time-nuts@lists.febo.com
Re: [time-nuts] ES-911/GPS/NTP DIP Switch Settings
GB
Gregory Beat
Wed, Nov 27, 2019 6:35 PM
Fred -
The ES-911/GPS/NTP is a “Swiss Army Knife” for the 911 centers.
Don’t forget the Network Time Protocol function (software setup).
Mark Sims covered the battery replacements in his November 3, 2019 posting, here on time-nuts.  ML-621 rechargeable lithium coin cell used on the Motorola M12+TIMING (MN:P273T12T17) receiver.  Choose same solder tab configuration.
https://www.digikey.com/products/en/battery-products/batteries-rechargeable-secondary/91?k=ml-621
The 6 Volt, 1.3 Ah battery is available from DigiKey (~$12.84).
https://www.digikey.com/product-detail/en/panasonic-bsg/LC-R061R3P/P128-ND/6671
The current models have a BR2330 lithium coin cell (in battery holder), as well.
https://www.digikey.com/product-detail/en/panasonic-bsg/BR-2330/P187-ND/31927
You can download the Manual for the Current ESE ES-911/GPS/NTP Model,
which also has Two DIP Switches for Configurations.
https://www.ese-web.com/911gn.htm
You can also download the ESE Master Clock software (MASTER32.EXE)
from their web site.
BANK / DIP 1
Switch : Function (if switch is “ON”)
1 - Auto Daylight Saving
2 - Format #0 TZ Reverse
3 - HR relay option 00:00 & 30:00 mode
4 - IRIG-B Signature Control
5 - IRIG-E Signature Control
6 - Baud Rate (see manual) 9600 baud, OFF
7 - Baud Rate (see manual) 9600 baud, OFF
8 - ASCII Format (see manual) OFF is 0.
BANK / DIP 2 (switches 3-8 are Time Zone Offset)
1 - ASCII Format (see manual), OFF is 0.
2 - 12 hour format display
3 - + offset
4 - 1/2 hour
5 - 1 hour
6 - 2 hour
7 - 4 hour
8 - 8 hour
In Addition, the Manual has the Pin Assignments for the Rear Panel D-subminiatureconnectors.
g. beat
w9gb
Date: Tue, 26 Nov 2019 20:16:32 -0800
To: time-nuts@lists.febo.com
Subject: [time-nuts] ES-911/GPS/NTP DIP Switch Settings
Thanks for all the useful information posted about this unit.
Since my earlier post, it appears that the Jackson Labs replacement receiver is
working and I now have a readable display on the E-911.
I'm sending an e-mail to ESE with the serial number of my ES-911 unit requesting the manual. However, could someone who already has documentation please pass along the DIP switch settings??
I have found that the right bank seems to determine the offset from UTC.
I think that by trial and error, I've found the settings for my time zone and I even
discovered the 30 minute offset feature.
However, the front panel display differs by 5 minutes from the on-board display on the Jackson Labs receiver.
I'm trying to figure out the source of this difference.
It appears that the change in the seconds display is in visual sync with the PPS led on the Jackson board.
Thanks in advance.
KE6CD
Fred - The ES-911/GPS/NTP is a “Swiss Army Knife” for the 911 centers. Don’t forget the Network Time Protocol function (software setup). Mark Sims covered the battery replacements in his November 3, 2019 posting, here on time-nuts. ML-621 rechargeable lithium coin cell used on the Motorola M12+TIMING (MN:P273T12T17) receiver. Choose same solder tab configuration. https://www.digikey.com/products/en/battery-products/batteries-rechargeable-secondary/91?k=ml-621 The 6 Volt, 1.3 Ah battery is available from DigiKey (~$12.84). https://www.digikey.com/product-detail/en/panasonic-bsg/LC-R061R3P/P128-ND/6671 The current models have a BR2330 lithium coin cell (in battery holder), as well. https://www.digikey.com/product-detail/en/panasonic-bsg/BR-2330/P187-ND/31927 You can download the Manual for the Current ESE ES-911/GPS/NTP Model, which also has Two DIP Switches for Configurations. https://www.ese-web.com/911gn.htm You can also download the ESE Master Clock software (MASTER32.EXE) from their web site. — BANK / DIP 1 Switch : Function (if switch is “ON”) 1 - Auto Daylight Saving 2 - Format #0 TZ Reverse 3 - HR relay option 00:00 & 30:00 mode 4 - IRIG-B Signature Control 5 - IRIG-E Signature Control 6 - Baud Rate (see manual) 9600 baud, OFF 7 - Baud Rate (see manual) 9600 baud, OFF 8 - ASCII Format (see manual) OFF is 0. BANK / DIP 2 (switches 3-8 are Time Zone Offset) Switch : Function (if switch is “ON”) 1 - ASCII Format (see manual), OFF is 0. 2 - 12 hour format display 3 - + offset 4 - 1/2 hour 5 - 1 hour 6 - 2 hour 7 - 4 hour 8 - 8 hour == In Addition, the Manual has the Pin Assignments for the Rear Panel D-subminiatureconnectors. g. beat w9gb ==== Date: Tue, 26 Nov 2019 20:16:32 -0800 From: Frederick Bray <fwbray@mminternet.com> To: time-nuts@lists.febo.com Subject: [time-nuts] ES-911/GPS/NTP DIP Switch Settings Thanks for all the useful information posted about this unit. Since my earlier post, it appears that the Jackson Labs replacement receiver is working and I now have a readable display on the E-911. I'm sending an e-mail to ESE with the serial number of my ES-911 unit requesting the manual. However, could someone who already has documentation please pass along the DIP switch settings?? I have found that the right bank seems to determine the offset from UTC. I think that by trial and error, I've found the settings for my time zone and I even discovered the 30 minute offset feature. However, the front panel display differs by 5 minutes from the on-board display on the Jackson Labs receiver. I'm trying to figure out the source of this difference. It appears that the change in the seconds display is in visual sync with the PPS led on the Jackson board. Thanks in advance. KE6CD
