wince-evc4\Windows Mobile
6 Professional SDK (ARMV4I)\Debug\BuildLog.htm"
6>pjlib_util_wince - 0 error(s), 0 warning(s)
5>....\src\pjsip\sip_dialog.c(508) : warning C4102:
'TODO___DIALOG_APP_TIMER' : unreferenced label
5>sip_auth_server.c
5>sip_auth_parser.c
7>------ Build started: Project: pjmedia_wince, Configuration: Debug
7>Compiling...
7>alaw_ulaw.c
5>Generating Code...
7>wave.c
7>wav_writer.c
7>wav_playlist.c
7>wav_player.c
5>Compiling...
5>sip_auth_msg.c
7>transport_udp.c
5>sip_auth_client.c
5>....\src\pjsip\sip_auth_client.c(465) : warning C4102:
'TODO___FULL_CLONE_OF_AUTH_CLIENT_SESSION' : unreferenced label
5>Creating library...
7>transport_ice.c
5>Build log was saved at
5>pjsip_core_wince - 0 error(s), 9 warning(s)
7>....\src\pjmedia\transport_ice.c(307) : warning C4102:
'TODO___RELATED_ADDR_FOR_RELAYED_ADDR' : unreferenced label
7>....\src\pjmedia\transport_ice.c(748) : warning C4102:
'TODO___SWITCH_SOURCE_ADDRESS' : unreferenced label
7>tonegen.c
7>stream.c
8>------ Skipped Build: Project: libgsmcodec, Configuration: Debug Win32 ------
8>Project not selected to build for this solution configuration
9>------ Build started: Project: pjnath_wince, Configuration: Debug
9>Compiling...
9>errno.c
9>stun_transaction.c
7>splitcomb.c
9>stun_session.c
7>sound_port.c
9>stun_msg_dump.c
7>silencedet.c
9>stun_msg.c
7>session.c
9>stun_auth.c
7>sdp_neg.c
9>nat_detect.c
7>....\src\pjmedia\sdp_neg.c(532) : warning C4102:
'TODO___CHECK_SDP_NEGOTIATION_WHEN_ASYMETRIC_MEDIA_IS_ALLOWED' :
unreferenced label
7>sdp_cmp.c
7>sdp.c
7>rtp.c
9>ice_strans.c
7>rtcp.c
7>resample_speex.c
9>....\src\pjnath\ice_strans.c(490) : warning C4102:
'TODO___DISTINGUISH_BETWEEN_LOCAL_AND_RELAY' : unreferenced label
9>....\src\pjnath\ice_strans.c(1035) : warning C4102:
'TODO___TX_TO_RELAY' : unreferenced label
7>resample_resample.c
9>ice_session.c
7>Generating Code...
9>....\src\pjnath\ice_session.c(2165) : warning C4102:
'TODO___DETERMINE_IF_REQUEST_COMES_FROM_RELAYED_CANDIDATE' :
unreferenced label
9>....\src\pjnath\ice_session.c(2286) : warning C4102:
'TODO___SUPPORT_RX_BIND_REQUEST_AS_INDICATION' : unreferenced label
9>Generating Code...
9>Creating library...
7>Compiling...
7>resample_port.c
9>Build log was saved at
"file://c:\pjproject-0.8.0\pjnath\build\wince-evc4\Windows Mobile 6
9>pjnath_wince - 0 error(s), 4 warning(s)
7>port.c
//-------------------------------> error here
7>plc_common.c
10>------ Skipped Build: Project: libspeex, Configuration: Debug Win32 ------
10>Project not selected to build for this solution configuration
11>------ Skipped Build: Project: libresample, Configuration: Debug Win32 ------
11>Project not selected to build for this solution configuration
12>------ Skipped Build: Project: libportaudio, Configuration: Debug
Win32 ------
12>Project not selected to build for this solution configuration
13>------ Skipped Build: Project: libmilenage, Configuration: Debug Win32 ------
13>Project not selected to build for this solution configuration
14>------ Skipped Build: Project: libilbccodec, Configuration: Debug
Win32 ------
14>Project not selected to build for this solution configuration
7>pasound.c
7>null_port.c
7>mem_player.c
7>mem_capture.c
7>master_port.c
7>jbuf.c
7>g711.c
7>errno.c
7>endpoint.c
7>echo_suppress.c
7>echo_speex.c
7>echo_port.c
7>echo_common.c
7>conference.c
7>codec.c
7>clock_thread.c
7>bidirectional.c
7>Compiling...
7>alaw_ulaw_table.c
7>Creating library...
7>Build log was saved at
7>pjmedia_wince - 0 error(s), 3 warning(s)
15>------ Build started: Project: pjsua_lib_wince, Configuration:
15>Compiling...
15>pjsua_acc.c
15>....\src\pjsua-lib\pjsua_acc.c(417) : warning C4102:
'TODO___pjsua_acc_modify' : unreferenced label
15>....\src\pjsua-lib\pjsua_acc.c(1166) : warning C4102:
'TODO___dont_use_pjsua_pool' : unreferenced label
15>pjsua_pres.c
15>pjsua_media.c
15>....\src\pjsua-lib\pjsua_media.c(1957) : warning C4102:
'TODO___set_codec_param' : unreferenced label
15>pjsua_im.c
15>pjsua_core.c
15>....\src\pjsua-lib\pjsua_core.c(1667) : warning C4102:
'TODO___pjsua_transport_set_enable' : unreferenced label
15>pjsua_call.c
15>....\src\pjsua-lib\pjsua_call.c(1314) : warning C4102:
'TODO___create_active_inactive_sdp_based_on_unhold_arg' : unreferenced
label
15>....\src\pjsua-lib\pjsua_call.c(2270) : warning C4102:
'TODO___HANDLE_FORKED_DIALOG' : unreferenced label
15>Generating Code...
15>Creating library...
15>Build log was saved at
15>pjsua_lib_wince - 0 error(s), 6 warning(s)
16>------ Build started: Project: pjsua_wince, Configuration: Debug
16>Compiling...
16>StdAfx.cpp
16>Compiling...
16>pjsua_wince.cpp
16>Compiling resources...
16>Linking...
16>Build log was saved at
"file://c:\pjproject-0.8.0\pjsip-apps\src\pjsua_wince\Windows Mobile 6
16>pjsua_wince - 1 error(s), 0 warning(s)
========== Build: 9 succeeded, 1 failed, 0 up-to-date, 6 skipped ==========
Arpit Mehta
Graduate Student
Department of Computer Science
Columbia University
Tel: 1-646-387-5998
Hello all,
'..\..\..\third_party\lib\libportaudio-i386-win32-vc8-debug.lib'
Steps I followed
Project: libspeex
the link error.
Thanks
Regards
Arpit Mehta
2>Compiling...
1>Compiling...
2>gsm.c
2>speex_codec.c
2>l16.c
2>ilbc.c
1>unicode_win32.c
1>types.c
1>timer.c
1>string.c
3>Compiling...
3>sip_100rel.c
1>sock_select.c
1>sock_common.c
1>sock_bsd.c
1>rbtree.c
3>sip_xfer.c
1>rand.c
1>pool_caching.c
3>sip_replaces.c
1>pool_buf.c
1>pool.c
3>sip_reg.c
3>sip_inv.c
1>os_time_win32.c
1>os_error_win32.c
1>os_core_win32.c
4>Compiling...
4>errno.c
4>xpidf.c
1>Compiling...
1>log.c
1>lock.c
1>list.c
4>rpid.c
1>ip_helper_win32.c
4>publishc.c
4>presence_body.c
4>presence.c
1>ioqueue_select.c
4>pidf.c
4>iscomposing.c
1>hash.c
4>evsub_msg.c
1>guid_simple.c
4>evsub.c
1>guid.c
1>file_io_win32.c
1>fifobuf.c
1>except.c
1>errno.c
5>Compiling...
1>ctype.c
5>sip_auth_aka.c
1>config.c
1>array.c
5>sip_util_proxy.c
5>sip_util.c
5>..\..\src\pjsip\sip_util.c(666) : warning C4102:
label
5>sip_uri.c
5>sip_ua_layer.c
6>Compiling...
6>base64.c
6>xml.c
6>stun_simple.c
6>string.c
6>srv_resolver.c
6>sha1.c
6>scanner.c
5>sip_transport.c
6>resolver.c
6>md5.c
5>sip_transaction.c
6>hmac_sha1.c
6>hmac_md5.c
6>getopt.c
5>..\..\src\pjsip\sip_transaction.c(604) : warning C4102:
5>..\..\src\pjsip\sip_transaction.c(732) : warning C4102:
5>..\..\src\pjsip\sip_transaction.c(781) : warning C4102:
5>sip_tel_uri.c
6>errno.c
6>dns_dump.c
5>sip_resolve.c
6>dns.c
5>..\..\src\pjsip\sip_resolve.c(286) : warning C4102:
5>sip_parser.c
6>crc32.c
5>sip_msg.c
5>sip_errno.c
5>sip_endpoint.c
5>..\..\src\pjsip\sip_endpoint.c(886) : warning C4102:
5>..\..\src\pjsip\sip_endpoint.c(856) : warning C4102:
5>sip_dialog.c
5>..\..\src\pjsip\sip_dialog.c(508) : warning C4102:
5>sip_auth_server.c
5>sip_auth_parser.c
7>Compiling...
