trawlers@lists.trawlering.com
TRAWLERS & TRAWLERING LIST
website on corrosion and many other topics, test for 316ss
JD
Jim Donnelly
Mon, Jul 4, 2005 12:23 AM
http://www.yachtsurvey.com/corrosion.htm has some excellent basic
explanations of corrosion in the marine environment.
  1. I sell a lot of scrap stainless steel in 200 ton lots, and I needed a
    quick and dirty test to tell the good stuff ( 316)  from the junk.
2 junkmens tests are widely used -  The magnet test ( it will NOT stick to
the really good stuff)
  • the acid test with a 9 volt battery.  You put a drop of acid (HCl works
    fine)  on the metal.  With a 9 volt battery and 2 pieces of jumper wire-
    you ground the negative side to the sample and just touch the positive wire
    to the drop of acid.  The acid will turn pink+ to red immediately if it is
    high moly stainless.  That makes it worth twice as much.  In the Papermill
    business we use mostly 316 due to its RELATIVE (but not absolute)
    resistance to Chloride Stress Corrosion which leads to catastrophic cracks.
  • you are much safer with good hot dip galvanized steel screws (not the
    flash plated junk)  than you are with any "stainless".  Monel is good.  But
    hard to get small quantities in  the sizes we use (14 x 2 1/2).
The name "Stainless Steel" is about as definitive as "Dog"
read this stuff:  www.corrosion-doctors.org
.  Silicon Bronze
is another subject-  There has been a lot of trouble in the REAL ( wooden)
Boat Building and Repair industry with junk metal sold as Silicon Bronze.
(Dont Eat that, Elmer).  This stuff has caused serious trouble with
snapping off during driving.    Look at some back issues of Wooden Boat for
coverage on this. Also search on the web to read about Brasses and Bronzes.
Brass has no place at all in the marine environment,  except as shiny
stuff.
Jim Donnelly
Troller Fan Isle
With the OPEN WIRELESS NODE
at Powell River BC
1) http://www.yachtsurvey.com/corrosion.htm has some excellent basic explanations of corrosion in the marine environment. 2) I sell a lot of scrap stainless steel in 200 ton lots, and I needed a quick and dirty test to tell the good stuff ( 316) from the junk. 2 junkmens tests are widely used - The magnet test ( it will NOT stick to the really good stuff) - the acid test with a 9 volt battery. You put a drop of acid (HCl works fine) on the metal. With a 9 volt battery and 2 pieces of jumper wire- you ground the negative side to the sample and just touch the positive wire to the drop of acid. The acid will turn pink+ to red immediately if it is high moly stainless. That makes it worth twice as much. In the Papermill business we use mostly 316 due to its RELATIVE (but not absolute) resistance to Chloride Stress Corrosion which leads to catastrophic cracks. - you are much safer with good hot dip galvanized steel screws (not the flash plated junk) than you are with any "stainless". Monel is good. But hard to get small quantities in the sizes we use (14 x 2 1/2). The name "Stainless Steel" is about as definitive as "Dog" read this stuff: www.corrosion-doctors.org . Silicon Bronze is another subject- There has been a lot of trouble in the REAL ( wooden) Boat Building and Repair industry with junk metal sold as Silicon Bronze. (Dont Eat that, Elmer). This stuff has caused serious trouble with snapping off during driving. Look at some back issues of Wooden Boat for coverage on this. Also search on the web to read about Brasses and Bronzes. Brass has no place at all in the marine environment, except as shiny stuff. Jim Donnelly Troller Fan Isle With the OPEN WIRELESS NODE at Powell River BC
