My boat is a woody, but it sounds as if your sliders are captured and held in
place by the wooden frames. Here's what I did a few years back to replace a
cracked slider:
- Slide the window open about 1-2 inches.
- Use a grinding wheel to vertically cut the top of the frame inch ahead and
one inch behind the slider.
- Sand the paint off the wooden frame between the two cuts to find the wooden
plugs covering the screws attaching the frame to the cabin side.
- Use a Forstner bit of whatever else you like to cut the plugs and then remove
the screws.
- Use a chisel to break the glue/sealant bond between the frame and the cabin.
If you destroy the bit of framing, it's no big deal to form up a new one - mine
popped off. Do not use something like 4200/5200 to reattach it unless you are
ready to employ Debond liberally and hopefully.
- Lever the slider down from the top and pull out all the old window channel
material.
- Place new channel in the bottom and side frames.
- Put the new slider in place and seal and refasten the top piece of frame in
place.
- Working from the "back" end of the slider, you should be able to work the new
top window channel material into place. Put a couple of screws through it into
the frame to hold it in place before sliding the window all the way aft. Then
put a few screws through it into the frame to hold the front end of the channel
in place.
- Fair the cuts and repaint.
Yer, dun, bud. :)
Rich Gano
CALYPSO (GB-42 #295)
Southport, FL (near Panama City)
cracked slider:
1. Slide the window open about 1-2 inches.
2. Use a grinding wheel to vertically cut the top of the frame inch ahead and
3. Sand the paint off the wooden frame between the two cuts to find the wooden
4. Use a Forstner bit of whatever else you like to cut the plugs and then remove
the screws.
5. Use a chisel to break the glue/sealant bond between the frame and the cabin.
6. Lever the slider down from the top and pull out all the old window channel
material.
7. Place new channel in the bottom and side frames.
8. Put the new slider in place and seal and refasten the top piece of frame in
place.
9. Working from the "back" end of the slider, you should be able to work the new
in place.
10. Fair the cuts and repaint.
Yer, dun, bud. :)
Rich Gano
