While reading the notes on snubbers and their use, I haven't seen much
mention of the need for a short, stout "snubber" for use in pulling
anchors loose from the bottom. I anchor in shallow waters for
hurricanes. The narrowness of the place I do this (numerous boats tied
bow-to-trees with sterns anchored in deeper water, all in CLOSE
proximity to one another with overlapping rodes) requires "setting" the
anchors with the engines. Getting these anchors up and stowed typically
takes half a day and neighborly cooperation. With no swell to help
loosen these anchors when the rode is hauled in to an "up and down"
condition, it takes brute force of the boat and engines to loosen the
deeply embedded anchors. I am most careful to attach a snubber to the
chain and slack the windlass before hogging any of these beasts loose
from the bottom "glue." You don't want a bent windlass shaft - do not
ask me how I know (but I wasn't the one who bent it). So I see that
there is really potential application for long elastic as well as short
stout snubbers on every trawler. BTW, the toughest anchor retrieval job
I ever had was getting my fisherman ("kedge" to some) style anchor out
of the bottom of a bayou after hurricane Opal in 1995. That sucker took
an hour, two snubbers, and full engine power see-sawing back and forth
over the top of it, and it was not hung on some obstruction either!
Rich Gano
CALYPSO (GB42-295)
Southport, FL
