time-nuts@lists.febo.com
Where does 28V come from?
HM
Hal Murray
Tue, Jul 21, 2009 6:59 AM
That said, the modules also appear to be powered by 28VDC, add some
regulation, you could use the chassis to power the Thunderbolt, and
mount it in one of the blank panels.
Lead acid batteries are close to 2V per cell.  For cars/trucks, they come
conviently packaged in 6V and 12V units.  The phone company works off 48V.
But where does 28V come from?
The Isotemp OSCO 127-10 data sheet says 27 V, but that's +3, -6 or 21-30V
which straddles both 24V and 28V.
These are my opinions, not necessarily my employer's.  I hate spam.
> That said, the modules also appear to be powered by 28VDC, add some > regulation, you could use the chassis to power the Thunderbolt, and > mount it in one of the blank panels. Lead acid batteries are close to 2V per cell. For cars/trucks, they come conviently packaged in 6V and 12V units. The phone company works off 48V. But where does 28V come from? The Isotemp OSCO 127-10 data sheet says 27 V, but that's +3, -6 or 21-30V which straddles both 24V and 28V. -- These are my opinions, not necessarily my employer's. I hate spam.
MS
Majdi S. Abbas
Tue, Jul 21, 2009 7:11 AM
I'm not sure, but some ideas come to mind:
28V is a common supply voltage for some RF transistors, particularly
amplifiers.
28VDC is also common on aircraft -- including their battery strings.
That, or it's related the Phone Company (tm) -- while their strings
are at 48V, the buses are typically floated on rectifiers at 54-56V which
you could divide to around 28V easily.
Alternatively, maybe it's just easy to regulate down to 24, or
+/- 12V, accounting for voltage drop across the regulators.
--msa
On Mon, Jul 20, 2009 at 11:59:46PM -0700, Hal Murray wrote: > Lead acid batteries are close to 2V per cell. For cars/trucks, they come > conviently packaged in 6V and 12V units. The phone company works off 48V. > > But where does 28V come from? I'm not sure, but some ideas come to mind: 28V is a common supply voltage for some RF transistors, particularly amplifiers. 28VDC is also common on aircraft -- including their battery strings. That, or it's related the Phone Company (tm) -- while their strings are at 48V, the buses are typically floated on rectifiers at 54-56V which you could divide to around 28V easily. Alternatively, maybe it's just easy to regulate down to 24, or +/- 12V, accounting for voltage drop across the regulators. --msa
SR
Steve Rooke
Tue, Jul 21, 2009 7:15 AM
2009/7/21 Hal Murray hmurray@megapathdsl.net:
A nominal 24V lead-acid battery on charge will have a terminal voltage
of 27.6V (I believe) so perhaps this is where it comes from.
73,
Steve
Steve Rooke - ZL3TUV & G8KVD & JAKDTTNW
A man with one clock knows what time it is;
A man with two clocks is never quite sure.
2009/7/21 Hal Murray <hmurray@megapathdsl.net>: > >>       That said, the modules also appear to be powered by 28VDC, add some >> regulation, you could use the chassis to power the Thunderbolt, and >> mount it in one of the blank panels. > > Lead acid batteries are close to 2V per cell.  For cars/trucks, they come > conviently packaged in 6V and 12V units.  The phone company works off 48V. > > But where does 28V come from? A nominal 24V lead-acid battery on charge will have a terminal voltage of 27.6V (I believe) so perhaps this is where it comes from. 73, Steve > > The Isotemp OSCO 127-10 data sheet says 27 V, but that's +3, -6 or 21-30V > which straddles both 24V and 28V. > > > -- > These are my opinions, not necessarily my employer's.  I hate spam. > > > > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. > -- Steve Rooke - ZL3TUV & G8KVD & JAKDTTNW A man with one clock knows what time it is; A man with two clocks is never quite sure.
P
phil
Tue, Jul 21, 2009 7:17 AM
----- Original Message -----
To: "Discussion of precise time and frequency measurement"
time-nuts@febo.com
Sent: Tuesday, July 21, 2009 2:59 AM
Subject: [time-nuts] Where does 28V come from?
Hal,
Where did you find that Isotemp OSCO 127-10 data sheet ?
Any other data on that unit?
