SS
Stephan Sandenbergh
Tue, Mar 8, 2011 6:46 PM
Hi,
I recently noticed something interesting: The DMTD measurement gives a set
of phase values x(t). From which fractional frequency y(t) is calculable. So
now it seems viable to plot the spectrum, Sy(f) and if you scale it properly
you arrive at Sphi(f). If I'm not making a gross error somewhere the math
seems to check out. But, I'm wondering is there a physical reason why this
isn't valid?
I have not seen this being done anywhere - so I assume there is. However, it
seems possible to plot Sphi(f) for 1Hz < f <100kHz when having a vbeat =
100kHz sampled for 1 second.
I'm familiar with the loose and tight phase-locked methods of measuring
phase noise, but am quite curious to know if phase noise from a DMTD
measurement is a valid assumption.
I would guess that if the frequency domain phase noise measurement requires
phase-lock then the time-domain measurement requires as well. However, here
in lies my real interest - two GPSDOs are phase-locked (not to 1Hz,
something far less I know) so can it be possible to measure GPSDO Adev and
phase-noise using a single DMTD run? Am I making a wrong assumption
somewhere?
Cheers,
Stephan.
Hi,
isn't valid?
somewhere?
Cheers,
Stephan.
BG
Bruce Griffiths
Tue, Mar 8, 2011 7:08 PM
Stephan Sandenbergh wrote:
Hi,
isn't valid?
seems possible to plot Sphi(f) for 1Hz< f<100kHz when having a vbeat =
somewhere?
Cheers,
Stephan.
Aside from the aliasing problem inherent when using a DMTD (The sampling
rate is equal to the beat frequency but the the bandwidth is necessarily
greater than the nyquist limit to permit the DMTD ZCD to work unless of
course one uses a front end bandpass filter - however the associated
phase shift tempco usually precludes this ) the output phase difference
measures also include contributions from the reference source and the
offset source. The contribution from the offset source depends on the
phase difference between the 2 sources being compared. Using a low noise
reference and phase locking the offset to the reference source will help
somewhat as will minimising the phase difference between the reference
and the source under test.
Bruce
> Hi,
> isn't valid?
> somewhere?
> Cheers,
> Stephan.
Bruce
MD
Magnus Danielson
Tue, Mar 8, 2011 8:28 PM
On 03/08/2011 07:46 PM, Stephan Sandenbergh wrote:
Hi,
isn't valid?
somewhere?
An architecture not completely different to the DMTD architecture is
used in phase-noise kits. Instead of having two sources and one
intermediary oscillator is instead there one source and two intermediary
oscillators. The oscillators is locked to the carrier frequency rather
than an offset. The mixed down signal is then cross-correlated to get
the spectrum. Increasing the averaging factor and the spectrum can be
suppressed below that of the intermediary oscillators. Since the two
intermediary oscillators have uncorrelated noise, the external noise is
what correlates over time. This technique is simply called
cross-correlation. Such a cross-correlation setup can run very close to
the carrier in terms of offsets.
In contrast will a DMTD with it's offset frequency be problematic at low
offsets since the positive and negative offsets noise will not occur at
the same frequency in a DMTD setup. Consider a a DMTD with a 10 Hz
offset, pointing a spectrum analyzer on 100 Hz will measure the
down-converted average of carrier+(100-10) Hz and carrier-(100+10) Hz,
thus carrier+90 Hz and carrier-110 Hz.
Creating a mixed-mode setup for phase-noise/DMTD will however be possible.
So, DMTD as such is relatively limited, but add an RF switch and another
oscillator and you get a cross-correlation phase-noise kit.
To turbo-charge the phase-noise kit use a quadrature combiner and
amplitude adjustment to create a interferometric mixdown, working around
part of the mixer limitations. Enrico Rubiola has writen about this
approach.
Cheers,
Magnus
> Hi,
> isn't valid?
> somewhere?
approach.
Cheers,
Magnus
SS
Stephan Sandenbergh
Thu, Mar 10, 2011 8:32 AM
Hi,
So
properly
isn't valid?
it
requires
here
somewhere?
Cheers,
Stephan.
course one uses a front end bandpass filter - however the associated phase
shift tempco usually precludes this ) the output phase difference measures
also include contributions from the reference source and the offset source.