7>alaw_ulaw.c
7>wave.c
7>wav_writer.c
7>wav_playlist.c
7>wav_player.c
5>Compiling...
5>sip_auth_msg.c
7>transport_udp.c
5>sip_auth_client.c
5>..\..\src\pjsip\sip_auth_client.c(465) : warning C4102:
7>transport_ice.c
7>..\..\src\pjmedia\transport_ice.c(307) : warning C4102:
7>..\..\src\pjmedia\transport_ice.c(748) : warning C4102:
7>tonegen.c
7>stream.c
9>Compiling...
9>errno.c
7>splitcomb.c
9>stun_session.c
7>sound_port.c
9>stun_msg_dump.c
7>silencedet.c
9>stun_msg.c
7>session.c
9>stun_auth.c
7>sdp_neg.c
9>nat_detect.c
7>..\..\src\pjmedia\sdp_neg.c(532) : warning C4102:
unreferenced label
7>sdp_cmp.c
7>sdp.c
7>rtp.c
9>ice_strans.c
7>rtcp.c
7>resample_speex.c
9>..\..\src\pjnath\ice_strans.c(490) : warning C4102:
9>..\..\src\pjnath\ice_strans.c(1035) : warning C4102:
9>ice_session.c
9>..\..\src\pjnath\ice_session.c(2165) : warning C4102:
unreferenced label
9>..\..\src\pjnath\ice_session.c(2286) : warning C4102:
7>Compiling...
7>resample_port.c
7>port.c
7>plc_common.c
Win32 ------
Win32 ------
7>pasound.c
7>null_port.c
7>mem_player.c
7>mem_capture.c
7>master_port.c
7>jbuf.c
7>g711.c
7>errno.c
7>endpoint.c
7>echo_suppress.c
7>echo_speex.c
7>echo_port.c
7>echo_common.c
7>conference.c
7>codec.c
7>clock_thread.c
7>bidirectional.c
7>Compiling...
7>alaw_ulaw_table.c
15>Compiling...
15>pjsua_acc.c
15>..\..\src\pjsua-lib\pjsua_acc.c(417) : warning C4102:
15>..\..\src\pjsua-lib\pjsua_acc.c(1166) : warning C4102:
15>pjsua_pres.c
15>pjsua_media.c
15>..\..\src\pjsua-lib\pjsua_media.c(1957) : warning C4102:
15>pjsua_im.c
15>pjsua_core.c
15>..\..\src\pjsua-lib\pjsua_core.c(1667) : warning C4102:
15>pjsua_call.c
15>..\..\src\pjsua-lib\pjsua_call.c(1314) : warning C4102:
label
15>..\..\src\pjsua-lib\pjsua_call.c(2270) : warning C4102:
16>Compiling...
16>StdAfx.cpp
16>Compiling...
16>pjsua_wince.cpp
16>Linking...
Arpit Mehta
Graduate Student
Columbia University
Tel: 1-646-387-5998
BP
Benny Prijono
Wed, Nov 28, 2007 11:56 AM
I don't have VS 2005, so my only guess is this was caused by the
project dependencies not properly set in the workspace during the
conversion process. Please add pjsua_wince project dependencies to
Project: libspeex
(and probably more).
cheers,
-benny
Arpit Mehta wrote:
Hello all,
Steps I followed
Project: libspeex
the link error.
Thanks
Regards
Arpit Mehta
2>Compiling...
1>Compiling...
2>gsm.c
2>speex_codec.c
2>l16.c
2>ilbc.c
1>unicode_win32.c
1>types.c
1>timer.c
1>string.c
3>Compiling...
3>sip_100rel.c
1>sock_select.c
1>sock_common.c
1>sock_bsd.c
1>rbtree.c
3>sip_xfer.c
1>rand.c
1>pool_caching.c
3>sip_replaces.c
1>pool_buf.c
1>pool.c
3>sip_reg.c
3>sip_inv.c
1>os_time_win32.c
1>os_error_win32.c
1>os_core_win32.c
4>Compiling...
4>errno.c
4>xpidf.c
1>Compiling...
1>log.c
1>lock.c
1>list.c
4>rpid.c
1>ip_helper_win32.c
4>publishc.c
4>presence_body.c
4>presence.c
1>ioqueue_select.c
4>pidf.c
4>iscomposing.c
1>hash.c
4>evsub_msg.c
1>guid_simple.c
4>evsub.c
1>guid.c
1>file_io_win32.c
1>fifobuf.c
1>except.c
1>errno.c
5>Compiling...
1>ctype.c
5>sip_auth_aka.c
1>config.c
1>array.c
5>sip_util_proxy.c
5>sip_util.c
label
5>sip_uri.c
5>sip_ua_layer.c
6>Compiling...
6>base64.c
6>xml.c
6>stun_simple.c
6>string.c
6>srv_resolver.c
6>sha1.c
6>scanner.c
5>sip_transport.c
6>resolver.c
6>md5.c
5>sip_transaction.c
6>hmac_sha1.c
6>hmac_md5.c
6>getopt.c
5>sip_tel_uri.c
6>errno.c
6>dns_dump.c
5>sip_resolve.c
6>dns.c
5>sip_parser.c
6>crc32.c
5>sip_msg.c
5>sip_errno.c
5>sip_endpoint.c
5>sip_dialog.c
5>sip_auth_server.c
5>sip_auth_parser.c
7>Compiling...
7>alaw_ulaw.c
7>wave.c
7>wav_writer.c
7>wav_playlist.c
7>wav_player.c
5>Compiling...
5>sip_auth_msg.c
7>transport_udp.c
5>sip_auth_client.c
7>transport_ice.c
7>tonegen.c
7>stream.c
9>Compiling...
9>errno.c
7>splitcomb.c
9>stun_session.c
7>sound_port.c
9>stun_msg_dump.c
7>silencedet.c
9>stun_msg.c
7>session.c
9>stun_auth.c
7>sdp_neg.c
9>nat_detect.c
unreferenced label
7>sdp_cmp.c
7>sdp.c
7>rtp.c
9>ice_strans.c
7>rtcp.c
7>resample_speex.c
9>ice_session.c
unreferenced label
7>Compiling...
7>resample_port.c
7>port.c
7>plc_common.c
Win32 ------
Win32 ------
7>pasound.c
7>null_port.c
7>mem_player.c
7>mem_capture.c
7>master_port.c
7>jbuf.c
7>g711.c
7>errno.c
7>endpoint.c
7>echo_suppress.c
7>echo_speex.c
7>echo_port.c
7>echo_common.c
7>conference.c
7>codec.c
7>clock_thread.c
7>bidirectional.c
7>Compiling...
7>alaw_ulaw_table.c
15>Compiling...
15>pjsua_acc.c
15>pjsua_pres.c
15>pjsua_media.c
15>pjsua_im.c
15>pjsua_core.c
15>pjsua_call.c
label
16>Compiling...
16>StdAfx.cpp
16>Compiling...
16>pjsua_wince.cpp
16>Linking...
> Project: libspeex
cheers,
-benny
Arpit Mehta wrote:
> Hello all,
> Steps I followed
> Project: libspeex
> the link error.
> Thanks
> Regards
> Arpit Mehta
> 2>Compiling...
> 1>Compiling...
> 2>gsm.c
> 2>speex_codec.c
> 2>l16.c
> 2>ilbc.c
> 1>unicode_win32.c
> 1>types.c
> 1>timer.c
> 1>string.c
> 3>Compiling...
> 3>sip_100rel.c
> 1>sock_select.c
> 1>sock_common.c
> 1>sock_bsd.c
> 1>rbtree.c
> 3>sip_xfer.c
> 1>rand.c
> 1>pool_caching.c
> 3>sip_replaces.c
> 1>pool_buf.c
> 1>pool.c
> 3>sip_reg.c
> 3>sip_inv.c
> 1>os_time_win32.c
> 1>os_error_win32.c
> 1>os_core_win32.c
> 4>Compiling...
> 4>errno.c
> 4>xpidf.c
> 1>Compiling...
> 1>log.c
> 1>lock.c
> 1>list.c
> 4>rpid.c
> 1>ip_helper_win32.c
> 4>publishc.c
> 4>presence_body.c
> 4>presence.c
> 1>ioqueue_select.c
> 4>pidf.c
> 4>iscomposing.c
> 1>hash.c
> 4>evsub_msg.c
> 1>guid_simple.c
> 4>evsub.c
> 1>guid.c
> 1>file_io_win32.c
> 1>fifobuf.c
> 1>except.c
> 1>errno.c
> 5>Compiling...
> 1>ctype.c
> 5>sip_auth_aka.c
> 1>config.c
> 1>array.c
> 5>sip_util_proxy.c
> 5>sip_util.c
> label
> 5>sip_uri.c
> 5>sip_ua_layer.c
> 6>Compiling...
> 6>base64.c
> 6>xml.c
> 6>stun_simple.c
> 6>string.c
> 6>srv_resolver.c
> 6>sha1.c
> 6>scanner.c
> 5>sip_transport.c
> 6>resolver.c
> 6>md5.c
> 5>sip_transaction.c
> 6>hmac_sha1.c
> 6>hmac_md5.c
> 6>getopt.c
> 5>sip_tel_uri.c
> 6>errno.c
> 6>dns_dump.c
> 5>sip_resolve.c
> 6>dns.c
> 5>sip_parser.c
> 6>crc32.c
> 5>sip_msg.c
> 5>sip_errno.c
> 5>sip_endpoint.c
> 5>sip_dialog.c
> 5>sip_auth_server.c
> 5>sip_auth_parser.c
> 7>Compiling...
