time-nuts@lists.febo.com
Prologix GPIB/USB converter help...
P
Prologix
Mon, Apr 16, 2007 12:11 AM
Hello Said,
Unfortunately, no. Updated firmware requires the new hardware.
Why are you not using hardware flow control? Which platform and application
are you using?
Regards,
Abdul
Hello Abdul,
is there a way to upgrade older boards with a new microcontroller?
I have a version 3.11 board, and can replace the micro myself.
Presently I am bypassing the Hardware flow control using delays in the
control software, not very elegant and it is quite slow.
Thanks,
Said
Hello Said, Unfortunately, no. Updated firmware requires the new hardware. Why are you not using hardware flow control? Which platform and application are you using? Regards, Abdul Hello Abdul, is there a way to upgrade older boards with a new microcontroller? I have a version 3.11 board, and can replace the micro myself. Presently I am bypassing the Hardware flow control using delays in the control software, not very elegant and it is quite slow. Thanks, Said
