USRP1 support: "unknown" daughterboard
CA
Carlos Alberto Ruiz Naranjo
Tue, Dec 11, 2018 9:36 PM
Hello,
I have found a USRP1 and I am playing with it. I have this error:
carlos@carlos-pc:~$ sudo uhd_usrp_probe --args="type=usrp1"
[INFO] [UHD] linux; GNU C++ version 7.3.0; Boost_106501;
UHD_4.0.0.rfnoc-devel-702-geec24d7b
[INFO] [USRP1] Opening a USRP1 device...
[INFO] [USRP1] Using FPGA clock rate of 64.000000MHz...
[ERROR] [DBMGR] The daughterboard manager encountered a recoverable error
in init.
Loading the "unknown" daughterboard implementations to continue.
The daughterboard cannot operate until this error is resolved.
AssertionError: m and ref_clock/m >= 1e6 and ref_clock/m <= 2.5e6
in double dbsrx::set_lo_freq(double)
at /home/carlos/rfnoc/uhd/host/lib/usrp/dboard/db_dbsrx.cpp:305
|      Device: USRP1 Device
|    _____________________________________________________
|  |      Mboard: USRP1
|  |  serial: 479b9db3
|  |  Time sources:  none
|  |  Clock sources: internal
|  |  Sensors:
|  |    _____________________________________________________
|  |  |      RX DSP: 0
|  |  |  Freq range: -32.000 to 32.000 MHz
|  |  |      RX DSP: 1
|  |  |      RX Dboard: A
|  |  |  ID: DBSRX (0x0002)
|  |  |    _____________________________________________________
|  |  |  |      RX Frontend: 0
|  |  |  |  Name: Unknown (0xffff) - 0
|  |  |  |  Antennas:
|  |  |  |  Sensors:
|  |  |  |  Freq range: 0.000 to 0.000 MHz
|  |  |  |  Gain Elements: None
|  |  |  |  Bandwidth range: 0.0 to 0.0 step 0.0 Hz
|  |  |  |  Connection Type: IQ
|  |  |  |  Uses LO offset: No
|  |  |  |      RX Codec: A
|  |  |  |  Name: ad9522
|  |  |  |  Gain range pga: 0.0 to 20.0 step 1.0 dB
|  |  |      RX Dboard: B
|  |  |  |  Antennas:
|  |  |  |  Sensors:
|  |  |  |      RX Codec: B
|  |  |  |  Name: ad9522
|  |  |      TX DSP: 0
|  |  |  Freq range: -44.000 to 44.000 MHz
|  |  |      TX DSP: 1
|  |  |      TX Dboard: A
|  |  |  |      TX Frontend: 0
|  |  |  |  Antennas:
|  |  |  |  Sensors:
|  |  |  |      TX Codec: A
|  |  |  |  Name: ad9522
|  |  |  |  Gain range pga: -20.0 to 0.0 step 0.1 dB
|  |  |      TX Dboard: B
|  |  |  |  Antennas:
|  |  |  |  Sensors:
|  |  |  |      TX Codec: B
|  |  |  |  Name: ad9522
And the same in GNURadio:
Executing: /usr/bin/python2 -u /home/carlos/top_block.py
[32;1m[INFO] [UHD] [39;0mlinux; GNU C++ version 7.3.0; Boost_106501;
[32;1m[INFO] [USRP1] [39;0mOpening a USRP1 device...
[32;1m[INFO] [USRP1] [39;0mUsing FPGA clock rate of 64.000000MHz...
[31;0m[ERROR] [DBMGR] [39;0mThe daughterboard manager encountered a
recoverable error in init.
[33;1m[WARNING] [MULTI_USRP] [39;0mSetting IQ imbalance compensation is not
possible on this device.
INFO: Audio sink arch: alsa
aUaU
Hello, I have found a USRP1 and I am playing with it. I have this error: carlos@carlos-pc:~$ sudo uhd_usrp_probe --args="type=usrp1" [INFO] [UHD] linux; GNU C++ version 7.3.0; Boost_106501; UHD_4.0.0.rfnoc-devel-702-geec24d7b [INFO] [USRP1] Opening a USRP1 device... [INFO] [USRP1] Using FPGA clock rate of 64.000000MHz... [ERROR] [DBMGR] The daughterboard manager encountered a recoverable error in init. Loading the "unknown" daughterboard implementations to continue. The daughterboard cannot operate until this error is resolved. AssertionError: m and ref_clock/m >= 1e6 and ref_clock/m <= 2.5e6 in double dbsrx::set_lo_freq(double) at /home/carlos/rfnoc/uhd/host/lib/usrp/dboard/db_dbsrx.cpp:305 _____________________________________________________ / | Device: USRP1 Device | _____________________________________________________ | / | | Mboard: USRP1 | | serial: 479b9db3 | | | | Time sources: none | | Clock sources: internal | | Sensors: | | _____________________________________________________ | | / | | | RX DSP: 0 | | | | | | Freq range: -32.000 to 32.000 MHz | | _____________________________________________________ | | / | | | RX DSP: 1 | | | | | | Freq range: -32.000 to 32.000 MHz | | _____________________________________________________ | | / | | | RX Dboard: A | | | ID: DBSRX (0x0002) | | | _____________________________________________________ | | | / | | | | RX Frontend: 0 | | | | Name: Unknown (0xffff) - 0 | | | | Antennas: | | | | Sensors: | | | | Freq range: 0.000 to 0.000 MHz | | | | Gain Elements: None | | | | Bandwidth range: 0.0 to 0.0 step 0.0 Hz | | | | Connection Type: IQ | | | | Uses LO offset: No | | | _____________________________________________________ | | | / | | | | RX Codec: A | | | | Name: ad9522 | | | | Gain range pga: 0.0 to 20.0 step 1.0 dB | | _____________________________________________________ | | / | | | RX Dboard: B | | | _____________________________________________________ | | | / | | | | RX Frontend: 0 | | | | Name: Unknown (0xffff) - 0 | | | | Antennas: | | | | Sensors: | | | | Freq range: 0.000 to 0.000 MHz | | | | Gain Elements: None | | | | Bandwidth range: 0.0 to 0.0 step 0.0 Hz | | | | Connection Type: IQ | | | | Uses LO offset: No | | | _____________________________________________________ | | | / | | | | RX Codec: B | | | | Name: ad9522 | | | | Gain range pga: 0.0 to 20.0 step 1.0 dB | | _____________________________________________________ | | / | | | TX DSP: 0 | | | | | | Freq range: -44.000 to 44.000 MHz | | _____________________________________________________ | | / | | | TX DSP: 1 | | | | | | Freq range: -44.000 to 44.000 MHz | | _____________________________________________________ | | / | | | TX Dboard: A | | | _____________________________________________________ | | | / | | | | TX Frontend: 0 | | | | Name: Unknown (0xffff) - 0 | | | | Antennas: | | | | Sensors: | | | | Freq range: 0.000 to 0.000 MHz | | | | Gain Elements: None | | | | Bandwidth range: 0.0 to 0.0 step 0.0 Hz | | | | Connection Type: IQ | | | | Uses LO offset: No | | | _____________________________________________________ | | | / | | | | TX Codec: A | | | | Name: ad9522 | | | | Gain range pga: -20.0 to 0.0 step 0.1 dB | | _____________________________________________________ | | / | | | TX Dboard: B | | | _____________________________________________________ | | | / | | | | TX Frontend: 0 | | | | Name: Unknown (0xffff) - 0 | | | | Antennas: | | | | Sensors: | | | | Freq range: 0.000 to 0.000 MHz | | | | Gain Elements: None | | | | Bandwidth range: 0.0 to 0.0 step 0.0 Hz | | | | Connection Type: IQ | | | | Uses LO offset: No | | | _____________________________________________________ | | | / | | | | TX Codec: B | | | | Name: ad9522 | | | | Gain range pga: -20.0 to 0.0 step 0.1 dB And the same in GNURadio: Executing: /usr/bin/python2 -u /home/carlos/top_block.py [32;1m[INFO] [UHD] [39;0mlinux; GNU C++ version 7.3.0; Boost_106501; UHD_4.0.0.rfnoc-devel-702-geec24d7b [32;1m[INFO] [USRP1] [39;0mOpening a USRP1 device... [32;1m[INFO] [USRP1] [39;0mUsing FPGA clock rate of 64.000000MHz... [31;0m[ERROR] [DBMGR] [39;0mThe daughterboard manager encountered a recoverable error in init. Loading the "unknown" daughterboard implementations to continue. The daughterboard cannot operate until this error is resolved. AssertionError: m and ref_clock/m >= 1e6 and ref_clock/m <= 2.5e6 in double dbsrx::set_lo_freq(double) at /home/carlos/rfnoc/uhd/host/lib/usrp/dboard/db_dbsrx.cpp:305 [33;1m[WARNING] [MULTI_USRP] [39;0mSetting IQ imbalance compensation is not possible on this device. INFO: Audio sink arch: alsa aUaU
MD
Marcus D. Leech
Tue, Dec 11, 2018 9:41 PM
On 12/11/2018 04:36 PM, Carlos Alberto Ruiz Naranjo via USRP-users wrote:
Hello,
error in init.
|  |      Mboard: USRP1
|  |  serial: 479b9db3
|  |  Sensors:
|  |  |      RX DSP: 0
|  |  |      RX DSP: 1
|  |  |      RX Dboard: A
|  |  |  |  Antennas:
|  |  |  |  Sensors:
|  |  |  |      RX Codec: A
|  |  |  |  Name: ad9522
|  |  |      RX Dboard: B
|  |  |  |  Antennas:
|  |  |  |  Sensors:
|  |  |  |      RX Codec: B
|  |  |  |  Name: ad9522
|  |  |      TX DSP: 0
|  |  |      TX DSP: 1
|  |  |      TX Dboard: A
|  |  |  |  Antennas:
|  |  |  |  Sensors:
|  |  |  |      TX Codec: A
|  |  |  |  Name: ad9522
|  |  |      TX Dboard: B
|  |  |  |  Antennas:
|  |  |  |  Sensors:
|  |  |  |      TX Codec: B
|  |  |  |  Name: ad9522
aUaU
Try an older release of UHD--does that help?
The DBSRX is ceftainly supported, and if support has gone away, that's
not design intent as far as I know.
Although, I must point out that the DBSRX was EOLed in favor of the
DBSRX2 nearly a decade ago, and the USRP1 is itself EOLed...
