View all threadsIs the FPGA code for mimo cable support available? Is that also on the
packet_router branch (you mention only the host code below)? If not, how
can I access it?
Yes available. usrp2_txrx_uhd.bin is the FW image and packet_router.bin FPGA
image. You can burn these images directly to the sd card(for usrp2).
The images are here;
http://www.ettus.com/downloads/uhd_images/experimental/UHD-mimo-cable-support/
Also, are there example host programs that exercise this code?
Not yet.
felibol
On 12/13/2010 7:34 PM, Josh Blum wrote:
Hello list,
I would like to announce support for the MIMO cable with UHD. The
support is experimental, so its not in the mainline yet, and is only
available for USRP2 at the moment.
The source for the FPGA code has not yet been pushed but you can get the
pre-built images here:
The supporting host code is available on the packet_router branch of the
uhd repo:
http://code.ettus.com/redmine/ettus/projects/uhd/repository/show?rev=packet_router
r
Here is an excerpt from the docs on the MIMO cable in UHD:
MIMO cable configuration
Using the MIMO cable, two USRP devices can be grouped together in a
multi-device configuration.
Only one device in the configuration can be attached to the ethernet.
This device will be referred to as the master, and the other device, the
slave.
I hope that explains it. Feedback is welcome!
Thanks,
-Josh
USRP-users mailing list
USRP-users@lists.ettus.com
I am looking for the verilog source, since I need to modify it, not just
the binaries. Thanks.
how
can I access it?
packet_router.bin FPGA image. You can burn these images directly to
Not yet.
felibol
Hello list,
uhd repo:
device, the slave.
the slave.
the MIMO cable.
the same subnet.
Thanks,
-Josh
USRP-users@lists.ettus.com mailto:USRP-users@lists.ettus.com
Its not uploaded yet. I was about to upload it tonight and then
everything imploded. I will make an announcement when its available.
-Josh
By "everything imploded", do you mean that the code does not
compile/work correctly? If it does compile and work correctly, would you
be able to provide a copy even if it is not mature/fully cleaned up?
I would really appreciate your help if it's possible. I know it is the
holiday season, so apologies for troubling you - just wanted to see if I
could get code that I could work with over the break.
Thanks,
Arun
-Josh
Work on the MIMO cable support is continuing on the "next" branch of the
uhd repository.
http://code.ettus.com/redmine/ettus/projects/uhd/repository/show?rev=next
All relevant fpga code can be found on the next branch in the fpga
directory.
The accompanying pre-built images for this branch can be found here:
Feedback is welcome,
-josh
can I access it?
Not yet.
felibol
Hello list,
uhd repo:
r
slave.
Thanks,
-Josh
Hi,
Can you please make the next branch available for the http GIT repo?
Thanks.
Thomas
uhd repository.
directory.
-josh
homepage (priv.): http://www.hobiger.org
Thank you.
uhd repository.
directory.
-josh
can I access it?
Not yet.
felibol
Hello list,
uhd repo:
r
slave.
Thanks,
-Josh
