time-nuts@lists.febo.com
Re: [time-nuts] Conducting Bench Top Material
S
SAIDJACK@aol.com
Fri, Jan 29, 2010 5:36 PM
It works well, and they have a wall-mount version as well.
Note that this reacts to 470MHz GMRS radios: the lamp get's brighter when
transmitting in it's vicinity, and completely shuts-off when you transmit
close  to it.
It is very bright indeed.
bye,
Said
In a message dated 1/29/2010 06:27:16 Pacific Standard Time,
phk@phk.freebsd.dk writes:
I  use one for my small CNC-mill:
http://ing.dk/uploads/society/content/232.png
It's called "JAN SJÖ"  here, not sure if they use that name in other
geographies.
Highly  recommended.
It works well, and they have a wall-mount version as well. Note that this reacts to 470MHz GMRS radios: the lamp get's brighter when transmitting in it's vicinity, and completely shuts-off when you transmit close to it. It is very bright indeed. bye, Said In a message dated 1/29/2010 06:27:16 Pacific Standard Time, phk@phk.freebsd.dk writes: I use one for my small CNC-mill: http://ing.dk/uploads/society/content/232.png It's called "JAN SJÖ" here, not sure if they use that name in other geographies. Highly recommended. --