Phil
----- Original Message ----- From: "Hal Murray" <hmurray@megapathdsl.net> To: "Discussion of precise time and frequency measurement" <time-nuts@febo.com> Sent: Tuesday, July 21, 2009 2:59 AM Subject: [time-nuts] Where does 28V come from? > >> That said, the modules also appear to be powered by 28VDC, add some >> regulation, you could use the chassis to power the Thunderbolt, and >> mount it in one of the blank panels. > > Lead acid batteries are close to 2V per cell. For cars/trucks, they come > conviently packaged in 6V and 12V units. The phone company works off 48V. > > But where does 28V come from? > > The Isotemp OSCO 127-10 data sheet says 27 V, but that's +3, -6 or 21-30V > which straddles both 24V and 28V. Hal, Where did you find that Isotemp OSCO 127-10 data sheet ? Any other data on that unit? Phil
NM
Neville Michie
Tue, Jul 21, 2009 8:54 AM
In the early days of radios, there were A and B batteries. A were 2,
4 or 6 volt. B were 90 to 120 volts
in glass accumulators.
These were taken back to the radio shop to be recharged when flat.
This is where the 6.3 volt filament voltage for vacuum tubes came from,
the voltage of a 3 cell accumulator on discharge, the A battery.
When radios were to be used with motor generator sets, particularly
the military,
the standard was for 7 volts, the voltage on a 3 cell accumulator on
charge , and there as even a
series of 7 volt filament valves for military use.
As more power was required, particularly to power genemotors, battery
banks were
doubled and doubled to give 14 volts and then 28 volts. At this
stage with genemotors
any voltage could be made to order, and voltage was regulated with
carbon pile series regulators
at the 28 volt level. A genemotor with 28 volt input could produce
-150 V for bias and 250V
and  600V for seriously powered radio transmitters.
Aircraft also came into the picture, also with generator supported
accumulators.
Car radios used vibrators and transformers to transform 12v to 260
volts.
It was not until 1960 onwards that solid state power supplies began
to appear.
The telephone industry used higher voltages around 50 I think, from
accumulators
under charge.
So that is where these standard voltages came from.
Cheers, Neville Michie
nuts@febo.com>
they come
off 48V.
21-30V
Hal,
Phil
time-nuts
In the early days of radios, there were A and B batteries. A were 2, 4 or 6 volt. B were 90 to 120 volts in glass accumulators. These were taken back to the radio shop to be recharged when flat. This is where the 6.3 volt filament voltage for vacuum tubes came from, the voltage of a 3 cell accumulator on discharge, the A battery. When radios were to be used with motor generator sets, particularly the military, the standard was for 7 volts, the voltage on a 3 cell accumulator on charge , and there as even a series of 7 volt filament valves for military use. As more power was required, particularly to power genemotors, battery banks were doubled and doubled to give 14 volts and then 28 volts. At this stage with genemotors any voltage could be made to order, and voltage was regulated with carbon pile series regulators at the 28 volt level. A genemotor with 28 volt input could produce -150 V for bias and 250V and 600V for seriously powered radio transmitters. Aircraft also came into the picture, also with generator supported accumulators. Car radios used vibrators and transformers to transform 12v to 260 volts. It was not until 1960 onwards that solid state power supplies began to appear. The telephone industry used higher voltages around 50 I think, from accumulators under charge. So that is where these standard voltages came from. Cheers, Neville Michie On 21/07/2009, at 5:17 PM, phil wrote: > > ----- Original Message ----- From: "Hal Murray" > <hmurray@megapathdsl.net> > To: "Discussion of precise time and frequency measurement" <time- > nuts@febo.com> > Sent: Tuesday, July 21, 2009 2:59 AM > Subject: [time-nuts] Where does 28V come from? > > >> >>> That said, the modules also appear to be powered by 28VDC, add some >>> regulation, you could use the chassis to power the Thunderbolt, and >>> mount it in one of the blank panels. >> >> Lead acid batteries are close to 2V per cell. For cars/trucks, >> they come >> conviently packaged in 6V and 12V units. The phone company works >> off 48V. >> >> But where does 28V come from? >> >> The Isotemp OSCO 127-10 data sheet says 27 V, but that's +3, -6 or >> 21-30V >> which straddles both 24V and 28V. > > Hal, > Where did you find that Isotemp OSCO 127-10 data sheet ? > Any other data on that unit? > Phil > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/ > time-nuts > and follow the instructions there.
RP
Roy Phillips
Tue, Jul 21, 2009 11:04 AM
Hal
I think you will find that 28 volts DC is standard in many aviation and
military mobile equipment power requirements. It is the nominal battery
voltage that comes from two 12 volt cells in series that are fully charged.
The voltage to run such equipment is not critical (can be less than 28
volts), as you normally charge two series 12 volt cells at 27.6 volts - this
is indicative of the nominal voltage of such supplies. Trust that this is
the information you are looking for ?