> 7>alaw_ulaw.c
> 7>wave.c
> 7>wav_writer.c
> 7>wav_playlist.c
> 7>wav_player.c
> 5>Compiling...
> 5>sip_auth_msg.c
> 7>transport_udp.c
> 5>sip_auth_client.c
> 7>transport_ice.c
> 7>tonegen.c
> 7>stream.c
> 9>Compiling...
> 9>errno.c
> 7>splitcomb.c
> 9>stun_session.c
> 7>sound_port.c
> 9>stun_msg_dump.c
> 7>silencedet.c
> 9>stun_msg.c
> 7>session.c
> 9>stun_auth.c
> 7>sdp_neg.c
> 9>nat_detect.c
> unreferenced label
> 7>sdp_cmp.c
> 7>sdp.c
> 7>rtp.c
> 9>ice_strans.c
> 7>rtcp.c
> 7>resample_speex.c
> 9>ice_session.c
> unreferenced label
> 7>Compiling...
> 7>resample_port.c
> 7>port.c
> 7>plc_common.c
> Win32 ------
> Win32 ------
> 7>pasound.c
> 7>null_port.c
> 7>mem_player.c
> 7>mem_capture.c
> 7>master_port.c
> 7>jbuf.c
> 7>g711.c
> 7>errno.c
> 7>endpoint.c
> 7>echo_suppress.c
> 7>echo_speex.c
> 7>echo_port.c
> 7>echo_common.c
> 7>conference.c
> 7>codec.c
> 7>clock_thread.c
> 7>bidirectional.c
> 7>Compiling...
> 7>alaw_ulaw_table.c
> 15>Compiling...
> 15>pjsua_acc.c
> 15>pjsua_pres.c
> 15>pjsua_media.c
> 15>pjsua_im.c
> 15>pjsua_core.c
> 15>pjsua_call.c
> label
> 16>Compiling...
> 16>StdAfx.cpp
> 16>Compiling...
> 16>pjsua_wince.cpp
> 16>Linking...
Benny Prijono
http://www.pjsip.org
AM
Arpit Mehta
Wed, Nov 28, 2007 7:36 PM
hi,
Thanks Benny that worked. So now it is compiling fine. But I am
getting all these link errors, this error is similar to one posted
here
http://www.pjsip.org/pipermail/pjsip/2007-May/003240.html
but unfortunately there is no solution given there.
1>------ Rebuild All started: Project: pjlib_wince, Configuration:
Release Windows Mobile 6 Professional SDK (ARMV4I) ------
16>Deleting intermediate and output files for project 'pjsua_wince',
configuration 'Release|Windows Mobile 6 Professional SDK (ARMV4I)'
16>Compiling...
16>StdAfx.cpp
16>Compiling...
16>pjsua_wince.cpp
16>Linking...
16>pjmedia_wince.lib(pasound.obj) : error LNK2019: unresolved external
symbol Pa_GetDeviceCount referenced in function
pjmedia_snd_get_dev_count
symbol Pa_GetDeviceInfo referenced in function
pjmedia_snd_get_dev_info
symbol Pa_GetHostApiInfo referenced in function
pa_get_default_input_dev
symbol Pa_GetHostApiCount referenced in function
symbol Pa_GetStreamInfo referenced in function pjmedia_snd_open_rec
symbol Pa_OpenStream referenced in function pjmedia_snd_open_rec
symbol Pa_CloseStream referenced in function pjmedia_snd_open
symbol Pa_StopStream referenced in function pjmedia_snd_stream_start
symbol Pa_StartStream referenced in function pjmedia_snd_stream_start
symbol Pa_Terminate referenced in function pjmedia_snd_deinit
symbol Pa_Initialize referenced in function pjmedia_snd_init
symbol PaUtil_SetDebugPrintFunction referenced in function
pjmedia_snd_init
16>pjmedia_wince.lib(errno.obj) : error LNK2019: unresolved external
symbol Pa_GetErrorText referenced in function pjmedia_strerror
16>pjmedia_wince.lib(resample_resample.obj) : error LNK2019:
unresolved external symbol res_GetXOFF referenced in function
pjmedia_resample_create
unresolved external symbol res_SrcLinear referenced in function
pjmedia_resample_run
unresolved external symbol res_Resample referenced in function
16>pjmedia_codec_wince.lib(gsm.obj) : error LNK2019: unresolved
external symbol gsm_create referenced in function gsm_codec_open
external symbol gsm_destroy referenced in function gsm_codec_close
external symbol gsm_encode referenced in function gsm_codec_encode
external symbol gsm_decode referenced in function gsm_codec_decode
16>pjmedia_codec_wince.lib(ilbc.obj) : error LNK2019: unresolved
external symbol initDecode referenced in function ilbc_codec_open
external symbol initEncode referenced in function ilbc_codec_open
external symbol iLBC_encode referenced in function ilbc_codec_encode
external symbol iLBC_decode referenced in function ilbc_codec_decode
16>pjmedia_codec_wince.lib(speex_codec.obj) : error LNK2019:
unresolved external symbol speex_encoder_destroy referenced in
function get_speex_info
unresolved external symbol speex_encoder_ctl referenced in function
get_speex_info
unresolved external symbol speex_encoder_init referenced in function
get_speex_info
unresolved external symbol speex_uwb_mode referenced in function
pjmedia_codec_speex_init
unresolved external symbol speex_wb_mode referenced in function
unresolved external symbol speex_nb_mode referenced in function
unresolved external symbol speex_decoder_destroy referenced in
function spx_codec_close
unresolved external symbol speex_bits_destroy referenced in function
spx_codec_close
unresolved external symbol speex_decoder_ctl referenced in function
spx_codec_modify
unresolved external symbol speex_bits_write referenced in function
spx_codec_encode
unresolved external symbol speex_bits_nbytes referenced in function
spx_codec_encode
unresolved external symbol speex_encode_int referenced in function
spx_codec_encode
unresolved external symbol speex_bits_reset referenced in function
spx_codec_encode
unresolved external symbol speex_decode_int referenced in function
spx_codec_decode
unresolved external symbol speex_bits_read_from referenced in function
spx_codec_decode
unresolved external symbol speex_decoder_init referenced in function
spx_codec_open
unresolved external symbol speex_bits_init referenced in function
spx_codec_open
16>Windows Mobile 6 Professional SDK (ARMV4I)\Release/pjsua_wince.exe
: fatal error LNK1120: 41 unresolved externals
Professional SDK (ARMV4I)\Release\BuildLog.htm"
16>pjsua_wince - 42 error(s), 0 warning(s)
========== Rebuild All: 9 succeeded, 1 failed, 6 skipped ==========
Thanks
Regards
Arpit Mehta
Project: libspeex
cheers,
-benny
Arpit Mehta wrote:
Hello all,
Steps I followed
Project: libspeex
the link error.
Thanks
Regards
Arpit Mehta
2>Compiling...
1>Compiling...
2>gsm.c
2>speex_codec.c
2>l16.c
2>ilbc.c
1>unicode_win32.c
1>types.c
1>timer.c
1>string.c
3>Compiling...
3>sip_100rel.c
1>sock_select.c
1>sock_common.c
1>sock_bsd.c
1>rbtree.c
3>sip_xfer.c
1>rand.c
1>pool_caching.c
3>sip_replaces.c
1>pool_buf.c
1>pool.c
3>sip_reg.c
3>sip_inv.c
1>os_time_win32.c
1>os_error_win32.c
1>os_core_win32.c
4>Compiling...
4>errno.c
4>xpidf.c
1>Compiling...
1>log.c
1>lock.c
1>list.c
4>rpid.c
1>ip_helper_win32.c
4>publishc.c
4>presence_body.c
4>presence.c
1>ioqueue_select.c
4>pidf.c
4>iscomposing.c
1>hash.c
4>evsub_msg.c
1>guid_simple.c
4>evsub.c
1>guid.c
1>file_io_win32.c
1>fifobuf.c
1>except.c
1>errno.c
5>Compiling...
1>ctype.c
5>sip_auth_aka.c
1>config.c
1>array.c
5>sip_util_proxy.c
5>sip_util.c
label
5>sip_uri.c
5>sip_ua_layer.c
6>Compiling...
6>base64.c
6>xml.c
6>stun_simple.c
6>string.c
6>srv_resolver.c
6>sha1.c
6>scanner.c
5>sip_transport.c
6>resolver.c
6>md5.c
5>sip_transaction.c
6>hmac_sha1.c
6>hmac_md5.c
6>getopt.c
5>sip_tel_uri.c
6>errno.c
6>dns_dump.c
5>sip_resolve.c
6>dns.c
5>sip_parser.c
6>crc32.c
5>sip_msg.c
5>sip_errno.c
5>sip_endpoint.c
5>sip_dialog.c
5>sip_auth_server.c
5>sip_auth_parser.c
7>Compiling...
7>alaw_ulaw.c
7>wave.c
7>wav_writer.c
7>wav_playlist.c
7>wav_player.c
5>Compiling...