On 12/11/2018 04:36 PM, Carlos Alberto Ruiz Naranjo via USRP-users wrote: > Hello, > > I have found a USRP1 and I am playing with it. I have this error: > > carlos@carlos-pc:~$ sudo uhd_usrp_probe --args="type=usrp1" > [INFO] [UHD] linux; GNU C++ version 7.3.0; Boost_106501; > UHD_4.0.0.rfnoc-devel-702-geec24d7b > [INFO] [USRP1] Opening a USRP1 device... > [INFO] [USRP1] Using FPGA clock rate of 64.000000MHz... > [ERROR] [DBMGR] The daughterboard manager encountered a recoverable > error in init. > Loading the "unknown" daughterboard implementations to continue. > The daughterboard cannot operate until this error is resolved. > AssertionError: m and ref_clock/m >= 1e6 and ref_clock/m <= 2.5e6 > in double dbsrx::set_lo_freq(double) > at /home/carlos/rfnoc/uhd/host/lib/usrp/dboard/db_dbsrx.cpp:305 > > _____________________________________________________ > / > | Device: USRP1 Device > | _____________________________________________________ > | / > | | Mboard: USRP1 > | | serial: 479b9db3 > | | > | | Time sources: none > | | Clock sources: internal > | | Sensors: > | | _____________________________________________________ > | | / > | | | RX DSP: 0 > | | | > | | | Freq range: -32.000 to 32.000 MHz > | | _____________________________________________________ > | | / > | | | RX DSP: 1 > | | | > | | | Freq range: -32.000 to 32.000 MHz > | | _____________________________________________________ > | | / > | | | RX Dboard: A > | | | ID: DBSRX (0x0002) > | | | _____________________________________________________ > | | | / > | | | | RX Frontend: 0 > | | | | Name: Unknown (0xffff) - 0 > | | | | Antennas: > | | | | Sensors: > | | | | Freq range: 0.000 to 0.000 MHz > | | | | Gain Elements: None > | | | | Bandwidth range: 0.0 to 0.0 step 0.0 Hz > | | | | Connection Type: IQ > | | | | Uses LO offset: No > | | | _____________________________________________________ > | | | / > | | | | RX Codec: A > | | | | Name: ad9522 > | | | | Gain range pga: 0.0 to 20.0 step 1.0 dB > | | _____________________________________________________ > | | / > | | | RX Dboard: B > | | | _____________________________________________________ > | | | / > | | | | RX Frontend: 0 > | | | | Name: Unknown (0xffff) - 0 > | | | | Antennas: > | | | | Sensors: > | | | | Freq range: 0.000 to 0.000 MHz > | | | | Gain Elements: None > | | | | Bandwidth range: 0.0 to 0.0 step 0.0 Hz > | | | | Connection Type: IQ > | | | | Uses LO offset: No > | | | _____________________________________________________ > | | | / > | | | | RX Codec: B > | | | | Name: ad9522 > | | | | Gain range pga: 0.0 to 20.0 step 1.0 dB > | | _____________________________________________________ > | | / > | | | TX DSP: 0 > | | | > | | | Freq range: -44.000 to 44.000 MHz > | | _____________________________________________________ > | | / > | | | TX DSP: 1 > | | | > | | | Freq range: -44.000 to 44.000 MHz > | | _____________________________________________________ > | | / > | | | TX Dboard: A > | | | _____________________________________________________ > | | | / > | | | | TX Frontend: 0 > | | | | Name: Unknown (0xffff) - 0 > | | | | Antennas: > | | | | Sensors: > | | | | Freq range: 0.000 to 0.000 MHz > | | | | Gain Elements: None > | | | | Bandwidth range: 0.0 to 0.0 step 0.0 Hz > | | | | Connection Type: IQ > | | | | Uses LO offset: No > | | | _____________________________________________________ > | | | / > | | | | TX Codec: A > | | | | Name: ad9522 > | | | | Gain range pga: -20.0 to 0.0 step 0.1 dB > | | _____________________________________________________ > | | / > | | | TX Dboard: B > | | | _____________________________________________________ > | | | / > | | | | TX Frontend: 0 > | | | | Name: Unknown (0xffff) - 0 > | | | | Antennas: > | | | | Sensors: > | | | | Freq range: 0.000 to 0.000 MHz > | | | | Gain Elements: None > | | | | Bandwidth range: 0.0 to 0.0 step 0.0 Hz > | | | | Connection Type: IQ > | | | | Uses LO offset: No > | | | _____________________________________________________ > | | | / > | | | | TX Codec: B > | | | | Name: ad9522 > | | | | Gain range pga: -20.0 to 0.0 step 0.1 dB > > And the same in GNURadio: > > Executing: /usr/bin/python2 -u /home/carlos/top_block.py > > [32;1m[INFO] [UHD] [39;0mlinux; GNU C++ version 7.3.0; Boost_106501; > UHD_4.0.0.rfnoc-devel-702-geec24d7b > [32;1m[INFO] [USRP1] [39;0mOpening a USRP1 device... > [32;1m[INFO] [USRP1] [39;0mUsing FPGA clock rate of 64.000000MHz... > [31;0m[ERROR] [DBMGR] [39;0mThe daughterboard manager encountered a > recoverable error in init. > Loading the "unknown" daughterboard implementations to continue. > The daughterboard cannot operate until this error is resolved. > AssertionError: m and ref_clock/m >= 1e6 and ref_clock/m <= 2.5e6 > in double dbsrx::set_lo_freq(double) > at /home/carlos/rfnoc/uhd/host/lib/usrp/dboard/db_dbsrx.cpp:305 > > [33;1m[WARNING] [MULTI_USRP] [39;0mSetting IQ imbalance compensation > is not possible on this device. > INFO: Audio sink arch: alsa > aUaU > > Try an older release of UHD--does that help? The DBSRX is ceftainly supported, and if support has gone away, that's not design intent as far as I know. Although, I must point out that the DBSRX was EOLed in favor of the DBSRX2 nearly a decade ago, and the USRP1 is itself EOLed...
CA
Wed, Dec 12, 2018 12:15 PM
Hi Marcus,
I have changed the version to UHD-3.9.LTS. With *uhd_usrp_probe
--args="type=usrp1" *I haven't erros. But I don't know why the GNURadio
version hasn't changed... I have, with the previous errors :
  • GNU C++ version 7.3.0; Boost_106501; UHD_4.0.0.rfnoc-devel-702-*
    geec24d7b
Any idea?