Roy Phillips.
time-nuts@febo.com
Sent: Tuesday, July 21, 2009 7:59 AM
Hal I think you will find that 28 volts DC is standard in many aviation and military mobile equipment power requirements. It is the nominal battery voltage that comes from two 12 volt cells in series that are fully charged. The voltage to run such equipment is not critical (can be less than 28 volts), as you normally charge two series 12 volt cells at 27.6 volts - this is indicative of the nominal voltage of such supplies. Trust that this is the information you are looking for ? Roy Phillips. ----- Original Message ----- From: "Hal Murray" <hmurray@megapathdsl.net> To: "Discussion of precise time and frequency measurement" <time-nuts@febo.com> Sent: Tuesday, July 21, 2009 7:59 AM Subject: [time-nuts] Where does 28V come from? > >> That said, the modules also appear to be powered by 28VDC, add some >> regulation, you could use the chassis to power the Thunderbolt, and >> mount it in one of the blank panels. > > Lead acid batteries are close to 2V per cell. For cars/trucks, they come > conviently packaged in 6V and 12V units. The phone company works off 48V. > > But where does 28V come from? > > The Isotemp OSCO 127-10 data sheet says 27 V, but that's +3, -6 or 21-30V > which straddles both 24V and 28V. > > > -- > These are my opinions, not necessarily my employer's. I hate spam. > > > > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to > https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. >
CH
Chuck Harris
Tue, Jul 21, 2009 12:19 PM
28V is a nominal voltage, not an exact voltage.  It is derived from the
system voltage of a 24V battery that is being continuously charged.
The typical lead acid battery, as used in vehicles, wants to be charged at
a voltage that will quickly return it to full charge after the high starting
load has been removed.  That requires about 2.3V per cell, which leads to
28V nominal.  Your car works this way too, and if you measure the voltage
on your battery while the car is running, you will find your 12V is really
13.8 to 14.5V
-Chuck Harris
28V is a nominal voltage, not an exact voltage. It is derived from the system voltage of a 24V battery that is being continuously charged. The typical lead acid battery, as used in vehicles, wants to be charged at a voltage that will quickly return it to full charge after the high starting load has been removed. That requires about 2.3V per cell, which leads to 28V nominal. Your car works this way too, and if you measure the voltage on your battery while the car is running, you will find your 12V is really 13.8 to 14.5V -Chuck Harris Hal Murray wrote: >> That said, the modules also appear to be powered by 28VDC, add some >> regulation, you could use the chassis to power the Thunderbolt, and >> mount it in one of the blank panels. > > Lead acid batteries are close to 2V per cell. For cars/trucks, they come > conviently packaged in 6V and 12V units. The phone company works off 48V. > > But where does 28V come from? > > The Isotemp OSCO 127-10 data sheet says 27 V, but that's +3, -6 or 21-30V > which straddles both 24V and 28V. > >
N
n3izn@aol.com
Tue, Jul 21, 2009 2:25 PM
Most wireless sites will be 28 volts also. Some are switching to the telco standard of -48 which when measured is actually around -56 volts. One reason for going to a higher voltage is, you can use smaller conductors to get same amount of power out.
Not to steal the thread, but any one know why the telephone company choose to use a negative voltage? Where as the positive is referenced to ground? When I was a kid I was told it was because they discovered that the battery terminal would corrode if it was done that way?
Most wireless sites will be 28 volts also. Some are switching to the telco standard of -48 which when measured is actually around -56 volts. One reason for going to a higher voltage is, you can use smaller conductors to get same amount of power out. Not to steal the thread, but any one know why the telephone company choose to use a negative voltage? Where as the positive is referenced to ground? When I was a kid I was told it was because they discovered that the battery terminal would corrode if it was done that way?
RD
Robert Darlington
Tue, Jul 21, 2009 2:34 PM
Corrosion protection, similar to why the old MG cars ran on a positive
ground.
Corrosion protection, similar to why the old MG cars ran on a positive ground. On Tue, Jul 21, 2009 at 8:25 AM, <n3izn@aol.com> wrote: > Most wireless sites will be 28 volts also. Some are switching to the telco > standard of -48 which when measured is actually around -56 volts. One reason > for going to a higher voltage is, you can use smaller conductors to get same > amount of power out. > > Not to steal the thread, but any one know why the telephone company choose > to use a negative voltage? Where as the positive is referenced to ground? > When I was a kid I was told it was because they discovered that the battery > terminal would corrode if it was done that way? > > > > > > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to > https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. >
LO
Lamar Owen
Tue, Jul 21, 2009 2:38 PM
Negative 48 was chosen for several reasons, but the primary reason a negative potential was chosen was due to negative voltages causing less galvanic corrosion to outside plant; splices and copper wires outside corrode more quickly when at a positive potential relative to ground.