5>sip_auth_msg.c
7>transport_udp.c
5>sip_auth_client.c
7>transport_ice.c
7>tonegen.c
7>stream.c
9>Compiling...
9>errno.c
7>splitcomb.c
9>stun_session.c
7>sound_port.c
9>stun_msg_dump.c
7>silencedet.c
9>stun_msg.c
7>session.c
9>stun_auth.c
7>sdp_neg.c
9>nat_detect.c
unreferenced label
7>sdp_cmp.c
7>sdp.c
7>rtp.c
9>ice_strans.c
7>rtcp.c
7>resample_speex.c
9>ice_session.c
unreferenced label
7>Compiling...
7>resample_port.c
7>port.c
7>plc_common.c
Win32 ------
Win32 ------
7>pasound.c
7>null_port.c
7>mem_player.c
7>mem_capture.c
7>master_port.c
7>jbuf.c
7>g711.c
7>errno.c
7>endpoint.c
7>echo_suppress.c
7>echo_speex.c
7>echo_port.c
7>echo_common.c
7>conference.c
7>codec.c
7>clock_thread.c
7>bidirectional.c
7>Compiling...
7>alaw_ulaw_table.c
15>Compiling...
15>pjsua_acc.c
15>pjsua_pres.c
15>pjsua_media.c
15>pjsua_im.c
15>pjsua_core.c
15>pjsua_call.c
label
16>Compiling...
16>StdAfx.cpp
16>Compiling...
16>pjsua_wince.cpp
16>Linking...
Arpit Mehta
Graduate Student
Columbia University
Tel: 1-646-387-5998
hi,
here
16>Compiling...
16>StdAfx.cpp
16>Compiling...
16>pjsua_wince.cpp
16>Linking...
pjmedia_snd_init
get_speex_info
get_speex_info
spx_codec_close
spx_codec_modify
spx_codec_encode
spx_codec_encode
spx_codec_encode
spx_codec_encode
spx_codec_decode
spx_codec_decode
spx_codec_open
spx_codec_open
Thanks
Regards
Arpit Mehta
> > Project: libspeex
> cheers,
> -benny
> Arpit Mehta wrote:
> > Hello all,
> > Steps I followed
> > Project: libspeex
> > the link error.
> > Thanks
> > Regards
> > Arpit Mehta
> > 2>Compiling...
> > 1>Compiling...
> > 2>gsm.c
> > 2>speex_codec.c
> > 2>l16.c
> > 2>ilbc.c
> > 1>unicode_win32.c
> > 1>types.c
> > 1>timer.c
> > 1>string.c
> > 3>Compiling...
> > 3>sip_100rel.c
> > 1>sock_select.c
> > 1>sock_common.c
> > 1>sock_bsd.c
> > 1>rbtree.c
> > 3>sip_xfer.c
> > 1>rand.c
> > 1>pool_caching.c
> > 3>sip_replaces.c
> > 1>pool_buf.c
> > 1>pool.c
> > 3>sip_reg.c
> > 3>sip_inv.c
> > 1>os_time_win32.c
> > 1>os_error_win32.c
> > 1>os_core_win32.c
> > 4>Compiling...
> > 4>errno.c
> > 4>xpidf.c
> > 1>Compiling...
> > 1>log.c
> > 1>lock.c
> > 1>list.c
> > 4>rpid.c
> > 1>ip_helper_win32.c
> > 4>publishc.c
> > 4>presence_body.c
> > 4>presence.c
> > 1>ioqueue_select.c
> > 4>pidf.c
> > 4>iscomposing.c
> > 1>hash.c
> > 4>evsub_msg.c
> > 1>guid_simple.c
> > 4>evsub.c
> > 1>guid.c
> > 1>file_io_win32.c
> > 1>fifobuf.c
> > 1>except.c
> > 1>errno.c
> > 5>Compiling...
> > 1>ctype.c
> > 5>sip_auth_aka.c
> > 1>config.c
> > 1>array.c
> > 5>sip_util_proxy.c
> > 5>sip_util.c
> > label
> > 5>sip_uri.c
> > 5>sip_ua_layer.c
> > 6>Compiling...
> > 6>base64.c
> > 6>xml.c
> > 6>stun_simple.c
> > 6>string.c
> > 6>srv_resolver.c
> > 6>sha1.c
> > 6>scanner.c
> > 5>sip_transport.c
> > 6>resolver.c
> > 6>md5.c
> > 5>sip_transaction.c
> > 6>hmac_sha1.c
> > 6>hmac_md5.c
> > 6>getopt.c
> > 5>sip_tel_uri.c
> > 6>errno.c
> > 6>dns_dump.c
> > 5>sip_resolve.c
> > 6>dns.c
> > 5>sip_parser.c
> > 6>crc32.c
> > 5>sip_msg.c
> > 5>sip_errno.c
> > 5>sip_endpoint.c
> > 5>sip_dialog.c
> > 5>sip_auth_server.c
> > 5>sip_auth_parser.c
> > 7>Compiling...
> > 7>alaw_ulaw.c
> > 7>wave.c
> > 7>wav_writer.c
> > 7>wav_playlist.c
> > 7>wav_player.c
> > 5>Compiling...
> > 5>sip_auth_msg.c
> > 7>transport_udp.c
> > 5>sip_auth_client.c
> > 7>transport_ice.c
> > 7>tonegen.c
> > 7>stream.c
> > 9>Compiling...
> > 9>errno.c
> > 7>splitcomb.c
> > 9>stun_session.c
> > 7>sound_port.c
> > 9>stun_msg_dump.c
> > 7>silencedet.c
> > 9>stun_msg.c
> > 7>session.c
> > 9>stun_auth.c
> > 7>sdp_neg.c
> > 9>nat_detect.c
> > unreferenced label
> > 7>sdp_cmp.c
> > 7>sdp.c
> > 7>rtp.c
> > 9>ice_strans.c
> > 7>rtcp.c
> > 7>resample_speex.c
> > 9>ice_session.c
> > unreferenced label
> > 7>Compiling...
> > 7>resample_port.c
> > 7>port.c
> > 7>plc_common.c
> > Win32 ------
> > Win32 ------
> > 7>pasound.c
> > 7>null_port.c
> > 7>mem_player.c
> > 7>mem_capture.c
> > 7>master_port.c
> > 7>jbuf.c
> > 7>g711.c
> > 7>errno.c
> > 7>endpoint.c
> > 7>echo_suppress.c
> > 7>echo_speex.c
> > 7>echo_port.c
> > 7>echo_common.c
> > 7>conference.c
> > 7>codec.c
> > 7>clock_thread.c
> > 7>bidirectional.c
> > 7>Compiling...
> > 7>alaw_ulaw_table.c
> > 15>Compiling...
> > 15>pjsua_acc.c
> > 15>pjsua_pres.c
> > 15>pjsua_media.c
> > 15>pjsua_im.c
> > 15>pjsua_core.c
> > 15>pjsua_call.c
> > label
> > 16>Compiling...
> > 16>StdAfx.cpp
> > 16>Compiling...
> > 16>pjsua_wince.cpp
> > 16>Linking...
> Benny Prijono
> _______________________________________________
> Visit our blog: http://blog.pjsip.org
> pjsip mailing list
> pjsip@lists.pjsip.org
> http://lists.pjsip.org/mailman/listinfo/pjsip_lists.pjsip.org
Arpit Mehta
Graduate Student
Columbia University
Tel: 1-646-387-5998
AM
Arpit Mehta
Wed, Nov 28, 2007 10:49 PM
Hi,
Also since this looks like a missing library error. Just wanted to add
that these are the libraries I have included in
pjsua_wince -->properties-->linker--> input -->additional dependencies
Do I also need to add more libraries for pjsua_wince project?
Also wanted to add that the third party libraries (as it can be seen
below) were built in win32 platform and not in WM6 platform.
commctrl.lib
coredll.lib
winsock.lib
ws2.lib
iphlpapi.lib
libspeex-i386-win32-vc8-debug.lib
libresample-i386-win32-vc8-debug.lib
libmilenage-i386-win32-vc8-debug.lib
libilbccodec-i386-win32-vc8-debug.lib
libgsmcodec-i386-win32-vc8-debug.lib
Thanks
Regards
Arpit Mehta
Graduate Student
Columbia University
On Nov 28, 2007 2:36 PM, Arpit Mehta am2866@columbia.edu wrote:
hi,
here
16>Compiling...
16>StdAfx.cpp
16>Compiling...
16>pjsua_wince.cpp
16>Linking...
pjmedia_snd_init
get_speex_info
get_speex_info
spx_codec_close
spx_codec_modify
spx_codec_encode
spx_codec_encode
spx_codec_encode
spx_codec_encode
spx_codec_decode
spx_codec_decode
spx_codec_open
spx_codec_open
Thanks
Regards
Arpit Mehta
Project: libspeex
cheers,
-benny
Arpit Mehta wrote:
Hello all,
Steps I followed
Project: libspeex
the link error.
Thanks
Regards
Arpit Mehta
2>Compiling...
1>Compiling...
2>gsm.c
2>speex_codec.c
2>l16.c
2>ilbc.c
1>unicode_win32.c
1>types.c
1>timer.c
1>string.c
3>Compiling...
