Ravi Inder Singh wrote:
Hi Benny,
I am trying to add Fax Tone detection support in PJSIP, I want to
trigger my upper application about the Fax Detection, for that I need
Event Call back from Media i.e. Fax tone has been detected. After going
in some details of PJ-Media code I came across that this it is quite
similar like detecting RFC2833 (Digit) Event i.e. Register Event as soon
as the call is connected in pjsua_call.c in
pjmedia_session_set_dtmf_callback function.
I came out to this solution only. I need the better way of doing it,
if it is available.
Hi Ravi,
another, perhaps cleaner, solution is to implement a media port to
detect the fax tone. There are few articles in PJSIP FAQ which
describes about implementing media ports, please see
http://www.pjsip.org/trac/wiki/FAQ
Once you've implemented the tone detection media port, you can
register it to the conference bridge and connect it to the call to
start listening for the tone.
I prefer this solution since it doesn't need any modification to
stream.c. RFC 2833 digit was implemented differently since it needs
to work on the RTP packet level rather than PCM level, thus it needs
to reside in stream.c.
cheers,
-benny
Looking forward for quick response.
Thanks & Regards,
Ravi Inder Singh
Visit our blog: http://blog.pjsip.org
pjsip mailing list
pjsip@lists.pjsip.org
http://lists.pjsip.org/mailman/listinfo/pjsip_lists.pjsip.org
Benny Prijono
Hi Benny,
I cannot be so sure that by adding Media Port this problem can be
resolved, as my requirement is for adding Answering Fax Machine, i.e. Media
port two functions, which both cannot resolve my issue.
a) get_frame () --> Conference bridge will get frames from this Media port.
Mem_player.c works like this only.
b) put_frame () --> This will save to PCM frames to a buffer but these PCM
frames will come from Sound Port i.e. MIC.
This is my understanding, please correct me if I am wrong on this.
My requirement is to detect
a) Answering Fax Machine detection --> which can be done by scanning
incoming Frames after they have been decoded in stream.c
b) Answering Machine detection --> This should be done only when 200 OK
has been received from other side. Is there any way to handle from
application, to enable Media port only when 200 Ok has been received.
Regards,
Ravi Inder Singh.
-----Original Message-----
From: pjsip-bounces@lists.pjsip.org [mailto:pjsip-bounces@lists.pjsip.org]
On Behalf Of Benny Prijono
Sent: Tuesday, October 16, 2007 10:02 PM
To: pjsip embedded/DSP SIP discussion
Subject: Re: [pjsip] FW: Intergrating Fax Tone Detection support
Hi Benny,
if it is available.
Hi Ravi,
cheers,
-benny
Thanks & Regards,
Ravi Inder Singh
pjsip mailing list
Benny Prijono
pjsip mailing list
