View all threadsUSRPN210r4 with SBX
I am observing a strong spike at the center of the receive spectrum when I
start burst transmission.
My top flowgraph contains following two hierarchical blocks
When I run top flowgrpah (without transmitting anything) and observe the
FFT of the received signal the spectrum does not contain high spike in the
center.
But as soon as I start transmitting in burst mode I see a very high spike
in center of the received signal FFT spectrum. It looks like LO
(transmitter or receiver ) is being received? Which one is it ? And why is
it happening? How can I avoid it because it is affecting my packets.
When I apply the offset in digital using DDC/DUC, the spike moves out of
the band.
Bob
On 10/29/2014 01:54 PM, bob wole via USRP-users wrote:
USRPN210r4 with SBX
when I start burst transmission.
the FFT of the received signal the spectrum does not contain high
spike in the center.
spike in center of the received signal FFT spectrum. It looks like LO
why is it happening? How can I avoid it because it is affecting my
packets.
of the band.
Bob
USRP-users mailing list
USRP-users@lists.ettus.com
That spike in the middle is a consequence of using direct conversion in
both the RX and TX paths--it'll be there in both to some degree.
You can use offset-tuning to move the DC offset outside your passband:
http://files.ettus.com/manual/page_general.html
In built-for-a-particular-purpose radios, there will also be undesired
LO leakage and mixing products--those are generally dealt with using an
application/band-specific filter to eliminate them. For
general-purpose SDRs, that isn't possible to do "as manufactured", you
have to deal
with RF hygiene and plumbing issues yourself.
So, moving the LO leakage outside your passband is part of the
picture--use offset tuning for that. Then, if you have "this won't meet
our hygiene requirements", you have to look at filtering.
Another thing you really should do is to run the calibration utilities,
which will attempt to balance I/Q amplitude and phase, which can improve
some of these issues, but not, usually, eliminate them entirely.
Marcus Leech
Principal Investigator
Shirleys Bay Radio Astronomy Consortium
http://www.sbrac.org