3>sip_100rel.c
1>sock_select.c
1>sock_common.c
1>sock_bsd.c
1>rbtree.c
3>sip_xfer.c
1>rand.c
1>pool_caching.c
3>sip_replaces.c
1>pool_buf.c
1>pool.c
3>sip_reg.c
3>sip_inv.c
1>os_time_win32.c
1>os_error_win32.c
1>os_core_win32.c
4>Compiling...
4>errno.c
4>xpidf.c
1>Compiling...
1>log.c
1>lock.c
1>list.c
4>rpid.c
1>ip_helper_win32.c
4>publishc.c
4>presence_body.c
4>presence.c
1>ioqueue_select.c
4>pidf.c
4>iscomposing.c
1>hash.c
4>evsub_msg.c
1>guid_simple.c
4>evsub.c
1>guid.c
1>file_io_win32.c
1>fifobuf.c
1>except.c
1>errno.c
5>Compiling...
1>ctype.c
5>sip_auth_aka.c
1>config.c
1>array.c
5>sip_util_proxy.c
5>sip_util.c
label
5>sip_uri.c
5>sip_ua_layer.c
6>Compiling...
6>base64.c
6>xml.c
6>stun_simple.c
6>string.c
6>srv_resolver.c
6>sha1.c
6>scanner.c
5>sip_transport.c
6>resolver.c
6>md5.c
5>sip_transaction.c
6>hmac_sha1.c
6>hmac_md5.c
6>getopt.c
5>sip_tel_uri.c
6>errno.c
6>dns_dump.c
5>sip_resolve.c
6>dns.c
5>sip_parser.c
6>crc32.c
5>sip_msg.c
5>sip_errno.c
5>sip_endpoint.c
5>sip_dialog.c
5>sip_auth_server.c
5>sip_auth_parser.c
7>Compiling...
7>alaw_ulaw.c
7>wave.c
7>wav_writer.c
7>wav_playlist.c
7>wav_player.c
5>Compiling...
5>sip_auth_msg.c
7>transport_udp.c
5>sip_auth_client.c
7>transport_ice.c
7>tonegen.c
7>stream.c
9>Compiling...
9>errno.c
7>splitcomb.c
9>stun_session.c
7>sound_port.c
9>stun_msg_dump.c
7>silencedet.c
9>stun_msg.c
7>session.c
9>stun_auth.c
7>sdp_neg.c
9>nat_detect.c
unreferenced label
7>sdp_cmp.c
7>sdp.c
7>rtp.c
9>ice_strans.c
7>rtcp.c
7>resample_speex.c
9>ice_session.c
unreferenced label
7>Compiling...
7>resample_port.c
7>port.c
7>plc_common.c
Win32 ------
Win32 ------
7>pasound.c
7>null_port.c
7>mem_player.c
7>mem_capture.c
7>master_port.c
7>jbuf.c
7>g711.c
7>errno.c
7>endpoint.c
7>echo_suppress.c
7>echo_speex.c
7>echo_port.c
7>echo_common.c
7>conference.c
7>codec.c
7>clock_thread.c
7>bidirectional.c
7>Compiling...
7>alaw_ulaw_table.c
15>Compiling...
15>pjsua_acc.c
15>pjsua_pres.c
15>pjsua_media.c
15>pjsua_im.c
15>pjsua_core.c
15>pjsua_call.c
label
16>Compiling...
16>StdAfx.cpp
16>Compiling...
16>pjsua_wince.cpp
16>Linking...
Arpit Mehta
Graduate Student
Columbia University
Tel: 1-646-387-5998
Hi,
commctrl.lib
coredll.lib
winsock.lib
ws2.lib
iphlpapi.lib
Thanks
Regards
Arpit Mehta
Graduate Student
Columbia University
On Nov 28, 2007 2:36 PM, Arpit Mehta <am2866@columbia.edu> wrote:
> hi,
> here
> 16>Compiling...
> 16>StdAfx.cpp
> 16>Compiling...
> 16>pjsua_wince.cpp
> 16>Linking...
> pjmedia_snd_init
> get_speex_info
> get_speex_info
> spx_codec_close
> spx_codec_modify
> spx_codec_encode
> spx_codec_encode
> spx_codec_encode
> spx_codec_encode
> spx_codec_decode
> spx_codec_decode
> spx_codec_open
> spx_codec_open
> Thanks
> Regards
> Arpit Mehta
> > > Project: libspeex
> > cheers,
> > -benny
> > Arpit Mehta wrote:
> > > Hello all,
> > > Steps I followed
> > > Project: libspeex
> > > the link error.
> > > Thanks
> > > Regards
> > > Arpit Mehta
> > > 2>Compiling...
> > > 1>Compiling...
> > > 2>gsm.c
> > > 2>speex_codec.c
> > > 2>l16.c
> > > 2>ilbc.c
> > > 1>unicode_win32.c
> > > 1>types.c
> > > 1>timer.c
> > > 1>string.c
> > > 3>Compiling...
> > > 3>sip_100rel.c
> > > 1>sock_select.c
> > > 1>sock_common.c
> > > 1>sock_bsd.c
> > > 1>rbtree.c
> > > 3>sip_xfer.c
> > > 1>rand.c
> > > 1>pool_caching.c
> > > 3>sip_replaces.c
> > > 1>pool_buf.c
> > > 1>pool.c
> > > 3>sip_reg.c
> > > 3>sip_inv.c
> > > 1>os_time_win32.c
> > > 1>os_error_win32.c
> > > 1>os_core_win32.c
> > > 4>Compiling...
> > > 4>errno.c
> > > 4>xpidf.c
> > > 1>Compiling...
> > > 1>log.c
> > > 1>lock.c
> > > 1>list.c
> > > 4>rpid.c
> > > 1>ip_helper_win32.c
> > > 4>publishc.c
> > > 4>presence_body.c
> > > 4>presence.c
> > > 1>ioqueue_select.c
> > > 4>pidf.c
> > > 4>iscomposing.c
> > > 1>hash.c
> > > 4>evsub_msg.c
> > > 1>guid_simple.c
> > > 4>evsub.c
> > > 1>guid.c
> > > 1>file_io_win32.c
> > > 1>fifobuf.c
> > > 1>except.c
> > > 1>errno.c
> > > 5>Compiling...
> > > 1>ctype.c
> > > 5>sip_auth_aka.c
> > > 1>config.c
> > > 1>array.c
> > > 5>sip_util_proxy.c
> > > 5>sip_util.c
> > > label
> > > 5>sip_uri.c
> > > 5>sip_ua_layer.c
> > > 6>Compiling...
> > > 6>base64.c
> > > 6>xml.c
> > > 6>stun_simple.c
> > > 6>string.c
> > > 6>srv_resolver.c
> > > 6>sha1.c
> > > 6>scanner.c
> > > 5>sip_transport.c
> > > 6>resolver.c
> > > 6>md5.c
> > > 5>sip_transaction.c
> > > 6>hmac_sha1.c
> > > 6>hmac_md5.c
> > > 6>getopt.c
> > > 5>sip_tel_uri.c
> > > 6>errno.c
> > > 6>dns_dump.c
> > > 5>sip_resolve.c
> > > 6>dns.c
> > > 5>sip_parser.c
> > > 6>crc32.c
> > > 5>sip_msg.c
> > > 5>sip_errno.c
> > > 5>sip_endpoint.c
> > > 5>sip_dialog.c
> > > 5>sip_auth_server.c
> > > 5>sip_auth_parser.c
> > > 7>Compiling...
> > > 7>alaw_ulaw.c
> > > 7>wave.c
> > > 7>wav_writer.c
> > > 7>wav_playlist.c
> > > 7>wav_player.c
> > > 5>Compiling...
> > > 5>sip_auth_msg.c
> > > 7>transport_udp.c
> > > 5>sip_auth_client.c
> > > 7>transport_ice.c
> > > 7>tonegen.c
> > > 7>stream.c
> > > 9>Compiling...
> > > 9>errno.c
> > > 7>splitcomb.c
> > > 9>stun_session.c
> > > 7>sound_port.c
> > > 9>stun_msg_dump.c
> > > 7>silencedet.c
> > > 9>stun_msg.c
> > > 7>session.c
> > > 9>stun_auth.c
> > > 7>sdp_neg.c
> > > 9>nat_detect.c
> > > unreferenced label
> > > 7>sdp_cmp.c
> > > 7>sdp.c
> > > 7>rtp.c
> > > 9>ice_strans.c
> > > 7>rtcp.c
> > > 7>resample_speex.c
> > > 9>ice_session.c
> > > unreferenced label
> > > 7>Compiling...
> > > 7>resample_port.c
> > > 7>port.c
> > > 7>plc_common.c
> > > Win32 ------
> > > Win32 ------
> > > 7>pasound.c
> > > 7>null_port.c
> > > 7>mem_player.c
> > > 7>mem_capture.c
> > > 7>master_port.c
> > > 7>jbuf.c
> > > 7>g711.c
> > > 7>errno.c
> > > 7>endpoint.c
> > > 7>echo_suppress.c
> > > 7>echo_speex.c
> > > 7>echo_port.c
> > > 7>echo_common.c
> > > 7>conference.c
> > > 7>codec.c
> > > 7>clock_thread.c
> > > 7>bidirectional.c
> > > 7>Compiling...
> > > 7>alaw_ulaw_table.c
> > > 15>Compiling...