Thank you.
El mar., 11 dic. 2018 a las 22:42, Marcus D. Leech via USRP-users (<
Hello,
error in init.
|  |      Mboard: USRP1
|  |  serial: 479b9db3
|  |  Sensors:
|  |  |      RX DSP: 0
|  |  |      RX DSP: 1
|  |  |      RX Dboard: A
|  |  |  |  Antennas:
|  |  |  |  Sensors:
|  |  |  |      RX Codec: A
|  |  |  |  Name: ad9522
|  |  |      RX Dboard: B
|  |  |  |  Antennas:
|  |  |  |  Sensors:
|  |  |  |      RX Codec: B
|  |  |  |  Name: ad9522
|  |  |      TX DSP: 0
|  |  |      TX DSP: 1
|  |  |      TX Dboard: A
|  |  |  |  Antennas:
|  |  |  |  Sensors:
|  |  |  |      TX Codec: A
|  |  |  |  Name: ad9522
|  |  |      TX Dboard: B
|  |  |  |  Antennas:
|  |  |  |  Sensors:
|  |  |  |      TX Codec: B
|  |  |  |  Name: ad9522
aUaU
USRP-users mailing list
USRP-users@lists.ettus.com
Hi Marcus, I have changed the version to UHD-3.9.LTS. With *uhd_usrp_probe --args="type=usrp1" *I haven't erros. But I don't know why the GNURadio version hasn't changed... I have, with the previous errors : * GNU C++ version 7.3.0; Boost_106501; UHD_4.0.0.rfnoc-devel-702-* *geec24d7b* Any idea? Thank you. El mar., 11 dic. 2018 a las 22:42, Marcus D. Leech via USRP-users (< usrp-users@lists.ettus.com>) escribió: > On 12/11/2018 04:36 PM, Carlos Alberto Ruiz Naranjo via USRP-users wrote: > > Hello, > > > > I have found a USRP1 and I am playing with it. I have this error: > > > > carlos@carlos-pc:~$ sudo uhd_usrp_probe --args="type=usrp1" > > [INFO] [UHD] linux; GNU C++ version 7.3.0; Boost_106501; > > UHD_4.0.0.rfnoc-devel-702-geec24d7b > > [INFO] [USRP1] Opening a USRP1 device... > > [INFO] [USRP1] Using FPGA clock rate of 64.000000MHz... > > [ERROR] [DBMGR] The daughterboard manager encountered a recoverable > > error in init. > > Loading the "unknown" daughterboard implementations to continue. > > The daughterboard cannot operate until this error is resolved. > > AssertionError: m and ref_clock/m >= 1e6 and ref_clock/m <= 2.5e6 > > in double dbsrx::set_lo_freq(double) > > at /home/carlos/rfnoc/uhd/host/lib/usrp/dboard/db_dbsrx.cpp:305 > > > > _____________________________________________________ > > / > > | Device: USRP1 Device > > | _____________________________________________________ > > | / > > | | Mboard: USRP1 > > | | serial: 479b9db3 > > | | > > | | Time sources: none > > | | Clock sources: internal > > | | Sensors: > > | | _____________________________________________________ > > | | / > > | | | RX DSP: 0 > > | | | > > | | | Freq range: -32.000 to 32.000 MHz > > | | _____________________________________________________ > > | | / > > | | | RX DSP: 1 > > | | | > > | | | Freq range: -32.000 to 32.000 MHz > > | | _____________________________________________________ > > | | / > > | | | RX Dboard: A > > | | | ID: DBSRX (0x0002) > > | | | _____________________________________________________ > > | | | / > > | | | | RX Frontend: 0 > > | | | | Name: Unknown (0xffff) - 0 > > | | | | Antennas: > > | | | | Sensors: > > | | | | Freq range: 0.000 to 0.000 MHz > > | | | | Gain Elements: None > > | | | | Bandwidth range: 0.0 to 0.0 step 0.0 Hz > > | | | | Connection Type: IQ > > | | | | Uses LO offset: No > > | | | _____________________________________________________ > > | | | / > > | | | | RX Codec: A > > | | | | Name: ad9522 > > | | | | Gain range pga: 0.0 to 20.0 step 1.0 dB > > | | _____________________________________________________ > > | | / > > | | | RX Dboard: B > > | | | _____________________________________________________ > > | | | / > > | | | | RX Frontend: 0 > > | | | | Name: Unknown (0xffff) - 0 > > | | | | Antennas: > > | | | | Sensors: > > | | | | Freq range: 0.000 to 0.000 MHz > > | | | | Gain Elements: None > > | | | | Bandwidth range: 0.0 to 0.0 step 0.0 Hz > > | | | | Connection Type: IQ > > | | | | Uses LO offset: No > > | | | _____________________________________________________ > > | | | / > > | | | | RX Codec: B > > | | | | Name: ad9522 > > | | | | Gain range pga: 0.0 to 20.0 step 1.0 dB > > | | _____________________________________________________ > > | | / > > | | | TX DSP: 0 > > | | | > > | | | Freq range: -44.000 to 44.000 MHz > > | | _____________________________________________________ > > | | / > > | | | TX DSP: 1 > > | | | > > | | | Freq range: -44.000 to 44.000 MHz > > | | _____________________________________________________ > > | | / > > | | | TX Dboard: A > > | | | _____________________________________________________ > > | | | / > > | | | | TX Frontend: 0 > > | | | | Name: Unknown (0xffff) - 0 > > | | | | Antennas: > > | | | | Sensors: > > | | | | Freq range: 0.000 to 0.000 MHz > > | | | | Gain Elements: None > > | | | | Bandwidth range: 0.0 to 0.0 step 0.0 Hz > > | | | | Connection Type: IQ > > | | | | Uses LO offset: No > > | | | _____________________________________________________ > > | | | / > > | | | | TX Codec: A > > | | | | Name: ad9522 > > | | | | Gain range pga: -20.0 to 0.0 step 0.1 dB > > | | _____________________________________________________ > > | | / > > | | | TX Dboard: B > > | | | _____________________________________________________ > > | | | / > > | | | | TX Frontend: 0 > > | | | | Name: Unknown (0xffff) - 0 > > | | | | Antennas: > > | | | | Sensors: > > | | | | Freq range: 0.000 to 0.000 MHz > > | | | | Gain Elements: None > > | | | | Bandwidth range: 0.0 to 0.0 step 0.0 Hz > > | | | | Connection Type: IQ > > | | | | Uses LO offset: No > > | | | _____________________________________________________ > > | | | / > > | | | | TX Codec: B > > | | | | Name: ad9522 > > | | | | Gain range pga: -20.0 to 0.0 step 0.1 dB > > > > And the same in GNURadio: > > > > Executing: /usr/bin/python2 -u /home/carlos/top_block.py > > > > [32;1m[INFO] [UHD] [39;0mlinux; GNU C++ version 7.3.0; Boost_106501; > > UHD_4.0.0.rfnoc-devel-702-geec24d7b > > [32;1m[INFO] [USRP1] [39;0mOpening a USRP1 device... > > [32;1m[INFO] [USRP1] [39;0mUsing FPGA clock rate of 64.000000MHz... > > [31;0m[ERROR] [DBMGR] [39;0mThe daughterboard manager encountered a > > recoverable error in init. > > Loading the "unknown" daughterboard implementations to continue. > > The daughterboard cannot operate until this error is resolved. > > AssertionError: m and ref_clock/m >= 1e6 and ref_clock/m <= 2.5e6 > > in double dbsrx::set_lo_freq(double) > > at /home/carlos/rfnoc/uhd/host/lib/usrp/dboard/db_dbsrx.cpp:305 > > > > [33;1m[WARNING] [MULTI_USRP] [39;0mSetting IQ imbalance compensation > > is not possible on this device. > > INFO: Audio sink arch: alsa > > aUaU > > > > > Try an older release of UHD--does that help? > > The DBSRX is ceftainly supported, and if support has gone away, that's > not design intent as far as I know. > > Although, I must point out that the DBSRX was EOLed in favor of the > DBSRX2 nearly a decade ago, and the USRP1 is itself EOLed... > > > > _______________________________________________ > USRP-users mailing list > USRP-users@lists.ettus.com > http://lists.ettus.com/mailman/listinfo/usrp-users_lists.ettus.com >
RC
Robin Coxe
Wed, Dec 12, 2018 2:42 PM
You may have multiple versions of GNU Radio and/or UHD libraries still installed on your PC.  Try navigating to the wherever you installed them (e.g., /usr/local/lib) and deleting the ones you don’t want by hand.
Robin Coxe | Chief R&D Program Manager, SDR | Santa Clara, CA | 408.610.6363
From: USRP-users usrp-users-bounces@lists.ettus.com on behalf of Carlos Alberto Ruiz Naranjo via USRP-users usrp-users@lists.ettus.com
Sent: Wednesday, December 12, 2018 4:17 AM
To: patchvonbraun@gmail.com
Cc: USRP-users@lists.ettus.com
Subject: Re: [USRP-users] USRP1 support: "unknown" daughterboard
Hi Marcus,
I have changed the version to UHD-3.9.LTS. With uhd_usrp_probe --args="type=usrp1" I haven't erros. But I don't know why the GNURadio version hasn't changed... I have, with the previous errors :
Any idea?
Thank you.
El mar., 11 dic. 2018 a las 22:42, Marcus D. Leech via USRP-users (<usrp-users@lists.ettus.commailto:usrp-users@lists.ettus.com>) escribió:
Hello,
error in init.
