trawlers@lists.trawlering.com
TRAWLERS & TRAWLERING LIST
TWL: TWL Oil, Fuel, TBN, and other stuff
A
almiller@n-jcenter.com
Sun, Jun 10, 2001 3:27 PM
Based on CaptnWil recommending synthetic oil and his endorsement of Mobil
Delvac 1, I spent some time speaking with engineers and industry experts --
everyone I spoke with said that Mobil Delvac 1 was probably the best marine
diesel engine oil that money could buy.
When I spoke with Mobil, they referred me to the following web site which
gave the following test characteristics for Mobil Delvac 1
http://dallnd6.dal.mobil.com/gis/MobilPDS.nsf/938dd40f165c0309862566660070e8
7c/022b5cb5b179a4eb8525670b0059271d?OpenDocument
Typical Characteristics
Test Method  Mobil
Delvac 1 SHC
SAE Grade -                                                          5W-40
Viscosity cSt at 40 oC                          D445      87.9
Viscosity cSt at 100 oC                        D445      14.5
CCS Viscosity, Poise @ -25 oC        D5293    31.7
MRV Viscosity, Poise/PA @ -30 oC  D4684    94/<35
Viscosity Index                                      D2270    172
Sulfated Ash,%                                      D874        1.8
Total Base Number                              D2896      15.9
Pour Point, oC                                      D97          <-54
Flash Point, oC                                      D92          226
I am not sure what all of the these numbers mean -- however, an engineer at
Mobil told me that Mobil Tri-Synthetic Motor Oils are very similar in test
results. He recommended Mobil Tri-Synthetic 15W-50 for my American Diesel
6N140. He said that I could safely double the oil change interval suggested
by the engine manufacturer.
I haven't changed from using a straight 40 weight oil recommended by Bob
Smith -- but I would appreciate hearing comments by those on the list that
are more expert in this area.
Thanks
Al
Palm Coast, Florida
Pacific Trawler 37
Based on CaptnWil recommending synthetic oil and his endorsement of Mobil Delvac 1, I spent some time speaking with engineers and industry experts -- everyone I spoke with said that Mobil Delvac 1 was probably the best marine diesel engine oil that money could buy. When I spoke with Mobil, they referred me to the following web site which gave the following test characteristics for Mobil Delvac 1 http://dallnd6.dal.mobil.com/gis/MobilPDS.nsf/938dd40f165c0309862566660070e8 7c/022b5cb5b179a4eb8525670b0059271d?OpenDocument Typical Characteristics Test Method Mobil Delvac 1 SHC SAE Grade - 5W-40 Viscosity cSt at 40 oC D445 87.9 Viscosity cSt at 100 oC D445 14.5 CCS Viscosity, Poise @ -25 oC D5293 31.7 MRV Viscosity, Poise/PA @ -30 oC D4684 94/<35 Viscosity Index D2270 172 Sulfated Ash,% D874 1.8 Total Base Number D2896 15.9 Pour Point, oC D97 <-54 Flash Point, oC D92 226 I am not sure what all of the these numbers mean -- however, an engineer at Mobil told me that Mobil Tri-Synthetic Motor Oils are very similar in test results. He recommended Mobil Tri-Synthetic 15W-50 for my American Diesel 6N140. He said that I could safely double the oil change interval suggested by the engine manufacturer. I haven't changed from using a straight 40 weight oil recommended by Bob Smith -- but I would appreciate hearing comments by those on the list that are more expert in this area. Thanks Al Palm Coast, Florida Pacific Trawler 37
