SNIP: Larry wrote:
"In the hypothetical example I used, this three volt difference will
attempt to push 30 amps through the approximately 40 feet of #12 primary
wire connecting the dedicated battery to the main battery/charger. Since
the maximum safe current carrying capacity of #12 wire is 20 amps, the
feeder wires will heat up. This is probably OK if the high current device
is operated for a short period of time and the dedicated battery is fully
charged at the outset."
REPLY: Larry, why not just run #10 wire which is 30 amp wire? The cost
and weight difference between #12 and #10 for 40 feet is not significant.
David Sorenson
Duluth, MN
Hotel pics, info and virtual tours. Click here to book a hotel online.
http://thirdpartyoffers.juno.com/TGL2141/fc/BLSrjpTKDEy15R1kIWOmSehtRVfD3DswLRrIwjKmn9TUuilPzyLtwy0wqWE/
David Sorenson
Duluth, MN
____________________________________________________________
