In a message dated 9/10/2007 6:16:29 PM Eastern Daylight Time,
keith.kmcgregor@gmail.com writes:
The polyester thread deteriorates much sooner than the
Sunbrella itself. Your best bet is to specify Tenara thread when you
replace your bimini and/or windows. This alone will add significant
longevity to the life of the top.
I bought a sailmakers sewing machine from Sailrite a few years ago. The
thread on a Sunbrella cover that went around the railing on rear of flybridge area
had begun to wear allowing some of the seams to come loose. It was a fairly
simple job; just resew the seams. I think the quote from an upholstery shop
was $125. I decided to put that money towards the purchase of a heavy duty
sewing machine and it was well worth the price. I've done a lot of other work
that has saved me $$$. So, if you do this job yourself and don't want to invest
in the very expensive thread ($139 for an 8 ounce roll), just sew over the
seam with the polyester thread (see info about polyester thread below).
Reid Gantt
Atlantic 30 Vouivre
docked at Sneads Ferry NC
Bonded Dabond (polyester) thread has set an industry standard because of its
high strength and controlled stretch, its stability in sunlight and its
resistance to needle heat, abrasion, salt-water and mildew.
See what's new at http://www.aol.com
