trawlers@lists.trawlering.com
TRAWLERS & TRAWLERING LIST
TWL: Twin screws, bad fuel
BH
Bart Hodge
Fri, Oct 4, 2002 2:20 PM
I have decided to sell my old Morgan OI 41 and switch to power. Friends with a single engine trawler, a Grand Banks, argue that twin engines are a headache and do not really provide the redundancy because most diesels quite due to bad fuel or clogged filters. They say both engines would die at the same time, anyway. It would seem to me that once one quit and there might still be a significant time lag until the second one quit. Maybe time enough to get the problem sorted out. I'm wondering if any of you twin-engine trawler people have had any experience with one engine continuing to run after the other had quit?
-BH
Do you Yahoo!?
New DSL Internet Access from SBC & Yahoo!
I have decided to sell my old Morgan OI 41 and switch to power. Friends with a single engine trawler, a Grand Banks, argue that twin engines are a headache and do not really provide the redundancy because most diesels quite due to bad fuel or clogged filters. They say both engines would die at the same time, anyway. It would seem to me that once one quit and there might still be a significant time lag until the second one quit. Maybe time enough to get the problem sorted out. I'm wondering if any of you twin-engine trawler people have had any experience with one engine continuing to run after the other had quit? -BH --------------------------------- Do you Yahoo!? New DSL Internet Access from SBC & Yahoo!
RS
Ridhard Sponholz
Fri, Oct 4, 2002 4:18 PM
Hi Bart,
I was cruising up the pacific coast on my 49 defever trawler when I lost
my port engine due water getting into the port tank through the
breathing tube.  I closed the port tank, and continued to run on my
starboard engine until I got safely into Coose Bay Oregon to fix the
port engine.  I was happy that I had 2 engines.  Another solution is to
have a single engine, longer range, and a homing device connected to
your genset.
Richard
-BH
Do you Yahoo!?
http://lists.samurai.com/mailman/listinfo/trawler-world-list
Hi Bart, I was cruising up the pacific coast on my 49 defever trawler when I lost my port engine due water getting into the port tank through the breathing tube. I closed the port tank, and continued to run on my starboard engine until I got safely into Coose Bay Oregon to fix the port engine. I was happy that I had 2 engines. Another solution is to have a single engine, longer range, and a homing device connected to your genset. Richard Bart Hodge wrote: >I have decided to sell my old Morgan OI 41 and switch to power. Friends with a single engine trawler, a Grand Banks, argue that twin engines are a headache and do not really provide the redundancy because most diesels quite due to bad fuel or clogged filters. They say both engines would die at the same time, anyway. It would seem to me that once one quit and there might still be a significant time lag until the second one quit. Maybe time enough to get the problem sorted out. I'm wondering if any of you twin-engine trawler people have had any experience with one engine continuing to run after the other had quit? > >-BH > > > >--------------------------------- >Do you Yahoo!? >New DSL Internet Access from SBC & Yahoo! >_______________________________________________ >http://lists.samurai.com/mailman/listinfo/trawler-world-list > > >
RS
Russ Sherwin
Fri, Oct 4, 2002 5:22 PM
We've covered this ground before, but in my opinion, the biggest threat in
stopping an engine is wrapping something around the prop. I believe with
fuel polishing and care I can prevent fuel problems from stopping the
engine. A twin provides redundancy both in engine and screws, but on the
other hand, a single has a much more protected prop to begin with. Oh, such
a dilemma. I opt for a single with a get-home and a separate (small) prop.
Russ
We've covered this ground before, but in my opinion, the biggest threat in stopping an engine is wrapping something around the prop. I believe with fuel polishing and care I can prevent fuel problems from stopping the engine. A twin provides redundancy both in engine and screws, but on the other hand, a single has a much more protected prop to begin with. Oh, such a dilemma. I opt for a single with a get-home and a separate (small) prop. Russ
PJ
Philip J. Rosch
Fri, Oct 4, 2002 7:58 PM
(SNIP) I'm wondering if any of you twin-engine trawler people have had
quit?
The positive side is when you work on one engine; you have the other
available so you can see how it goes together!
I've had my twins for 11 years. Occasionally one engine will overheat
due to clogged strainer, HEX failure etc, but never have I had both
engines quit.
The secret to avoiding bad fuel is only buy fuel where the local
commercial and sport fishermen buy their fuel and look at the condition
of the filters.  Vendors who screw the locals get drummed out of town
(or worse!)