> > > 15>pjsua_acc.c
> > > 15>pjsua_pres.c
> > > 15>pjsua_media.c
> > > 15>pjsua_im.c
> > > 15>pjsua_core.c
> > > 15>pjsua_call.c
> > > label
> > > 16>Compiling...
> > > 16>StdAfx.cpp
> > > 16>Compiling...
> > > 16>pjsua_wince.cpp
> > > 16>Linking...
> > Benny Prijono
> > pjsip mailing list
> Arpit Mehta
> Graduate Student
> Columbia University
> Tel: 1-646-387-5998
OB
Olivier Beytrison
Thu, Nov 29, 2007 10:43 AM
Hello,
Sorry for being less active those days, I just got my degree so I was
pretty busy the past days.
alright, the problem here is that the solution you have contains wince
projects (all the pjsip projects) and Win32 projects (the third party
project). This happened because when you openend the wince_demos.vcw
file, you didn't said "no" when VS2005 asked you if you want to use the
existing VC++ project file.
In fact, if you look at the third_party\build*\ directory, you will
always find a .vcp, .dsp and .vcproj file.
.vcproj is for Win32
.vcp is for WinCE
.dsp i don't remember
when VS2005 open the .vcp project file he see that there's already a
.vcproj file present, and ask you if you want to load it insteed. that's
the problem, if you accept, you end up with Win32 projects in your WinCE
solution.
below is the steps to perform in order to get a working version of
pjsua_wince for Windows Mobile 6
Check out a fresh new version of the pjsip project from its svn
Copy the pjlib\include\pj\config_site_sample.h as config_site.h
Edit the file \third_party\portaudio\src\common\pa_debugprint.c
line 77 change it from
#if (_MSC_VER) && (_MSC_VER < 1400)
to
#if (_MSC_VER) && (_MSC_VER <= 1400)
Launch VS20005 Professional
browse and open the pjsip-apps\build\wince-evc4\wince_demos.vcw file
now be sure to answer "NO" when VS2005 asks you if you want to use
the project file already present for some of the projects. If you say
yes, you will load project files for win32, in place of winCE (which
is the problem when looking at your mail)
Answer "Yes" when they ask you if you want to convert the project
file
Choose "Windows Mobile 6 Professional" from the drop down, and debug
Run "Generate" on the pjsua_wince project and it should be okay :)
with those steps you're sure to have something working at the end.
Regards,
Olivier B.
Arpit Mehta a écrit :
Hi,
commctrl.lib
coredll.lib
winsock.lib
ws2.lib
iphlpapi.lib
Thanks
Regards
Arpit Mehta
Graduate Student
Columbia University
hi,
here
16>Compiling...
16>StdAfx.cpp
16>Compiling...
16>pjsua_wince.cpp
16>Linking...
pjmedia_snd_init
get_speex_info
get_speex_info
spx_codec_close
spx_codec_modify
spx_codec_encode
spx_codec_encode
spx_codec_encode
spx_codec_encode
spx_codec_decode
spx_codec_decode
spx_codec_open
spx_codec_open
Thanks
Regards
Arpit Mehta
Project: libspeex
cheers,
-benny
Arpit Mehta wrote:
Hello all,
Steps I followed
Project: libspeex
the link error.
Thanks
Regards
Arpit Mehta
2>Compiling...
1>Compiling...
2>gsm.c
2>speex_codec.c
2>l16.c
2>ilbc.c
1>unicode_win32.c
1>types.c
1>timer.c
1>string.c
3>Compiling...
3>sip_100rel.c
1>sock_select.c
1>sock_common.c
1>sock_bsd.c
1>rbtree.c
3>sip_xfer.c
1>rand.c
1>pool_caching.c
3>sip_replaces.c
1>pool_buf.c
1>pool.c
3>sip_reg.c
3>sip_inv.c
1>os_time_win32.c
1>os_error_win32.c
1>os_core_win32.c
4>Compiling...
4>errno.c
4>xpidf.c
1>Compiling...
1>log.c
1>lock.c
1>list.c
4>rpid.c
1>ip_helper_win32.c
4>publishc.c
4>presence_body.c
4>presence.c
1>ioqueue_select.c
4>pidf.c
4>iscomposing.c
1>hash.c
4>evsub_msg.c
1>guid_simple.c
4>evsub.c
1>guid.c
1>file_io_win32.c
1>fifobuf.c
1>except.c
1>errno.c
5>Compiling...
1>ctype.c
5>sip_auth_aka.c
1>config.c
1>array.c
5>sip_util_proxy.c
5>sip_util.c
label
5>sip_uri.c
5>sip_ua_layer.c
6>Compiling...
6>base64.c
6>xml.c
6>stun_simple.c
6>string.c
6>srv_resolver.c
6>sha1.c
6>scanner.c
5>sip_transport.c
6>resolver.c
6>md5.c
5>sip_transaction.c
6>hmac_sha1.c
6>hmac_md5.c
6>getopt.c
5>sip_tel_uri.c
6>errno.c
6>dns_dump.c
5>sip_resolve.c
6>dns.c
5>sip_parser.c
6>crc32.c
5>sip_msg.c
5>sip_errno.c
5>sip_endpoint.c
5>sip_dialog.c
5>sip_auth_server.c
5>sip_auth_parser.c
7>Compiling...
7>alaw_ulaw.c
7>wave.c
7>wav_writer.c
7>wav_playlist.c
7>wav_player.c
5>Compiling...
5>sip_auth_msg.c
7>transport_udp.c
5>sip_auth_client.c
7>transport_ice.c
7>tonegen.c
7>stream.c
9>Compiling...
9>errno.c
7>splitcomb.c
9>stun_session.c
7>sound_port.c
9>stun_msg_dump.c
7>silencedet.c
9>stun_msg.c
7>session.c
9>stun_auth.c
7>sdp_neg.c
9>nat_detect.c
unreferenced label
7>sdp_cmp.c
7>sdp.c
7>rtp.c
9>ice_strans.c
7>rtcp.c
7>resample_speex.c
9>ice_session.c
unreferenced label
7>Compiling...
7>resample_port.c
7>port.c
7>plc_common.c
Win32 ------
Win32 ------
7>pasound.c
7>null_port.c
7>mem_player.c
7>mem_capture.c
7>master_port.c
7>jbuf.c
7>g711.c
7>errno.c
7>endpoint.c
7>echo_suppress.c
7>echo_speex.c
7>echo_port.c
7>echo_common.c
7>conference.c
7>codec.c
7>clock_thread.c
7>bidirectional.c
7>Compiling...
7>alaw_ulaw_table.c
15>Compiling...
15>pjsua_acc.c
15>pjsua_pres.c
15>pjsua_media.c
15>pjsua_im.c
15>pjsua_core.c
15>pjsua_call.c
label
16>Compiling...
16>StdAfx.cpp
16>Compiling...
16>pjsua_wince.cpp
16>Linking...
Arpit Mehta
Graduate Student
Columbia University
Tel: 1-646-387-5998
Hello,
In fact, if you look at the third_party\build\*\ directory, you will
.vcp is for WinCE
solution.
1. Check out a fresh new version of the pjsip project from its svn
2. Copy the pjlib\include\pj\config_site_sample.h as config_site.h
3. Edit the file \third_party\portaudio\src\common\pa_debugprint.c
to
4. Launch VS20005 Professional
5. browse and open the pjsip-apps\build\wince-evc4\wince_demos.vcw file
6. now be sure to answer "NO" when VS2005 asks you if you want to use
7. Answer "Yes" when they ask you if you want to convert the project
file
8. Choose "Windows Mobile 6 Professional" from the drop down, and debug
9. Run "Generate" on the pjsua_wince project and it should be okay :)
Regards,
Olivier B.
> Hi,
> commctrl.lib
> coredll.lib
> winsock.lib
> ws2.lib
> iphlpapi.lib
> Thanks
> Regards
> Arpit Mehta
> Graduate Student
> Columbia University
>> hi,
>> here
>> 16>Compiling...
>> 16>StdAfx.cpp
>> 16>Compiling...
>> 16>pjsua_wince.cpp
>> 16>Linking...
>> pjmedia_snd_init
>> get_speex_info
>> get_speex_info
>> spx_codec_close
>> spx_codec_modify
>> spx_codec_encode
>> spx_codec_encode
>> spx_codec_encode
>> spx_codec_encode
>> spx_codec_decode
>> spx_codec_decode
>> spx_codec_open
>> spx_codec_open
>> Thanks
>> Regards
>> Arpit Mehta
>>> > Project: libspeex
>>> cheers,
>>> -benny
>>> Arpit Mehta wrote:
>>>> Hello all,
>>>> Steps I followed
>>>> Project: libspeex
>>>> the link error.
>>>> Thanks
>>>> Regards
>>>> Arpit Mehta
>>>> 2>Compiling...
>>>> 1>Compiling...
>>>> 2>gsm.c
>>>> 2>speex_codec.c
>>>> 2>l16.c
>>>> 2>ilbc.c
>>>> 1>unicode_win32.c
>>>> 1>types.c
>>>> 1>timer.c
>>>> 1>string.c
>>>> 3>Compiling...