The contribution from the offset source depends on the phase difference
between the 2 sources being compared. Using a low noise reference and phase
locking the offset to the reference source will help somewhat as will
minimising the phase difference between the reference and the source under
test.
Bruce
To unsubscribe, go to
Hi,
This makes sense.
Thanks,
Stephan.
>> Hi,
>> So
>> properly
>> isn't valid?
>> it
>> requires
>> here
>> somewhere?
>> Cheers,
>> Stephan.
> test.
> Bruce
> _______________________________________________
SS
Stephan Sandenbergh
Thu, Mar 10, 2011 8:42 AM
Hi,
Cross-correlation a very clever idea! Thanks for the reference - Rubiola got
some good sources of reference on his home page.
One thing though - for a phase-noise kit one will probably need to replace
the ZCD with a low-noise amplification stage of around 80dB to be to allow
sampling at ADC voltage levels?
Cheers,
Stephan.
Hi,
So
properly
isn't valid?
it
requires
here
somewhere?
An architecture not completely different to the DMTD architecture is used
in phase-noise kits. Instead of having two sources and one intermediary
oscillator is instead there one source and two intermediary oscillators. The
oscillators is locked to the carrier frequency rather than an offset. The
mixed down signal is then cross-correlated to get the spectrum. Increasing
the averaging factor and the spectrum can be suppressed below that of the
intermediary oscillators. Since the two intermediary oscillators have
uncorrelated noise, the external noise is what correlates over time. This
technique is simply called cross-correlation. Such a cross-correlation setup
can run very close to the carrier in terms of offsets.
offsets since the positive and negative offsets noise will not occur at the
same frequency in a DMTD setup. Consider a a DMTD with a 10 Hz offset,
pointing a spectrum analyzer on 100 Hz will measure the down-converted
average of carrier+(100-10) Hz and carrier-(100+10) Hz, thus carrier+90 Hz
and carrier-110 Hz.
To turbo-charge the phase-noise kit use a quadrature combiner and amplitude
adjustment to create a interferometric mixdown, working around part of the
mixer limitations. Enrico Rubiola has writen about this approach.
Cheers,
Magnus
Hi,
Cheers,
Stephan.
>> Hi,
>> So
>> properly
>> isn't valid?
>> it
>> requires
>> here
>> somewhere?
> and carrier-110 Hz.
> Cheers,
> Magnus
BG
Bruce Griffiths
Thu, Mar 10, 2011 8:44 AM
If you can solve the aliasing problem then its easy to average the noise
at frequencies fbeat-foffset and fbeat+foffset to synthesize the
measured phase noise values with a beat frequency of 0 Hz as would be
measured by a conventional phase measurement setup.
Bruce
Hi,
So
properly
isn't valid?
it
requires
here
somewhere?
Cheers,
Stephan.
test.
Bruce
Bruce
> Hi,
> This makes sense.
> Thanks,
> Stephan.
>>> Hi,
>>> So
>>> properly
>>> isn't valid?
>>> it
>>> requires
>>> here
>>> somewhere?
>>> Cheers,
>>> Stephan.
>> test.
>> Bruce
BG
Bruce Griffiths
Thu, Mar 10, 2011 8:50 AM
For conventional phase noise measurements at offsets in the (10Hz,
20kHz) range one can use a sound card with a low noise preaamp.
Suitable sound card preamps with lower noise floors than Enrico's or
Wenzel's designs can be built using readily available components.
Wider bandwidths ( up to 1MHz or so) are not difficult to achieve.
Bruce
Hi,
Cheers,
Stephan.
Hi,
So
properly
isn't valid?
it
requires
here
somewhere?
and carrier-110 Hz.
Cheers,
Magnus
Bruce
> Hi,
> Cheers,
> Stephan.
>>> Hi,
>>> So
>>> properly
>>> isn't valid?
>>> it
>>> requires
>>> here
>>> somewhere?
>> and carrier-110 Hz.
>> Cheers,
>> Magnus
> To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts
SS
Stephan Sandenbergh
Thu, Mar 10, 2011 1:12 PM
Hi,
Thanks this is good advice.
Pointing the spectrum analyzer to fc + delta seems to be similar
than deducing phase noise from the ZCD output since this would be with
reference to (fc + delta) in any how? Provided the aliasing issue can be
sorted.
