Using pjsip application layer on Windows Mobile 6.5 - when the device suspended - I'm not getting any events.
JT
John Tamburin
Wed, Feb 3, 2010 8:30 AM
Hi all,
I'm trying to use the pjsip application layer(on windows mobile 6.5) - that
works perfectly when the device is "turned on" - Under On power state,
but when the device moves to Suspend power state, after a few seconds my
application fails to receive notification (incoming call and so on).
I really need the suspend mode active - it saves lots of battery power, on
the other hand, the notifications seize to occur!
Help will be greatly appreciated.
John.
Hi all, I'm trying to use the pjsip application layer(on windows mobile 6.5) - that works perfectly when the device is "turned on" - Under On power state, but when the device moves to Suspend power state, after a few seconds my application fails to receive notification (incoming call and so on). I really need the suspend mode active - it saves lots of battery power, on the other hand, the notifications seize to occur! Help will be greatly appreciated. John.
RM
Re Mo
Tue, Feb 16, 2010 10:08 AM
Hello John,
I'm trying to run my PJSIP demo using Release version but it seems that i
the application crash while the Debug version run perfectly, did you
encounter this problem?
Thanks.
On Wed, Feb 3, 2010 at 10:30 AM, John Tamburin johntambu@gmail.com wrote:
Hi all,
John.
Visit our blog: http://blog.pjsip.org
pjsip mailing list
pjsip@lists.pjsip.org
http://lists.pjsip.org/mailman/listinfo/pjsip_lists.pjsip.org
Hello John, I'm trying to run my PJSIP demo using Release version but it seems that i the application crash while the Debug version run perfectly, did you encounter this problem? Thanks. On Wed, Feb 3, 2010 at 10:30 AM, John Tamburin <johntambu@gmail.com> wrote: > Hi all, > I'm trying to use the pjsip application layer(on windows mobile 6.5) - that > works perfectly when the device is "turned on" - Under On power state, > but when the device moves to Suspend power state, after a few seconds my > application fails to receive notification (incoming call and so on). > > I really need the suspend mode active - it saves lots of battery power, on > the other hand, the notifications seize to occur! > > Help will be greatly appreciated. > John. > > _______________________________________________ > Visit our blog: http://blog.pjsip.org > > pjsip mailing list > pjsip@lists.pjsip.org > http://lists.pjsip.org/mailman/listinfo/pjsip_lists.pjsip.org > >