>>>> 3>sip_100rel.c
>>>> 1>sock_select.c
>>>> 1>sock_common.c
>>>> 1>sock_bsd.c
>>>> 1>rbtree.c
>>>> 3>sip_xfer.c
>>>> 1>rand.c
>>>> 1>pool_caching.c
>>>> 3>sip_replaces.c
>>>> 1>pool_buf.c
>>>> 1>pool.c
>>>> 3>sip_reg.c
>>>> 3>sip_inv.c
>>>> 1>os_time_win32.c
>>>> 1>os_error_win32.c
>>>> 1>os_core_win32.c
>>>> 4>Compiling...
>>>> 4>errno.c
>>>> 4>xpidf.c
>>>> 1>Compiling...
>>>> 1>log.c
>>>> 1>lock.c
>>>> 1>list.c
>>>> 4>rpid.c
>>>> 1>ip_helper_win32.c
>>>> 4>publishc.c
>>>> 4>presence_body.c
>>>> 4>presence.c
>>>> 1>ioqueue_select.c
>>>> 4>pidf.c
>>>> 4>iscomposing.c
>>>> 1>hash.c
>>>> 4>evsub_msg.c
>>>> 1>guid_simple.c
>>>> 4>evsub.c
>>>> 1>guid.c
>>>> 1>file_io_win32.c
>>>> 1>fifobuf.c
>>>> 1>except.c
>>>> 1>errno.c
>>>> 5>Compiling...
>>>> 1>ctype.c
>>>> 5>sip_auth_aka.c
>>>> 1>config.c
>>>> 1>array.c
>>>> 5>sip_util_proxy.c
>>>> 5>sip_util.c
>>>> label
>>>> 5>sip_uri.c
>>>> 5>sip_ua_layer.c
>>>> 6>Compiling...
>>>> 6>base64.c
>>>> 6>xml.c
>>>> 6>stun_simple.c
>>>> 6>string.c
>>>> 6>srv_resolver.c
>>>> 6>sha1.c
>>>> 6>scanner.c
>>>> 5>sip_transport.c
>>>> 6>resolver.c
>>>> 6>md5.c
>>>> 5>sip_transaction.c
>>>> 6>hmac_sha1.c
>>>> 6>hmac_md5.c
>>>> 6>getopt.c
>>>> 5>sip_tel_uri.c
>>>> 6>errno.c
>>>> 6>dns_dump.c
>>>> 5>sip_resolve.c
>>>> 6>dns.c
>>>> 5>sip_parser.c
>>>> 6>crc32.c
>>>> 5>sip_msg.c
>>>> 5>sip_errno.c
>>>> 5>sip_endpoint.c
>>>> 5>sip_dialog.c
>>>> 5>sip_auth_server.c
>>>> 5>sip_auth_parser.c
>>>> 7>Compiling...
>>>> 7>alaw_ulaw.c
>>>> 7>wave.c
>>>> 7>wav_writer.c
>>>> 7>wav_playlist.c
>>>> 7>wav_player.c
>>>> 5>Compiling...
>>>> 5>sip_auth_msg.c
>>>> 7>transport_udp.c
>>>> 5>sip_auth_client.c
>>>> 7>transport_ice.c
>>>> 7>tonegen.c
>>>> 7>stream.c
>>>> 9>Compiling...
>>>> 9>errno.c
>>>> 7>splitcomb.c
>>>> 9>stun_session.c
>>>> 7>sound_port.c
>>>> 9>stun_msg_dump.c
>>>> 7>silencedet.c
>>>> 9>stun_msg.c
>>>> 7>session.c
>>>> 9>stun_auth.c
>>>> 7>sdp_neg.c
>>>> 9>nat_detect.c
>>>> unreferenced label
>>>> 7>sdp_cmp.c
>>>> 7>sdp.c
>>>> 7>rtp.c
>>>> 9>ice_strans.c
>>>> 7>rtcp.c
>>>> 7>resample_speex.c
>>>> 9>ice_session.c
>>>> unreferenced label
>>>> 7>Compiling...
>>>> 7>resample_port.c
>>>> 7>port.c
>>>> 7>plc_common.c
>>>> Win32 ------
>>>> Win32 ------
>>>> 7>pasound.c
>>>> 7>null_port.c
>>>> 7>mem_player.c
>>>> 7>mem_capture.c
>>>> 7>master_port.c
>>>> 7>jbuf.c
>>>> 7>g711.c
>>>> 7>errno.c
>>>> 7>endpoint.c
>>>> 7>echo_suppress.c
>>>> 7>echo_speex.c
>>>> 7>echo_port.c
>>>> 7>echo_common.c
>>>> 7>conference.c
>>>> 7>codec.c
>>>> 7>clock_thread.c
>>>> 7>bidirectional.c
>>>> 7>Compiling...
>>>> 7>alaw_ulaw_table.c
>>>> 15>Compiling...
>>>> 15>pjsua_acc.c
>>>> 15>pjsua_pres.c
>>>> 15>pjsua_media.c
>>>> 15>pjsua_im.c
>>>> 15>pjsua_core.c
>>>> 15>pjsua_call.c
>>>> label
>>>> 16>Compiling...
>>>> 16>StdAfx.cpp
>>>> 16>Compiling...
>>>> 16>pjsua_wince.cpp
>>>> 16>Linking...
>>> Benny Prijono
>>> pjsip mailing list
>> Arpit Mehta
>> Graduate Student
>> Columbia University
>> Tel: 1-646-387-5998
> pjsip mailing list
Olivier Beytrison
Telecommunication Engineer
Mobile: +41 (0)78 619 73 53
Mail: olivier@heliosnet.org
GPG: 0x4FB83528 http://pgp.mit.edu/
AM
Arpit Mehta
Fri, Nov 30, 2007 1:34 AM
Thanks !!! Well the procedure worked like a charm !! :) I hope it gets
included somewhere in the documentation to make it easier for first
time users like me.
Just to let you know VS2005 gave errors the first time regarding
corrupt project, but checking out the source code again worked just
fine.
So now I have a very simple UA from which can make a call only. Is it
the rest of UA (the one which I saw in the screenshot for WinXP
http://www.pjsip.org/pjsip/docs/html/page_pjsip_samples.htm) also
available as a WinCE port ?
Thanks
Regards
Arpit Mehta
On Nov 29, 2007 5:43 AM, Olivier Beytrison olivier@heliosnet.org wrote:
Hello,
.vcp is for WinCE
solution.
to
file
Regards,
Olivier B.
Hi,
commctrl.lib
coredll.lib
winsock.lib
ws2.lib
iphlpapi.lib
Thanks
Regards
Arpit Mehta
Graduate Student
Columbia University
hi,
here
16>Compiling...
16>StdAfx.cpp
16>Compiling...
16>pjsua_wince.cpp
16>Linking...
pjmedia_snd_init
get_speex_info
get_speex_info
spx_codec_close
spx_codec_modify
spx_codec_encode
spx_codec_encode
spx_codec_encode
spx_codec_encode
spx_codec_decode
spx_codec_decode
spx_codec_open
spx_codec_open
Thanks
Regards
Arpit Mehta
Project: libspeex
cheers,
-benny
Arpit Mehta wrote:
Hello all,
Steps I followed
Project: libspeex
the link error.
Thanks
Regards
Arpit Mehta
2>Compiling...
1>Compiling...
2>gsm.c
2>speex_codec.c
2>l16.c
2>ilbc.c
1>unicode_win32.c
1>types.c
1>timer.c
1>string.c
3>Compiling...
3>sip_100rel.c
1>sock_select.c
1>sock_common.c
1>sock_bsd.c
1>rbtree.c
3>sip_xfer.c
1>rand.c
1>pool_caching.c
3>sip_replaces.c
1>pool_buf.c
1>pool.c
3>sip_reg.c
3>sip_inv.c
1>os_time_win32.c
1>os_error_win32.c
1>os_core_win32.c
4>Compiling...
4>errno.c
4>xpidf.c
1>Compiling...
1>log.c
1>lock.c
1>list.c
4>rpid.c
1>ip_helper_win32.c
4>publishc.c
4>presence_body.c
4>presence.c
1>ioqueue_select.c
4>pidf.c
4>iscomposing.c
1>hash.c
4>evsub_msg.c
1>guid_simple.c
4>evsub.c
1>guid.c
1>file_io_win32.c
1>fifobuf.c
1>except.c
1>errno.c
5>Compiling...
1>ctype.c
5>sip_auth_aka.c
1>config.c
1>array.c
5>sip_util_proxy.c
5>sip_util.c
label
5>sip_uri.c
5>sip_ua_layer.c
6>Compiling...
6>base64.c
6>xml.c
6>stun_simple.c
6>string.c
6>srv_resolver.c
6>sha1.c
6>scanner.c
5>sip_transport.c
6>resolver.c
6>md5.c
5>sip_transaction.c
6>hmac_sha1.c
6>hmac_md5.c
6>getopt.c
5>sip_tel_uri.c
6>errno.c
6>dns_dump.c
5>sip_resolve.c
6>dns.c
5>sip_parser.c
6>crc32.c
5>sip_msg.c
5>sip_errno.c
5>sip_endpoint.c
5>sip_dialog.c
5>sip_auth_server.c
5>sip_auth_parser.c
7>Compiling...
7>alaw_ulaw.c
7>wave.c
7>wav_writer.c
7>wav_playlist.c
7>wav_player.c
5>Compiling...
5>sip_auth_msg.c
7>transport_udp.c
5>sip_auth_client.c
7>transport_ice.c
7>tonegen.c
7>stream.c
9>Compiling...