Regarding the aliasing issue - in order to plot phase noise up to 100kHz I
would use a 300kHz beat sampled at 100MHz (which is the sampling system I
got available). Obviously, making sure I have sufficient bandwidth in all
areas.
Cheers.
Stephan.
On 10 March 2011 10:50, Bruce Griffiths bruce.griffiths@xtra.co.nz wrote:
For conventional phase noise measurements at offsets in the (10Hz, 20kHz)
Bruce
Hi,
got
Cheers,
Stephan.
Hi,
set
calculable.
So
properly
math
this
isn't valid?
However,
it
requires
here
and
somewhere?
The
Increasing
setup
the
Hz
and carrier-110 Hz.
possible.
amplitude
the
Cheers,
Magnus
Hi,
sorted.
areas.
Cheers.
Stephan.
> Bruce
>> Hi,
>> got
>> Cheers,
>> Stephan.
>>>> Hi,
>>>> set
>>>> calculable.
>>>> So
>>>> properly
>>>> math
>>>> this
>>>> isn't valid?
>>>> However,
>>>> it
>>>> requires
>>>> here
>>>> and
>>>> somewhere?
>>> The
>>> Increasing
>>> setup
>>> the
>>> Hz
>>> and carrier-110 Hz.
>>> possible.
>>> amplitude
>>> the
>>> Cheers,
>>> Magnus
SS
Stephan Sandenbergh
Thu, Mar 10, 2011 1:16 PM
Thanks,
I'm familiar with the designs you posted to measure voltage noise ect. on
you home page. These, with some modification, mainly removing the blocking
caps, seems that it would do the trick.
Cheers,
Stephan.
Bruce
Hi,
got
Cheers,
Stephan.
Hi,
set
calculable.
So
properly
math
this
isn't valid?
However,
it
requires
here
and
somewhere?
The
Increasing
setup
the
Hz
and carrier-110 Hz.
possible.
amplitude
the
Cheers,
Magnus
Thanks,
Cheers,
Stephan.
> Bruce
>> Hi,
>> got
>> Cheers,
>> Stephan.
>>>> Hi,
>>>> set
>>>> calculable.
>>>> So
>>>> properly
>>>> math
>>>> this
>>>> isn't valid?
>>>> However,
>>>> it
>>>> requires
>>>> here
>>>> and
>>>> somewhere?
>>> The
>>> Increasing
>>> setup
>>> the
>>> Hz
>>> and carrier-110 Hz.
>>> possible.
>>> amplitude
>>> the
>>> Cheers,
>>> Magnus
BG
Bruce Griffiths
Thu, Mar 10, 2011 6:36 PM
Hi,
sorted.
areas.
The definition requires that both the noise at fc + delta and the noise
at fc-delta be added to obtain the phase noise at an offset of delta.
This is easy to do either in an FPGA or in post processing.
If you are sampling at 100MHz then the post mixer filter only need limit
the bandwidth sufficiently to eliminate the mixer sum product and keep
the noise signal within the bandwidth of the following amplifier.
Additional filtering if required can be implemented as digital filters.
Note with a 300kHz beat frequency phase noise components at offsets
greater than fcarrier + 300KHz will be folded into the mixer output
spectrum so using a carrier bandpass filter with a bandwidth smaller
than the beat frequency may be advisable.
Bruce
Hi,
got
Cheers,
Stephan.
Hi,
set
calculable.
So
properly
math
this
isn't valid?
However,
it
requires
here
and
somewhere?
The
Increasing
setup
the
Hz
and carrier-110 Hz.
possible.
amplitude
the
Cheers,
Magnus
> Hi,
> sorted.
> areas.
> Cheers.
> Stephan.
Bruce
>> Bruce
>>> Hi,
>>> got
>>> Cheers,
>>> Stephan.
>>>>> Hi,
>>>>> set
>>>>> calculable.
>>>>> So
>>>>> properly
>>>>> math
>>>>> this
>>>>> isn't valid?
>>>>> However,
>>>>> it
>>>>> requires
>>>>> here
>>>>> and
>>>>> somewhere?
>>>> The
>>>> Increasing
>>>> setup
>>>> the
>>>> Hz
>>>> and carrier-110 Hz.
>>>> possible.
>>>> amplitude
>>>> the
>>>> Cheers,
>>>> Magnus