Lamar Owen
Chief Information Officer
Pisgah Astronomical Research Institute
1 PARI Drive
Rosman, NC 28772
828-862-5554
www.pari.edu
> n3izn@aol.com Wrote: > Not to steal the thread, but any one know why the telephone company choose to use a negative > voltage? Where as the positive is referenced to ground? When I was a kid I was told it was > because they discovered that the battery terminal would corrode if it was done that way? Negative 48 was chosen for several reasons, but the primary reason a negative potential was chosen was due to negative voltages causing less galvanic corrosion to outside plant; splices and copper wires outside corrode more quickly when at a positive potential relative to ground. -- Lamar Owen Chief Information Officer Pisgah Astronomical Research Institute 1 PARI Drive Rosman, NC 28772 828-862-5554 www.pari.edu _______________________________________________ time-nuts mailing list -- time-nuts@febo.com To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts and follow the instructions there.
JF
J. Forster
Tue, Jul 21, 2009 2:39 PM
The higher voltage is used to get a longer range for the subscriber loop
in the pre amplifier days w/o using heavier wire. Remember, there is LOT
of copper in a POTS netrork.
They probably studied the problem very thoroughly in the late 1800s,
trading off cost for safety (electrocution danger). There was no PVC or
Teflon, just wax and dry paper.
I seem to remember the positive ground was for corrosion protection.
-John
The higher voltage is used to get a longer range for the subscriber loop in the pre amplifier days w/o using heavier wire. Remember, there is LOT of copper in a POTS netrork. They probably studied the problem very thoroughly in the late 1800s, trading off cost for safety (electrocution danger). There was no PVC or Teflon, just wax and dry paper. I seem to remember the positive ground was for corrosion protection. -John ============= > Most wireless sites will be 28 volts also. Some are switching to the telco > standard of -48 which when measured is actually around -56 volts. One > reason for going to a higher voltage is, you can use smaller conductors to > get same amount of power out. > > Not to steal the thread, but any one know why the telephone company choose > to use a negative voltage? Where as the positive is referenced to ground? > When I was a kid I was told it was because they discovered that the > battery terminal would corrode if it was done that way? > > > > > > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to > https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. > >
M
mikes@flatsurface.com
Tue, Jul 21, 2009 2:46 PM
At 10:25 AM 7/21/2009, n3izn@aol.com wrote...
Using negative voltages on the lines (referenced to ground) reduces
corrosion, by making the conductor cathodic.
At 10:25 AM 7/21/2009, n3izn@aol.com wrote... >Not to steal the thread, but any one know why the telephone company >choose to use a negative voltage? Where as the positive is referenced >to ground? When I was a kid I was told it was because they discovered >that the battery terminal would corrode if it was done that way? Using negative voltages on the lines (referenced to ground) reduces corrosion, by making the conductor cathodic.
BC
Brooke Clarke
Tue, Jul 21, 2009 3:19 PM
Hi Hal:
Automotive electrical systems are said to be "12 Volts" (or "24 Volts" for
military vehicles).  That's the voltage of a six cell lead acid battery when
it's discharged.  It's fairly common to run down a car battery by say using a
ham radio while the car is parked.  The rated voltage of a rechargeable battery
is the discharged value.
But the same electrical system when installed in an aircraft is called a "14
Volt" system ("28 Volts" for military aircraft).  In aircraft the engine is
always running and the generator is always charging the battery.  You don't
park an airplane in the sky.
The 12/14 volt system can see a range of 10 to 15 Volts and the 24/28 volt
system will see a range of 20 to 30 Volts.
Have Fun,
Brooke Clarke
http://www.prc68.com
Hi Hal: Automotive electrical systems are said to be "12 Volts" (or "24 Volts" for military vehicles). That's the voltage of a six cell lead acid battery when it's discharged. It's fairly common to run down a car battery by say using a ham radio while the car is parked. The rated voltage of a rechargeable battery is the discharged value. But the same electrical system when installed in an aircraft is called a "14 Volt" system ("28 Volts" for military aircraft). In aircraft the engine is always running and the generator is always charging the battery. You don't park an airplane in the sky. The 12/14 volt system can see a range of 10 to 15 Volts and the 24/28 volt system will see a range of 20 to 30 Volts. Have Fun, Brooke Clarke http://www.prc68.com Hal Murray wrote: >> That said, the modules also appear to be powered by 28VDC, add some >> regulation, you could use the chassis to power the Thunderbolt, and >> mount it in one of the blank panels. > > Lead acid batteries are close to 2V per cell. For cars/trucks, they come > conviently packaged in 6V and 12V units. The phone company works off 48V. > > But where does 28V come from?
RP
Roy Phillips
Tue, Jul 21, 2009 3:42 PM
abcde
time-nuts@febo.com
Sent: Tuesday, July 21, 2009 12:04 PM
Subject: Re: [time-nuts] Where does 28V come from?
