Traditionally steadying sails are on slides and bronze or stainless steel
track. Alumium in the thickness necessary is not practical. The use of
track allows the sail to be deployed easily. Some vessels now are using
roller furling--with a luff wire and a roller furling drum. This requires U
V protection on the exposed part of the sail, typically Sunbrella. Hoops are
rarely used today.
The steadying sail should be very flat cut and can be loose footed (it is
slightly easier to stow on the boom if it has track and slides on the boom.
Some alumium masts and booms have luff grooves, either slugs (nylon) or bolt
ropes are used in the grooves. (not recommended). Lashing could be used, but
probably not recommended. The cheapest and easiest is sail track and slides.
The easiest is the luff wire and roller furling.
Bob Austin