|  |      Mboard: USRP1
|  |  serial: 479b9db3
|  |  Sensors:
|  |  |      RX DSP: 0
|  |  |      RX DSP: 1
|  |  |      RX Dboard: A
|  |  |  |  Antennas:
|  |  |  |  Sensors:
|  |  |  |      RX Codec: A
|  |  |  |  Name: ad9522
|  |  |      RX Dboard: B
|  |  |  |  Antennas:
|  |  |  |  Sensors:
|  |  |  |      RX Codec: B
|  |  |  |  Name: ad9522
|  |  |      TX DSP: 0
|  |  |      TX DSP: 1
|  |  |      TX Dboard: A
|  |  |  |  Antennas:
|  |  |  |  Sensors:
|  |  |  |      TX Codec: A
|  |  |  |  Name: ad9522
|  |  |      TX Dboard: B
|  |  |  |  Antennas:
|  |  |  |  Sensors:
|  |  |  |      TX Codec: B
|  |  |  |  Name: ad9522
aUaU
USRP-users@lists.ettus.commailto:USRP-users@lists.ettus.com
You may have multiple versions of GNU Radio and/or UHD libraries still installed on your PC. Try navigating to the wherever you installed them (e.g., /usr/local/lib) and deleting the ones you don’t want by hand. Robin Coxe | Chief R&D Program Manager, SDR | Santa Clara, CA | 408.610.6363 ________________________________ From: USRP-users <usrp-users-bounces@lists.ettus.com> on behalf of Carlos Alberto Ruiz Naranjo via USRP-users <usrp-users@lists.ettus.com> Sent: Wednesday, December 12, 2018 4:17 AM To: patchvonbraun@gmail.com Cc: USRP-users@lists.ettus.com Subject: Re: [USRP-users] USRP1 support: "unknown" daughterboard Hi Marcus, I have changed the version to UHD-3.9.LTS. With uhd_usrp_probe --args="type=usrp1" I haven't erros. But I don't know why the GNURadio version hasn't changed... I have, with the previous errors : GNU C++ version 7.3.0; Boost_106501; UHD_4.0.0.rfnoc-devel-702-geec24d7b Any idea? Thank you. El mar., 11 dic. 2018 a las 22:42, Marcus D. Leech via USRP-users (<usrp-users@lists.ettus.com<mailto:usrp-users@lists.ettus.com>>) escribió: On 12/11/2018 04:36 PM, Carlos Alberto Ruiz Naranjo via USRP-users wrote: > Hello, > > I have found a USRP1 and I am playing with it. I have this error: > > carlos@carlos-pc:~$ sudo uhd_usrp_probe --args="type=usrp1" > [INFO] [UHD] linux; GNU C++ version 7.3.0; Boost_106501; > UHD_4.0.0.rfnoc-devel-702-geec24d7b > [INFO] [USRP1] Opening a USRP1 device... > [INFO] [USRP1] Using FPGA clock rate of 64.000000MHz... > [ERROR] [DBMGR] The daughterboard manager encountered a recoverable > error in init. > Loading the "unknown" daughterboard implementations to continue. > The daughterboard cannot operate until this error is resolved. > AssertionError: m and ref_clock/m >= 1e6 and ref_clock/m <= 2.5e6 > in double dbsrx::set_lo_freq(double) > at /home/carlos/rfnoc/uhd/host/lib/usrp/dboard/db_dbsrx.cpp:305 > > _____________________________________________________ > / > | Device: USRP1 Device > | _____________________________________________________ > | / > | | Mboard: USRP1 > | | serial: 479b9db3 > | | > | | Time sources: none > | | Clock sources: internal > | | Sensors: > | | _____________________________________________________ > | | / > | | | RX DSP: 0 > | | | > | | | Freq range: -32.000 to 32.000 MHz > | | _____________________________________________________ > | | / > | | | RX DSP: 1 > | | | > | | | Freq range: -32.000 to 32.000 MHz > | | _____________________________________________________ > | | / > | | | RX Dboard: A > | | | ID: DBSRX (0x0002) > | | | _____________________________________________________ > | | | / > | | | | RX Frontend: 0 > | | | | Name: Unknown (0xffff) - 0 > | | | | Antennas: > | | | | Sensors: > | | | | Freq range: 0.000 to 0.000 MHz > | | | | Gain Elements: None > | | | | Bandwidth range: 0.0 to 0.0 step 0.0 Hz > | | | | Connection Type: IQ > | | | | Uses LO offset: No > | | | _____________________________________________________ > | | | / > | | | | RX Codec: A > | | | | Name: ad9522 > | | | | Gain range pga: 0.0 to 20.0 step 1.0 dB > | | _____________________________________________________ > | | / > | | | RX Dboard: B > | | | _____________________________________________________ > | | | / > | | | | RX Frontend: 0 > | | | | Name: Unknown (0xffff) - 0 > | | | | Antennas: > | | | | Sensors: > | | | | Freq range: 0.000 to 0.000 MHz > | | | | Gain Elements: None > | | | | Bandwidth range: 0.0 to 0.0 step 0.0 Hz > | | | | Connection Type: IQ > | | | | Uses LO offset: No > | | | _____________________________________________________ > | | | / > | | | | RX Codec: B > | | | | Name: ad9522 > | | | | Gain range pga: 0.0 to 20.0 step 1.0 dB > | | _____________________________________________________ > | | / > | | | TX DSP: 0 > | | | > | | | Freq range: -44.000 to 44.000 MHz > | | _____________________________________________________ > | | / > | | | TX DSP: 1 > | | | > | | | Freq range: -44.000 to 44.000 MHz > | | _____________________________________________________ > | | / > | | | TX Dboard: A > | | | _____________________________________________________ > | | | / > | | | | TX Frontend: 0 > | | | | Name: Unknown (0xffff) - 0 > | | | | Antennas: > | | | | Sensors: > | | | | Freq range: 0.000 to 0.000 MHz > | | | | Gain Elements: None > | | | | Bandwidth range: 0.0 to 0.0 step 0.0 Hz > | | | | Connection Type: IQ > | | | | Uses LO offset: No > | | | _____________________________________________________ > | | | / > | | | | TX Codec: A > | | | | Name: ad9522 > | | | | Gain range pga: -20.0 to 0.0 step 0.1 dB > | | _____________________________________________________ > | | / > | | | TX Dboard: B > | | | _____________________________________________________ > | | | / > | | | | TX Frontend: 0 > | | | | Name: Unknown (0xffff) - 0 > | | | | Antennas: > | | | | Sensors: > | | | | Freq range: 0.000 to 0.000 MHz > | | | | Gain Elements: None > | | | | Bandwidth range: 0.0 to 0.0 step 0.0 Hz > | | | | Connection Type: IQ > | | | | Uses LO offset: No > | | | _____________________________________________________ > | | | / > | | | | TX Codec: B > | | | | Name: ad9522 > | | | | Gain range pga: -20.0 to 0.0 step 0.1 dB > > And the same in GNURadio: > > Executing: /usr/bin/python2 -u /home/carlos/top_block.py > > [32;1m[INFO] [UHD] [39;0mlinux; GNU C++ version 7.3.0; Boost_106501; > UHD_4.0.0.rfnoc-devel-702-geec24d7b > [32;1m[INFO] [USRP1] [39;0mOpening a USRP1 device... > [32;1m[INFO] [USRP1] [39;0mUsing FPGA clock rate of 64.000000MHz... > [31;0m[ERROR] [DBMGR] [39;0mThe daughterboard manager encountered a > recoverable error in init. > Loading the "unknown" daughterboard implementations to continue. > The daughterboard cannot operate until this error is resolved. > AssertionError: m and ref_clock/m >= 1e6 and ref_clock/m <= 2.5e6 > in double dbsrx::set_lo_freq(double) > at /home/carlos/rfnoc/uhd/host/lib/usrp/dboard/db_dbsrx.cpp:305 > > [33;1m[WARNING] [MULTI_USRP] [39;0mSetting IQ imbalance compensation > is not possible on this device. > INFO: Audio sink arch: alsa > aUaU > > Try an older release of UHD--does that help? The DBSRX is ceftainly supported, and if support has gone away, that's not design intent as far as I know. Although, I must point out that the DBSRX was EOLed in favor of the DBSRX2 nearly a decade ago, and the USRP1 is itself EOLed... _______________________________________________ USRP-users mailing list USRP-users@lists.ettus.com<mailto:USRP-users@lists.ettus.com> http://lists.ettus.com/mailman/listinfo/usrp-users_lists.ettus.com
CA
Thu, Dec 13, 2018 6:20 PM
Thank you!!! :)
El mié., 12 dic. 2018 a las 15:42, Robin Coxe (robin.coxe@ettus.com)
408.610.6363
Hi Marcus,
geec24d7b
Any idea?
Thank you.
Hello,
error in init.
|  |      Mboard: USRP1
|  |  serial: 479b9db3
|  |  Sensors:
|  |  |      RX DSP: 0
|  |  |      RX DSP: 1
|  |  |      RX Dboard: A
|  |  |  |  Antennas:
|  |  |  |  Sensors:
|  |  |  |      RX Codec: A
|  |  |  |  Name: ad9522
|  |  |      RX Dboard: B
|  |  |  |  Antennas:
|  |  |  |  Sensors:
|  |  |  |      RX Codec: B
|  |  |  |  Name: ad9522
|  |  |      TX DSP: 0
|  |  |      TX DSP: 1
|  |  |      TX Dboard: A
|  |  |  |  Antennas:
|  |  |  |  Sensors:
|  |  |  |      TX Codec: A
|  |  |  |  Name: ad9522
|  |  |      TX Dboard: B
|  |  |  |  Antennas:
|  |  |  |  Sensors:
|  |  |  |      TX Codec: B
|  |  |  |  Name: ad9522
aUaU
Thank you!!! :) El mié., 12 dic. 2018 a las 15:42, Robin Coxe (<robin.coxe@ettus.com>) escribió: > You may have multiple versions of GNU Radio and/or UHD libraries still > installed on your PC. Try navigating to the wherever you installed them > (e.g., /usr/local/lib) and deleting the ones you don’t want by hand. > > > > Robin Coxe | Chief R&D Program Manager, SDR | Santa Clara, CA | > 408.610.6363 > > ------------------------------ > *From:* USRP-users <usrp-users-bounces@lists.ettus.com> on behalf of > Carlos Alberto Ruiz Naranjo via USRP-users <usrp-users@lists.ettus.com> > *Sent:* Wednesday, December 12, 2018 4:17 AM > *To:* patchvonbraun@gmail.com > *Cc:* USRP-users@lists.ettus.com > *Subject:* Re: [USRP-users] USRP1 support: "unknown" daughterboard > > Hi Marcus, > > I have changed the version to UHD-3.9.LTS. With *uhd_usrp_probe > --args="type=usrp1" *I haven't erros. But I don't know why the GNURadio > version hasn't changed... I have, with the previous errors : > > *GNU C++ version 7.3.0; Boost_106501; UHD_4.0.0.rfnoc-devel-702-* > *geec24d7b* > > Any idea? > > Thank you. > > El mar., 11 dic. 2018 a las 22:42, Marcus D. Leech via USRP-users (< > usrp-users@lists.ettus.com>) escribió: > >> On 12/11/2018 04:36 PM, Carlos Alberto Ruiz Naranjo via USRP-users wrote: >> > Hello, >> > >> > I have found a USRP1 and I am playing with it. I have this error: >> > >> > carlos@carlos-pc:~$ sudo uhd_usrp_probe --args="type=usrp1" >> > [INFO] [UHD] linux; GNU C++ version 7.3.0; Boost_106501; >> > UHD_4.0.0.rfnoc-devel-702-geec24d7b >> > [INFO] [USRP1] Opening a USRP1 device... >> > [INFO] [USRP1] Using FPGA clock rate of 64.000000MHz... >> > [ERROR] [DBMGR] The daughterboard manager encountered a recoverable >> > error in init. >> > Loading the "unknown" daughterboard implementations to continue. >> > The daughterboard cannot operate until this error is resolved. >> > AssertionError: m and ref_clock/m >= 1e6 and ref_clock/m <= 2.5e6 >> > in double dbsrx::set_lo_freq(double) >> > at /home/carlos/rfnoc/uhd/host/lib/usrp/dboard/db_dbsrx.cpp:305 >> > >> > _____________________________________________________ >> > / >> > | Device: USRP1 Device >> > | _____________________________________________________ >> > | / >> > | | Mboard: USRP1 >> > | | serial: 479b9db3 >> > | | >> > | | Time sources: none >> > | | Clock sources: internal >> > | | Sensors: >> > | | _____________________________________________________ >> > | | / >> > | | | RX DSP: 0 >> > | | | >> > | | | Freq range: -32.000 to 32.000 MHz >> > | | _____________________________________________________ >> > | | / >> > | | | RX DSP: 1 >> > | | | >> > | | | Freq range: -32.000 to 32.000 MHz >> > | | _____________________________________________________ >> > | | / >> > | | | RX Dboard: A >> > | | | ID: DBSRX (0x0002) >> > | | | _____________________________________________________ >> > | | | / >> > | | | | RX Frontend: 0 >> > | | | | Name: Unknown (0xffff) - 0 >> > | | | | Antennas: >> > | | | | Sensors: >> > | | | | Freq range: 0.000 to 0.000 MHz >> > | | | | Gain Elements: None >> > | | | | Bandwidth range: 0.0 to 0.0 step 0.0 Hz >> > | | | | Connection Type: IQ >> > | | | | Uses LO offset: No >> > | | | _____________________________________________________ >> > | | | / >> > | | | | RX Codec: A >> > | | | | Name: ad9522 >> > | | | | Gain range pga: 0.0 to 20.0 step 1.0 dB >> > | | _____________________________________________________ >> > | | / >> > | | | RX Dboard: B >> > | | | _____________________________________________________ >> > | | | / >> > | | | | RX Frontend: 0 >> > | | | | Name: Unknown (0xffff) - 0 >> > | | | | Antennas: >> > | | | | Sensors: >> > | | | | Freq range: 0.000 to 0.000 MHz >> > | | | | Gain Elements: None >> > | | | | Bandwidth range: 0.0 to 0.0 step 0.0 Hz >> > | | | | Connection Type: IQ >> > | | | | Uses LO offset: No >> > | | | _____________________________________________________ >> > | | | / >> > | | | | RX Codec: B >> > | | | | Name: ad9522 >> > | | | | Gain range pga: 0.0 to 20.0 step 1.0 dB >> > | | _____________________________________________________ >> > | | / >> > | | | TX DSP: 0 >> > | | | >> > | | | Freq range: -44.000 to 44.000 MHz >> > | | _____________________________________________________ >> > | | / >> > | | | TX DSP: 1 >> > | | | >> > | | | Freq range: -44.000 to 44.000 MHz >> > | | _____________________________________________________ >> > | | / >> > | | | TX Dboard: A >> > | | | _____________________________________________________ >> > | | | / >> > | | | | TX Frontend: 0 >> > | | | | Name: Unknown (0xffff) - 0 >> > | | | | Antennas: >> > | | | | Sensors: >> > | | | | Freq range: 0.000 to 0.000 MHz >> > | | | | Gain Elements: None >> > | | | | Bandwidth range: 0.0 to 0.0 step 0.0 Hz >> > | | | | Connection Type: IQ >> > | | | | Uses LO offset: No >> > | | | _____________________________________________________ >> > | | | / >> > | | | | TX Codec: A >> > | | | | Name: ad9522 >> > | | | | Gain range pga: -20.0 to 0.0 step 0.1 dB >> > | | _____________________________________________________ >> > | | / >> > | | | TX Dboard: B >> > | | | _____________________________________________________ >> > | | | / >> > | | | | TX Frontend: 0 >> > | | | | Name: Unknown (0xffff) - 0 >> > | | | | Antennas: >> > | | | | Sensors: >> > | | | | Freq range: 0.000 to 0.000 MHz >> > | | | | Gain Elements: None >> > | | | | Bandwidth range: 0.0 to 0.0 step 0.0 Hz >> > | | | | Connection Type: IQ >> > | | | | Uses LO offset: No >> > | | | _____________________________________________________ >> > | | | / >> > | | | | TX Codec: B >> > | | | | Name: ad9522 >> > | | | | Gain range pga: -20.0 to 0.0 step 0.1 dB >> > >> > And the same in GNURadio: >> > >> > Executing: /usr/bin/python2 -u /home/carlos/top_block.py >> > >> > [32;1m[INFO] [UHD] [39;0mlinux; GNU C++ version 7.3.0; Boost_106501; >> > UHD_4.0.0.rfnoc-devel-702-geec24d7b >> > [32;1m[INFO] [USRP1] [39;0mOpening a USRP1 device... >> > [32;1m[INFO] [USRP1] [39;0mUsing FPGA clock rate of 64.000000MHz... >> > [31;0m[ERROR] [DBMGR] [39;0mThe daughterboard manager encountered a >> > recoverable error in init. >> > Loading the "unknown" daughterboard implementations to continue. >> > The daughterboard cannot operate until this error is resolved. >> > AssertionError: m and ref_clock/m >= 1e6 and ref_clock/m <= 2.5e6 >> > in double dbsrx::set_lo_freq(double) >> > at /home/carlos/rfnoc/uhd/host/lib/usrp/dboard/db_dbsrx.cpp:305 >> > >> > [33;1m[WARNING] [MULTI_USRP] [39;0mSetting IQ imbalance compensation >> > is not possible on this device. >> > INFO: Audio sink arch: alsa >> > aUaU >> > >> > >> Try an older release of UHD--does that help? >> >> The DBSRX is ceftainly supported, and if support has gone away, that's >> not design intent as far as I know. >> >> Although, I must point out that the DBSRX was EOLed in favor of the >> DBSRX2 nearly a decade ago, and the USRP1 is itself EOLed... >> >> >> >> _______________________________________________ >> USRP-users mailing list >> USRP-users@lists.ettus.com >> http://lists.ettus.com/mailman/listinfo/usrp-users_lists.ettus.com >> >