Hal
Roy Phillips.
time-nuts@febo.com
48V.
abcde ----- Original Message ----- From: "Roy Phillips" <phill.r1@btinternet.com> To: "Discussion of precise time and frequency measurement" <time-nuts@febo.com> Sent: Tuesday, July 21, 2009 12:04 PM Subject: Re: [time-nuts] Where does 28V come from? > Hal > I think you will find that 28 volts DC is standard in many aviation and > military mobile equipment power requirements. It is the nominal battery > voltage that comes from two 12 volt cells in series that are fully > charged. The voltage to run such equipment is not critical (can be less > than 28 volts), as you normally charge two series 12 volt cells at 27.6 > volts - this is indicative of the nominal voltage of such supplies. Trust > that this is the information you are looking for ? > Roy Phillips. > > ----- Original Message ----- > From: "Hal Murray" <hmurray@megapathdsl.net> > To: "Discussion of precise time and frequency measurement" > <time-nuts@febo.com> > Sent: Tuesday, July 21, 2009 7:59 AM > Subject: [time-nuts] Where does 28V come from? > > >> >>> That said, the modules also appear to be powered by 28VDC, add some >>> regulation, you could use the chassis to power the Thunderbolt, and >>> mount it in one of the blank panels. >> >> Lead acid batteries are close to 2V per cell. For cars/trucks, they come >> conviently packaged in 6V and 12V units. The phone company works off >> 48V. >> >> But where does 28V come from? >> >> The Isotemp OSCO 127-10 data sheet says 27 V, but that's +3, -6 or 21-30V >> which straddles both 24V and 28V. >> >> >> -- >> These are my opinions, not necessarily my employer's. I hate spam. >> >> >> >> >> _______________________________________________ >> time-nuts mailing list -- time-nuts@febo.com >> To unsubscribe, go to >> https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts >> and follow the instructions there. >> > > > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to > https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. >
DP
dave powis
Tue, Jul 21, 2009 4:21 PM
Phone companies work off a standard 48v (often referred to as 50v) for exchanges and 'in building' installations.  This includes mobile phone operators.  But a significant amount of equipment in the mobile network is not in the exchange sites - it is in the BTS (Base Transmitter System) cabinets, where 28v is used.  Henace a lot of ex-mobile phone co equipment, such the HP/Symmetricom Z380xx, Lucent RFTG's that were around, and power amplifiers used on 23 and 13cm amateur bands, is normally capable of being powered from either 28V or 48V supplies, since it could be deployed in either situation.
73,
Dave, G4HUP
To: Discussion of precise time and frequency measurement time-nuts@febo.com
Sent: Tuesday, 21 July, 2009 4:42:01 PM
abcde
----- Original Message ----- From: "Roy Phillips" phill.r1@btinternet.com
To: "Discussion of precise time and frequency measurement" time-nuts@febo.com
Hal
Roy Phillips.
----- Original Message ----- From: "Hal Murray" hmurray@megapathdsl.net
Phone companies work off a standard 48v (often referred to as 50v) for exchanges and 'in building' installations. This includes mobile phone operators. But a significant amount of equipment in the mobile network is not in the exchange sites - it is in the BTS (Base Transmitter System) cabinets, where 28v is used. Henace a lot of ex-mobile phone co equipment, such the HP/Symmetricom Z380xx, Lucent RFTG's that were around, and power amplifiers used on 23 and 13cm amateur bands, is normally capable of being powered from either 28V or 48V supplies, since it could be deployed in either situation. 73, Dave, G4HUP ________________________________ From: Roy Phillips <phill.r1@btinternet.com> To: Discussion of precise time and frequency measurement <time-nuts@febo.com> Sent: Tuesday, 21 July, 2009 4:42:01 PM Subject: Re: [time-nuts] Where does 28V come from? abcde ----- Original Message ----- From: "Roy Phillips" <phill.r1@btinternet.com> To: "Discussion of precise time and frequency measurement" <time-nuts@febo.com> Sent: Tuesday, July 21, 2009 12:04 PM Subject: Re: [time-nuts] Where does 28V come from? > Hal > I think you will find that 28 volts DC is standard in many aviation and military mobile equipment power requirements. It is the nominal battery voltage that comes from two 12 volt cells in series that are fully charged. The voltage to run such equipment is not critical (can be less than 28 volts), as you normally charge two series 12 volt cells at 27.6 volts - this is indicative of the nominal voltage of such supplies. Trust that this is the information you are looking for ? > Roy Phillips. > > ----- Original Message ----- From: "Hal Murray" <hmurray@megapathdsl.net> > To: "Discussion of precise time and frequency measurement" <time-nuts@febo.com> > Sent: Tuesday, July 21, 2009 7:59 AM > Subject: [time-nuts] Where does 28V come from? > > >> >>> That said, the modules also appear to be powered by 28VDC, add some >>> regulation, you could use the chassis to power the Thunderbolt, and >>> mount it in one of the blank panels. >> >> Lead acid batteries are close to 2V per cell. For cars/trucks, they come >> conviently packaged in 6V and 12V units. The phone company works off 48V. >> >> But where does 28V come from? >> >> The Isotemp OSCO 127-10 data sheet says 27 V, but that's +3, -6 or 21-30V >> which straddles both 24V and 28V. >> >> >> -- These are my opinions, not necessarily my employer's. I hate spam. >> >> >> >> >> _______________________________________________ >> time-nuts mailing list -- time-nuts@febo.com >> To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts >> and follow the instructions there. >> > > > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. > _______________________________________________ time-nuts mailing list -- time-nuts@febo.com To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts and follow the instructions there.
