time-nuts@lists.febo.com
Re: [time-nuts] 1" 14 tpi UNS die
RA
Robert Atkinson
Tue, Jul 7, 2009 8:13 PM
Hi Dave,
I was curious that BSP did not fit. I just grabbed some hardware to try. A 3/4 BSP blank just fitted a Trimble pallisade but not the female end of a Shakespeare short mast. The trimble spec says 1-14TPI or 3/4NPT. It is looser on the shakespeare thread (1-14). I guess it has a thread cut for either and your antenna it 1-14 only. A 3/4-BSPT might fit but a marine mount might be best. I whish I still had access to the CNC lathe at my last employers. It would only take a few minutes to knock some up from 30mm hex bar!
--- On Tue, 7/7/09, David C. Partridge david.partridge@dsl.pipex.com wrote:
From: David C. Partridge david.partridge@dsl.pipex.com
Subject: Re: [time-nuts] 1" 14 tpi UNS die
To: "'Discussion of precise time and frequency measurement'" time-nuts@febo.com
Date: Tuesday, 7 July, 2009, 7:10 PM
As it would appear to an expensive
option to purchase the appropriate dies
"over here", and as the pipe is soft alloy, I've just
reduced its diameter a
bit so it's an tight push fit in the antenna base (for now)
  • though still
    hoping to find a good solution with spending lots of dosh!
Thanks to all
Dave
-----Original Message-----
[mailto:time-nuts-bounces@febo.com]
On
Behalf Of GandalfG8@aol.com
Sent: 07 July 2009 18:54
To: time-nuts@febo.com
In a message dated 07/07/2009 18:43:55 GMT Daylight Time,
Arnold.Tibus@gmx.de
writes:
I have  the same problem with several GPS antennas, a
Quadrifilar from
Raytheon, Irvine 2640NW with mounting base, HP 58532A with
mounting base, HP
58504Ac. etc. Some complete boxes from HP do contain an
adapter.
So this  thread is definitively a kind of standard.
The thread is fully
cylindrical,  all the plumbers tubes do use conical
threads which are not
compatible.  Very difficult to find proper solution in
the metrical Europe.
If I would  find a source of that HP-adapters I would
buy 4 units.
I did not check for  the correct naming of this thread
though.
As commented previously, this is a common fitting and
fairly standard  for
GPS antennas and some other antenna kit, especially in a
marine
environment.
A variety of adaptors is available from marine suppliers
ranging from
expensive stainless steel fittings to much cheaper plastic,
they are also
regularly listed on Ebay.
However, there doesn't seem to be anything readilly
available  which has a
collar to sit over a plain pipe, which I suspect
might  meet David's needs.
They are widely available with a flange fitting, for
mounting to flat
surfaces, or rail fittings to attach to horizontal deck
rails, but perhaps a
trawl through some of the marine suppliers might throw up
something else
that could do the job without the need for threading the
end of the pipe.
regards
Nigel
GM8PZR
To unsubscribe, go to
Hi Dave, I was curious that BSP did not fit. I just grabbed some hardware to try. A 3/4 BSP blank just fitted a Trimble pallisade but not the female end of a Shakespeare short mast. The trimble spec says 1-14TPI or 3/4NPT. It is looser on the shakespeare thread (1-14). I guess it has a thread cut for either and your antenna it 1-14 only. A 3/4-BSPT might fit but a marine mount might be best. I whish I still had access to the CNC lathe at my last employers. It would only take a few minutes to knock some up from 30mm hex bar! --- On Tue, 7/7/09, David C. Partridge <david.partridge@dsl.pipex.com> wrote: > From: David C. Partridge <david.partridge@dsl.pipex.com> > Subject: Re: [time-nuts] 1" 14 tpi UNS die > To: "'Discussion of precise time and frequency measurement'" <time-nuts@febo.com> > Date: Tuesday, 7 July, 2009, 7:10 PM > As it would appear to an expensive > option to purchase the appropriate dies > "over here", and as the pipe is soft alloy, I've just > reduced its diameter a > bit so it's an tight push fit in the antenna base (for now) > - though still > hoping to find a good solution with spending lots of dosh! > > Thanks to all > Dave > > -----Original Message----- > From: time-nuts-bounces@febo.com > [mailto:time-nuts-bounces@febo.com] > On > Behalf Of GandalfG8@aol.com > Sent: 07 July 2009 18:54 > To: time-nuts@febo.com > Subject: Re: [time-nuts] 1" 14 tpi UNS die > > > In a message dated 07/07/2009 18:43:55 GMT Daylight Time, > Arnold.Tibus@gmx.de > writes: > > I have  the same problem with several GPS antennas, a > Quadrifilar from > Raytheon, Irvine 2640NW with mounting base, HP 58532A with > mounting base, HP > 58504Ac. etc. Some complete boxes from HP do contain an > adapter. > So this  thread is definitively a kind of standard. > The thread is fully > cylindrical,  all the plumbers tubes do use conical > threads which are not > compatible.  Very difficult to find proper solution in > the metrical Europe. > If I would  find a source of that HP-adapters I would > buy 4 units. > I did not check for  the correct naming of this thread > though. > > > --------------- > As commented previously, this is a common fitting and > fairly standard  for > GPS antennas and some other antenna kit, especially in a > marine > environment. > > A variety of adaptors is available from marine suppliers > ranging from > expensive stainless steel fittings to much cheaper plastic, > they are also > regularly listed on Ebay. > > However, there doesn't seem to be anything readilly > available  which has a > collar to sit over a plain pipe, which I suspect > might  meet David's needs. > They are widely available with a flange fitting, for > mounting to flat > surfaces, or rail fittings to attach to horizontal deck > rails, but perhaps a > trawl through some of the marine suppliers might throw up > something else > that could do the job without the need for threading the > end of the pipe. > > regards > > Nigel > GM8PZR > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to > https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. > > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. >