                             Regards....
Phil Rosch
M/V "Curmudgeon" Marine Trader 44 TC
Currently Moored in Spa Creek, Annapolis, MD.
"Twenty years from now you will be more disappointed by the things you
didn't
do than by the ones you did do. So throw off the bowlines. Sail away
from
the safe harbor. Catch the trade winds in your sails. Explore. Dream.
Discover." - Mark Twain
(SNIP) I'm wondering if any of you twin-engine trawler people have had any experience with one engine continuing to run after the other had quit? The positive side is when you work on one engine; you have the other available so you can see how it goes together! I've had my twins for 11 years. Occasionally one engine will overheat due to clogged strainer, HEX failure etc, but never have I had both engines quit. The secret to avoiding bad fuel is only buy fuel where the local commercial and sport fishermen buy their fuel and look at the condition of the filters. Vendors who screw the locals get drummed out of town (or worse!) Regards.... Phil Rosch M/V "Curmudgeon" Marine Trader 44 TC Currently Moored in Spa Creek, Annapolis, MD. "Twenty years from now you will be more disappointed by the things you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover." - Mark Twain
RC
R C Smith Jr
Sat, Oct 5, 2002 2:36 PM
After going both ways (Krogen 42 single, Hatteras 58 twin), I do not think
numbers of engines should be a significant consideration in purchasing a
used trawler. There are good advantages either way and there are many more
important design features/personal preferences that should have highere
precedence. Buying new is different, but most of us buy used.
Regarding contaminated fuel with twins, I think pulling fuel for each engine
from different tanks is the obvious way to go.  I have 4 tanks allowing me
to keep using the prior fuel fill in one engine while testing the new fuel
in the other. Apparently, fuel does not spoil in my fiberglass tanks...knock
wood.
Bob
R C Smith Jr
M/V MARY KATHRYN (new name, ex-SUSAN MARIE)
Hatteras 58 LRC
Currently in Annapolis
After going both ways (Krogen 42 single, Hatteras 58 twin), I do not think numbers of engines should be a significant consideration in purchasing a used trawler. There are good advantages either way and there are many more important design features/personal preferences that should have highere precedence. Buying new is different, but most of us buy used. Regarding contaminated fuel with twins, I think pulling fuel for each engine from different tanks is the obvious way to go. I have 4 tanks allowing me to keep using the prior fuel fill in one engine while testing the new fuel in the other. Apparently, fuel does not spoil in my fiberglass tanks...knock wood. Bob ___________________ R C Smith Jr M/V MARY KATHRYN (new name, ex-SUSAN MARIE) Hatteras 58 LRC Currently in Annapolis
M
Michael
Sun, Oct 6, 2002 3:47 PM
Contrary to popular opinion among single engine owners, bad fuel is not the
only problem you can run in to.  I was gunkholeing up the Coos river when I
hit a log or rock I don't know which, and broke a prop.  I came in on the
other engine and put the boat in the slip without anyone knowing I had a
problem until I told them.  There is more to the propulsion system than fuel.
-BH
Michael Gibbons
http://www.seadreamer.net
40' Marine Trader
"Sea Dreamer"
Contrary to popular opinion among single engine owners, bad fuel is not the only problem you can run in to. I was gunkholeing up the Coos river when I hit a log or rock I don't know which, and broke a prop. I came in on the other engine and put the boat in the slip without anyone knowing I had a problem until I told them. There is more to the propulsion system than fuel. At 07:20 AM 10/4/2002 -0700, you wrote: >I have decided to sell my old Morgan OI 41 and switch to power. Friends >with a single engine trawler, a Grand Banks, argue that twin engines are a >headache and do not really provide the redundancy because most diesels >quite due to bad fuel or clogged filters. They say both engines would die >at the same time, anyway. It would seem to me that once one quit and there >might still be a significant time lag until the second one quit. Maybe >time enough to get the problem sorted out. I'm wondering if any of you >twin-engine trawler people have had any experience with one engine >continuing to run after the other had quit? > >-BH --|--|--|--|--|--|--|--|--|--|--|--|--|--|--|-- Michael Gibbons http://www.seadreamer.net 40' Marine Trader "Sea Dreamer" --|--|--|--|--|--|--|--|--|--|--|--|--|--|--|--