RA
Robert Atkinson
Tue, Jul 21, 2009 5:38 PM
Others have said it all, but see MIL-STD-704F < http://assist.daps.dla.mil/docimages/A/0000/0003/5901/000000433000_000000038767_BDJDANQSPS.PDF?CFID=32790482&CFTOKEN=123a955522c88712-9E5138E6-1372-548A-D3D5BB2597F5676D&jsessionid=0630a8f7f91d568172ed > or < http://assist.daps.dla.mil/quicksearch/basic_profile.cfm?ident_number=35901 > for specifications and MIL-HDBK-845 < http://assist.daps.dla.mil/docimages/A/0000/0011/0257/000000482523_000000172526_MROJWPALXS.PDF?CFID=32789554&CFTOKEN=578349968949c304-9E4997F9-1372-548A-D384056DE208ED29&jsessionid=0630a8f7f91d568172ed > or http://assist.daps.dla.mil/quicksearch/basic_profile.cfm?ident_number=110257 > for more info.
28V needs half the current for the same power. This results in lighter wires, switches etc. The newest standard for cars (Automobiles) is 42V bus with 36V (3x12V) battery standard, they are jumping 28/24V completely.
Robert G8RPI.
Date: Tuesday, 21 July, 2009, 7:59 AM
Thunderbolt, and
+3, -6 or 21-30V
I hate spam.
Others have said it all, but see MIL-STD-704F < http://assist.daps.dla.mil/docimages/A/0000/0003/5901/000000433000_000000038767_BDJDANQSPS.PDF?CFID=32790482&CFTOKEN=123a955522c88712-9E5138E6-1372-548A-D3D5BB2597F5676D&jsessionid=0630a8f7f91d568172ed > or < http://assist.daps.dla.mil/quicksearch/basic_profile.cfm?ident_number=35901 > for specifications and MIL-HDBK-845 < http://assist.daps.dla.mil/docimages/A/0000/0011/0257/000000482523_000000172526_MROJWPALXS.PDF?CFID=32789554&CFTOKEN=578349968949c304-9E4997F9-1372-548A-D384056DE208ED29&jsessionid=0630a8f7f91d568172ed > or http://assist.daps.dla.mil/quicksearch/basic_profile.cfm?ident_number=110257 > for more info. 28V needs half the current for the same power. This results in lighter wires, switches etc. The newest standard for cars (Automobiles) is 42V bus with 36V (3x12V) battery standard, they are jumping 28/24V completely. Robert G8RPI. --- On Tue, 21/7/09, Hal Murray <hmurray@megapathdsl.net> wrote: > From: Hal Murray <hmurray@megapathdsl.net> > Subject: [time-nuts] Where does 28V come from? > To: "Discussion of precise time and frequency measurement" <time-nuts@febo.com> > Date: Tuesday, 21 July, 2009, 7:59 AM > > >     That said, the modules also appear > to be powered by 28VDC, add some > > regulation, you could use the chassis to power the > Thunderbolt, and > > mount it in one of the blank panels. > > Lead acid batteries are close to 2V per cell.  For > cars/trucks, they come > conviently packaged in 6V and 12V units.  The phone > company works off 48V. > > But where does 28V come from? > > The Isotemp OSCO 127-10 data sheet says 27 V, but that's > +3, -6 or 21-30V > which straddles both 24V and 28V. > > > -- > These are my opinions, not necessarily my employer's.  > I hate spam. > > > > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. >
PK
Poul-Henning Kamp
Tue, Jul 21, 2009 5:45 PM
In message 768062.16062.qm@web27101.mail.ukl.yahoo.com, Robert Atkinson write
s:
That one has run into all sorts of trouble.
It was sort of predicated on people with microwave ovens and
dishwashers in their hummers and that entire market has more or
less evaporated.
42V was chosen over 56V because the latter is "high voltage" according
to various countries codes.
