trawlers@lists.trawlering.com
TRAWLERS & TRAWLERING LIST
TWL: update
R
russ@technicalmarketing.com
Wed, Dec 13, 2000 4:23 PM
For all concerned, Donna's surgery yesterday went fine, she will be
coming home today, and thanks to all of you for your kind thoughts. Now
she wants to go boating!
By the way, we had an interesting problem with the nordhavn that seems
to be solved now, but is still puzzling: Coming back from Long Beach
trawler fest, the engine started surging after 2-1/2 hours of running on
the starboard tank, and eventually died, showing high vacuum on the
Racor gauge. Switching filters did nothing. Switching to the port tank
solved it. Over the next several weeks, the same thing happened six more
times; after 2-3 hours of running, vacuum would start to build from near
0 to 1, then 2 then 5 then 10, 15, (in of hg) and after about 20
minutes, the engine would die. It wasn't a hard blockage, because
switching off the tank feed causes the vacuum to reach that level in
less than a minute. Each time, the only cure was switching to the other
tank. Sounds like vents, doesn't it? we checked the vents, replaced all
hoses, changed filters, etc., still had the problem after 2-3 hours of
running. All the PAE techs, and even Jim Leishman himself took a crack
at the problem with no success. Finally replaced the entire dual racor
filter assembly, since it was the last thing in the fuel system
remaining untouched, and the problem seems to have gone away, though
dissection of the old filter assembly revealed nothing. We are
mystified. By the way, these are bottom feed tanks, not dip tube feed.
Russ
For all concerned, Donna's surgery yesterday went fine, she will be coming home today, and thanks to all of you for your kind thoughts. Now she wants to go boating! By the way, we had an interesting problem with the nordhavn that seems to be solved now, but is still puzzling: Coming back from Long Beach trawler fest, the engine started surging after 2-1/2 hours of running on the starboard tank, and eventually died, showing high vacuum on the Racor gauge. Switching filters did nothing. Switching to the port tank solved it. Over the next several weeks, the same thing happened six more times; after 2-3 hours of running, vacuum would start to build from near 0 to 1, then 2 then 5 then 10, 15, (in of hg) and after about 20 minutes, the engine would die. It wasn't a hard blockage, because switching off the tank feed causes the vacuum to reach that level in less than a minute. Each time, the only cure was switching to the other tank. Sounds like vents, doesn't it? we checked the vents, replaced all hoses, changed filters, etc., still had the problem after 2-3 hours of running. All the PAE techs, and even Jim Leishman himself took a crack at the problem with no success. Finally replaced the entire dual racor filter assembly, since it was the last thing in the fuel system remaining untouched, and the problem seems to have gone away, though dissection of the old filter assembly revealed nothing. We are mystified. By the way, these are bottom feed tanks, not dip tube feed. Russ
B
barnacle42@ameritech.net
Wed, Dec 13, 2000 4:42 PM
Russ,
A couple of weeks ago there was a post about Racor twin filter having a
problem with the isolation valve.If you have the isolation valve, check to
see if the internal nipple is actually switching from one filter to the
other. Some filter valves break internally and dont actually switch. Steve
Russ, A couple of weeks ago there was a post about Racor twin filter having a problem with the isolation valve.If you have the isolation valve, check to see if the internal nipple is actually switching from one filter to the other. Some filter valves break internally and dont actually switch. Steve
