time-nuts@lists.febo.com
Re: [time-nuts] 10 MHz to 32.768 kHz converter
HM
Hal Murray
Sun, Mar 20, 2016 9:36 PM
My question is should I expect exactly 32.768000000 kHz (obviously assuming
we use the same 10 MHz to drive the divider and all test equipment)?
Yes, as long as you are feeding the same reference to your counter and your
divider you should get an exact answer.
The closest I can get the 32.768 kHz is within about 0.1 Hz.
How accurate is your counter?
Do the arithmetic and count cycles.  You may be able to figure out how many
cycles you are off.  You can try different chunks of code to verify that they
are doing what you expect.  Or put trigger a scope on a PPS and see if the 32
KHz is drifting.
Does the actual model of PIC chip influence the accuracy?
Compare the cycle counts on the instructions.  I expect them to be the same,
but I haven't compared various PIC versions in a long time.
These are my opinions.  I hate spam.
martyn@ptsyst.com said: > My question is should I expect exactly 32.768000000 kHz (obviously assuming > we use the same 10 MHz to drive the divider and all test equipment)? Yes, as long as you are feeding the same reference to your counter and your divider you should get an exact answer. > The closest I can get the 32.768 kHz is within about 0.1 Hz. How accurate is your counter? Do the arithmetic and count cycles. You may be able to figure out how many cycles you are off. You can try different chunks of code to verify that they are doing what you expect. Or put trigger a scope on a PPS and see if the 32 KHz is drifting. > Does the actual model of PIC chip influence the accuracy? Compare the cycle counts on the instructions. I expect them to be the same, but I haven't compared various PIC versions in a long time. -- These are my opinions. I hate spam.