Poul-Henning
Poul-Henning Kamp      | UNIX since Zilog Zeus 3.20
phk@FreeBSD.ORG        | TCP/IP since RFC 956
FreeBSD committer      | BSD since 4.3-tahoe
Never attribute to malice what can adequately be explained by incompetence.
In message <768062.16062.qm@web27101.mail.ukl.yahoo.com>, Robert Atkinson write s: >The newest standard for cars (Automobiles) is 42V bus with > 36V (3x12V) battery standard, they are jumping 28/24V completely. That one has run into all sorts of trouble. It was sort of predicated on people with microwave ovens and dishwashers in their hummers and that entire market has more or less evaporated. 42V was chosen over 56V because the latter is "high voltage" according to various countries codes. Poul-Henning -- Poul-Henning Kamp | UNIX since Zilog Zeus 3.20 phk@FreeBSD.ORG | TCP/IP since RFC 956 FreeBSD committer | BSD since 4.3-tahoe Never attribute to malice what can adequately be explained by incompetence.
LJ
Lux, James P (337C)
Tue, Jul 21, 2009 6:30 PM
-----Original Message-----
From: time-nuts-bounces@febo.com [mailto:time-nuts-bounces@febo.com] On Behalf Of Poul-Henning Kamp
Sent: Tuesday, July 21, 2009 10:45 AM
s:
less evaporated.
Higher voltages are being driven by a couple factors, independent of dishwasher installation..
There is a desire to reduce the wiring harness mass and cost.  Higher voltages let you use smaller wires, so you spend less money on copper and insulation.
For things like electric motor driven power steering and airconditioning, higher voltages are better (smaller wires, lower mass, better efficiency) and would allow doing away with hydraulic pumps and belt driven compressors.  Wires are a lot easier to move around than belts and pulleys, so that makes internal layout easier for the styling folks.
There is a also a desire to do point of load switching (which also reduces mass.. fewer wires). Historically, there was a problem getting semiconductor switches with appropriate parameters to do high side switching. A Vds-on of 1 Volt is awfully big in the context of a 12V device (that might actually be running at 9V during cranking).  It's less of a problem in the context of a 50V bus.
Working against this is that semiconductors sort of start at about 60V ratings. A 42 volt bus (still being a multiple of 6, for historical reasons.. darn those Babylonians) gives you 18V margin against the 60V.  (especially if you consider that 14.4V is the actual max voltage for a 12V system...  42=50.4V)
And then there's the 50V threshold for "low voltage systems" that Poul mentions.
I think the latter is starting to be less important, as more hybrid cars have high voltage battery packs show up in the field and we haven't seen dozens of firefighters electrocuted by inadvertently cutting the wires, or shop technicians dying by putting a screwdriver where they shouldn't.
You're still stuck in the cost trade between higher voltage semiconductors and lower copper and actuator costs with higher voltages, and even more, between the cost of things like transient suppression.
I'll note that spacecraft have been going to higher voltage buses for this kind of reason (except for science spacecraft, which tend to stick with the venerable 28V avionics power, since it's familiar, and there tends to be a lot of scrounging of surplus and reuse of proven designs).  ISS uses, I think, 100V DC as the bus, and commercial comsats use bus voltages of 70-90V.
-----Original Message----- From: time-nuts-bounces@febo.com [mailto:time-nuts-bounces@febo.com] On Behalf Of Poul-Henning Kamp Sent: Tuesday, July 21, 2009 10:45 AM To: Discussion of precise time and frequency measurement Subject: Re: [time-nuts] Where does 28V come from? In message <768062.16062.qm@web27101.mail.ukl.yahoo.com>, Robert Atkinson write s: >The newest standard for cars (Automobiles) is 42V bus with > 36V (3x12V) battery standard, they are jumping 28/24V completely. That one has run into all sorts of trouble. It was sort of predicated on people with microwave ovens and dishwashers in their hummers and that entire market has more or less evaporated. 42V was chosen over 56V because the latter is "high voltage" according to various countries codes. ---------------------------------------------- Higher voltages are being driven by a couple factors, independent of dishwasher installation.. There is a desire to reduce the wiring harness mass and cost. Higher voltages let you use smaller wires, so you spend less money on copper and insulation. For things like electric motor driven power steering and airconditioning, higher voltages are better (smaller wires, lower mass, better efficiency) and would allow doing away with hydraulic pumps and belt driven compressors. Wires are a lot easier to move around than belts and pulleys, so that makes internal layout easier for the styling folks. There is a also a desire to do point of load switching (which also reduces mass.. fewer wires). Historically, there was a problem getting semiconductor switches with appropriate parameters to do high side switching. A Vds-on of 1 Volt is awfully big in the context of a 12V device (that might actually be running at 9V during cranking). It's less of a problem in the context of a 50V bus. Working against this is that semiconductors sort of start at about 60V ratings. A 42 volt bus (still being a multiple of 6, for historical reasons.. darn those Babylonians) gives you 18V margin against the 60V. (especially if you consider that 14.4V is the actual max voltage for a 12V system... 42=50.4V) And then there's the 50V threshold for "low voltage systems" that Poul mentions. I think the latter is starting to be less important, as more hybrid cars have high voltage battery packs show up in the field and we haven't seen dozens of firefighters electrocuted by inadvertently cutting the wires, or shop technicians dying by putting a screwdriver where they shouldn't. You're still stuck in the cost trade between higher voltage semiconductors and lower copper and actuator costs with higher voltages, and even more, between the cost of things like transient suppression. I'll note that spacecraft have been going to higher voltage buses for this kind of reason (except for science spacecraft, which tend to stick with the venerable 28V avionics power, since it's familiar, and there tends to be a lot of scrounging of surplus and reuse of proven designs). ISS uses, I think, 100V DC as the bus, and commercial comsats use bus voltages of 70-90V.