9>errno.c
7>splitcomb.c
9>stun_session.c
7>sound_port.c
9>stun_msg_dump.c
7>silencedet.c
9>stun_msg.c
7>session.c
9>stun_auth.c
7>sdp_neg.c
9>nat_detect.c
unreferenced label
7>sdp_cmp.c
7>sdp.c
7>rtp.c
9>ice_strans.c
7>rtcp.c
7>resample_speex.c
9>ice_session.c
unreferenced label
7>Compiling...
7>resample_port.c
7>port.c
7>plc_common.c
Win32 ------
Win32 ------
7>pasound.c
7>null_port.c
7>mem_player.c
7>mem_capture.c
7>master_port.c
7>jbuf.c
7>g711.c
7>errno.c
7>endpoint.c
7>echo_suppress.c
7>echo_speex.c
7>echo_port.c
7>echo_common.c
7>conference.c
7>codec.c
7>clock_thread.c
7>bidirectional.c
7>Compiling...
7>alaw_ulaw_table.c
15>Compiling...
15>pjsua_acc.c
15>pjsua_pres.c
15>pjsua_media.c
15>pjsua_im.c
15>pjsua_core.c
15>pjsua_call.c
label
16>Compiling...
16>StdAfx.cpp
16>Compiling...
16>pjsua_wince.cpp
16>Linking...
Arpit Mehta
Graduate Student
Columbia University
Tel: 1-646-387-5998
Arpit Mehta
Graduate Student
Columbia University
Tel: 1-646-387-5998
time users like me.
fine.
Thanks
Regards
Arpit Mehta
On Nov 29, 2007 5:43 AM, Olivier Beytrison <olivier@heliosnet.org> wrote:
> Hello,
> .vcp is for WinCE
> solution.
> to
> file
> Regards,
> Olivier B.
> > Hi,
> > commctrl.lib
> > coredll.lib
> > winsock.lib
> > ws2.lib
> > iphlpapi.lib
> > Thanks
> > Regards
> > Arpit Mehta
> > Graduate Student
> > Columbia University
> >> hi,
> >> here
> >> 16>Compiling...
> >> 16>StdAfx.cpp
> >> 16>Compiling...
> >> 16>pjsua_wince.cpp
> >> 16>Linking...
> >> pjmedia_snd_init
> >> get_speex_info
> >> get_speex_info
> >> spx_codec_close
> >> spx_codec_modify
> >> spx_codec_encode
> >> spx_codec_encode
> >> spx_codec_encode
> >> spx_codec_encode
> >> spx_codec_decode
> >> spx_codec_decode
> >> spx_codec_open
> >> spx_codec_open
> >> Thanks
> >> Regards
> >> Arpit Mehta
> >>> > Project: libspeex
> >>> cheers,
> >>> -benny
> >>> Arpit Mehta wrote:
> >>>> Hello all,
> >>>> Steps I followed
> >>>> Project: libspeex
> >>>> the link error.
> >>>> Thanks
> >>>> Regards
> >>>> Arpit Mehta
> >>>> 2>Compiling...
> >>>> 1>Compiling...
> >>>> 2>gsm.c
> >>>> 2>speex_codec.c
> >>>> 2>l16.c
> >>>> 2>ilbc.c
> >>>> 1>unicode_win32.c
> >>>> 1>types.c
> >>>> 1>timer.c
> >>>> 1>string.c
> >>>> 3>Compiling...
> >>>> 3>sip_100rel.c
> >>>> 1>sock_select.c
> >>>> 1>sock_common.c
> >>>> 1>sock_bsd.c
> >>>> 1>rbtree.c
> >>>> 3>sip_xfer.c
> >>>> 1>rand.c
> >>>> 1>pool_caching.c
> >>>> 3>sip_replaces.c
> >>>> 1>pool_buf.c
> >>>> 1>pool.c
> >>>> 3>sip_reg.c
> >>>> 3>sip_inv.c
> >>>> 1>os_time_win32.c
> >>>> 1>os_error_win32.c
> >>>> 1>os_core_win32.c
> >>>> 4>Compiling...
> >>>> 4>errno.c
> >>>> 4>xpidf.c
> >>>> 1>Compiling...
> >>>> 1>log.c
> >>>> 1>lock.c
> >>>> 1>list.c
> >>>> 4>rpid.c
> >>>> 1>ip_helper_win32.c
> >>>> 4>publishc.c
> >>>> 4>presence_body.c
> >>>> 4>presence.c
> >>>> 1>ioqueue_select.c
> >>>> 4>pidf.c
> >>>> 4>iscomposing.c
> >>>> 1>hash.c
> >>>> 4>evsub_msg.c
> >>>> 1>guid_simple.c
> >>>> 4>evsub.c
> >>>> 1>guid.c
> >>>> 1>file_io_win32.c
> >>>> 1>fifobuf.c
> >>>> 1>except.c
> >>>> 1>errno.c
> >>>> 5>Compiling...
> >>>> 1>ctype.c
> >>>> 5>sip_auth_aka.c
> >>>> 1>config.c
> >>>> 1>array.c
> >>>> 5>sip_util_proxy.c
> >>>> 5>sip_util.c
> >>>> label
> >>>> 5>sip_uri.c
> >>>> 5>sip_ua_layer.c
> >>>> 6>Compiling...
> >>>> 6>base64.c
> >>>> 6>xml.c
> >>>> 6>stun_simple.c
> >>>> 6>string.c
> >>>> 6>srv_resolver.c
> >>>> 6>sha1.c
> >>>> 6>scanner.c
> >>>> 5>sip_transport.c
> >>>> 6>resolver.c
> >>>> 6>md5.c
> >>>> 5>sip_transaction.c
> >>>> 6>hmac_sha1.c
> >>>> 6>hmac_md5.c
> >>>> 6>getopt.c
> >>>> 5>sip_tel_uri.c
> >>>> 6>errno.c
> >>>> 6>dns_dump.c
> >>>> 5>sip_resolve.c
> >>>> 6>dns.c
> >>>> 5>sip_parser.c
> >>>> 6>crc32.c
> >>>> 5>sip_msg.c
> >>>> 5>sip_errno.c
> >>>> 5>sip_endpoint.c
> >>>> 5>sip_dialog.c
> >>>> 5>sip_auth_server.c
> >>>> 5>sip_auth_parser.c
> >>>> 7>Compiling...
> >>>> 7>alaw_ulaw.c
> >>>> 7>wave.c
> >>>> 7>wav_writer.c
> >>>> 7>wav_playlist.c
> >>>> 7>wav_player.c
> >>>> 5>Compiling...
> >>>> 5>sip_auth_msg.c
> >>>> 7>transport_udp.c
> >>>> 5>sip_auth_client.c
> >>>> 7>transport_ice.c
> >>>> 7>tonegen.c
> >>>> 7>stream.c
> >>>> 9>Compiling...
> >>>> 9>errno.c
> >>>> 7>splitcomb.c
> >>>> 9>stun_session.c
> >>>> 7>sound_port.c
> >>>> 9>stun_msg_dump.c
> >>>> 7>silencedet.c
> >>>> 9>stun_msg.c
> >>>> 7>session.c
> >>>> 9>stun_auth.c
> >>>> 7>sdp_neg.c
> >>>> 9>nat_detect.c
> >>>> unreferenced label
> >>>> 7>sdp_cmp.c
> >>>> 7>sdp.c
> >>>> 7>rtp.c
> >>>> 9>ice_strans.c
> >>>> 7>rtcp.c
> >>>> 7>resample_speex.c
> >>>> 9>ice_session.c
> >>>> unreferenced label
> >>>> 7>Compiling...
> >>>> 7>resample_port.c
> >>>> 7>port.c
> >>>> 7>plc_common.c
> >>>> Win32 ------
> >>>> Win32 ------
> >>>> 7>pasound.c
> >>>> 7>null_port.c
> >>>> 7>mem_player.c
> >>>> 7>mem_capture.c
> >>>> 7>master_port.c
> >>>> 7>jbuf.c
> >>>> 7>g711.c
> >>>> 7>errno.c
> >>>> 7>endpoint.c
> >>>> 7>echo_suppress.c
> >>>> 7>echo_speex.c
> >>>> 7>echo_port.c
> >>>> 7>echo_common.c
> >>>> 7>conference.c
> >>>> 7>codec.c
> >>>> 7>clock_thread.c
> >>>> 7>bidirectional.c
> >>>> 7>Compiling...
> >>>> 7>alaw_ulaw_table.c
> >>>> 15>Compiling...
> >>>> 15>pjsua_acc.c
> >>>> 15>pjsua_pres.c
> >>>> 15>pjsua_media.c
> >>>> 15>pjsua_im.c
> >>>> 15>pjsua_core.c
> >>>> 15>pjsua_call.c
> >>>> label
> >>>> 16>Compiling...
> >>>> 16>StdAfx.cpp
> >>>> 16>Compiling...
> >>>> 16>pjsua_wince.cpp
> >>>> 16>Linking...
> >>> Benny Prijono
> >>> pjsip mailing list
> >> Arpit Mehta
> >> Graduate Student
> >> Columbia University
> >> Tel: 1-646-387-5998
> > pjsip mailing list
> Olivier Beytrison
> pjsip mailing list
Arpit Mehta
Graduate Student
Columbia University
Tel: 1-646-387-5998
