trawlers@lists.trawlering.com
TRAWLERS & TRAWLERING LIST
TWL: Sliding Window Frames
JM
j.morson@worldnet.att.net
Thu, Mar 15, 2001 10:43 AM
Garrett:
I can give you a partial answer, but I'm not sure of the correct procedure.
If you look closely at the top window frame you'll see that it is 2-piece. The "top channel with the felt" fits inside
the main window frame. My local glass shop replaced my side windows.  I think they opened the sliding window
the whole way and then starting at the opposite end, pried the top channel down along the whole length. From
that point I think they pulled the channel out  horizontally.
Jerry & Shary Morson
m/v Slow Ride
President 41
Garrett: I can give you a partial answer, but I'm not sure of the correct procedure. If you look closely at the top window frame you'll see that it is 2-piece. The "top channel with the felt" fits inside the main window frame. My local glass shop replaced my side windows. I think they opened the sliding window the whole way and then starting at the opposite end, pried the top channel down along the whole length. From that point I think they pulled the channel out horizontally. Jerry & Shary Morson m/v Slow Ride President 41