PK
Poul-Henning Kamp
Tue, Jul 21, 2009 6:37 PM
In message <ECE7A93BD093E1439C20020FBE87C47FEB749828B8@ALTPHYEMBEVSP20.RES.AD.J
PL>, "Lux, James P (337C)" writes:
True, but the car industrys plan was the that dishwasher-in-hummer
segment was going to pay the development costs, making "42V electrical"
a "high-end-feature", thus making people desire it in lower grade
cars, rather than having to actually stuff it down peoples throats.
Right now, 42V car are "D.E.A.D" according to my sources in the
autoindustry, partly, as you point out, in light of the hybrid/electric
market expected to explode, but mostly, because nobody has the money
to develop and push the new standard.
Poul-Henning
In message <ECE7A93BD093E1439C20020FBE87C47FEB749828B8@ALTPHYEMBEVSP20.RES.AD.J PL>, "Lux, James P (337C)" writes: >Higher voltages are being driven by a couple factors, independent >of dishwasher installation.. > >There is a desire to reduce the wiring harness mass and cost. >Higher voltages let you use smaller wires, so you spend less money >on copper and insulation. True, but the car industrys plan was the that dishwasher-in-hummer segment was going to pay the development costs, making "42V electrical" a "high-end-feature", thus making people desire it in lower grade cars, rather than having to actually stuff it down peoples throats. Right now, 42V car are "D.E.A.D" according to my sources in the autoindustry, partly, as you point out, in light of the hybrid/electric market expected to explode, but mostly, because nobody has the money to develop and push the new standard. Poul-Henning -- Poul-Henning Kamp | UNIX since Zilog Zeus 3.20 phk@FreeBSD.ORG | TCP/IP since RFC 956 FreeBSD committer | BSD since 4.3-tahoe Never attribute to malice what can adequately be explained by incompetence.
MD
Magnus Danielson
Tue, Jul 21, 2009 8:35 PM
Dave,
In all environments I encounter it, it is called 48V and not 50V. There
also exists a -60 VDC standard. For Europe, it is standardized as ETSI
EN 300 132-2. For US Bellcore (now Telecordia) wrote it into it's NEBS
series, but I can't recall the number from the top of my head.
The ETSI variant is online, so fetch that.
The ETSI people have created another interesting spec, the EN 300 132-3
which is for a 400 VDC system. It avoids the step of DC-AC conversion in
UPS systems since most supplies rectifies it anyway. Check it out. :)
Cheers,
Magnus
Dave, dave powis wrote: > Phone companies work off a standard 48v (often referred to as 50v) for exchanges and 'in building' installations. This includes mobile phone operators. But a significant amount of equipment in the mobile network is not in the exchange sites - it is in the BTS (Base Transmitter System) cabinets, where 28v is used. Henace a lot of ex-mobile phone co equipment, such the HP/Symmetricom Z380xx, Lucent RFTG's that were around, and power amplifiers used on 23 and 13cm amateur bands, is normally capable of being powered from either 28V or 48V supplies, since it could be deployed in either situation. In all environments I encounter it, it is called 48V and not 50V. There also exists a -60 VDC standard. For Europe, it is standardized as ETSI EN 300 132-2. For US Bellcore (now Telecordia) wrote it into it's NEBS series, but I can't recall the number from the top of my head. The ETSI variant is online, so fetch that. The ETSI people have created another interesting spec, the EN 300 132-3 which is for a 400 VDC system. It avoids the step of DC-AC conversion in UPS systems since most supplies rectifies it anyway. Check it out. :) Cheers, Magnus
