Re: [USRP-users] [Discuss-gnuradio] Bandpass Sampling
MM
Marcus Müller
Thu, Dec 11, 2014 4:03 PM
www.ni.com/white-paper/14311/en/
Greetings,
Marcus
On 12/11/2014 04:54 PM, Richard Bell wrote:
That's perfect. Thanks a lot. I'm curious to know where this document came
from, so I can help myself later. Can you tell me?
v/r,
Rich
On Tue, Dec 9, 2014 at 8:52 AM, Marcus Müller marcus.mueller@ettus.com
wrote:
Hi Ian,
thanks, I was looking for that.
Richard: Everything left of the ADC/DAC is on the WBX daughterboard.
Greetings,
Marcus
On 12/09/2014 05:41 PM, Ian Buckley wrote:
Block diagram USRP N210 + WBX:
On Dec 9, 2014, at 8:24 AM, Marcus Müller via USRP-users <
Hi Richard,
it's a 300+-page PDF file, which works quite well on any computer that
I tried -- maybe you need to wait a second for your PC to load that
document?
It doesn't contain a block diagram of the WBX, however.
Greetings,
Marcus
On 12/09/2014 02:00 AM, Richard Bell wrote:
I've seen the the UHD manual but not the performance measures doc. It
is
not opening for me. If it has a block diagram of the WBX board, then
that
is what I was looking for.
There is no more information I need at this time. Your previous answer
was
helpful and what I was looking for.
Yes you can move this to the usrp list.
Thanks again,
Rich
On Mon, Dec 8, 2014 at 12:24 PM, Marcus Müller <
wrote:
There's so much Marcus in here ;) so here's my answer: usually,
you'd use
the USRP+WBX as direct conversion receiver, not an IF one.
Regarding WBX documentation: have you seen the performance
measurements
[1], and the UHD manual [2]?
Is there some specific information you're missing?
Best regards,
Marcus
PS: if you'd agree, I'd like to shift this discussion to
usrp-users@lists.ettus.com .
[1] http://files.ettus.com/performance_data/wbx/
[2] http://files.ettus.com/manual/page_dboards.html#dboards_wbx
On 12/08/2014 08:57 PM, Richard Bell wrote:
I think Marcus answered my question. Thank you.
On Mon, Dec 8, 2014 at 11:53 AM, Richard Bell <
wrote:
I'm apologize. I am using a WBX card.
I forgot to mention that I've been looking for a datasheet for the
WBX,
but all I can find is the PCB schematic doc on the ettus website which
isn't very useful. So I don't know what the IF frequency coming out
of the
WBX is. Does the WBX tune itself given the UHD source settings so
that the
IF it produces is proper for the USRP ADC?
Rich
On Mon, Dec 8, 2014 at 11:28 AM, mleech@ripnet.com <
The N2xx series use a fixed sample rate, so there's no "deciding
what
sample rate to use based on Fc".
There's also the analog bandwidth of the ADC to consider.  If you
aren't
going to use a downconverter card, then the analog bandwidth of the
ADC
will start to roll-off at some point, so even if you narrowband
filter your
input signal to remove aliasing possibilities, you will end up in the
roll-off skirts of the analog bandwidth of the ADC.
Is there some reason not to use a downconverter card, like the WBX for
your application?
On 2014-12-08 14:23, Richard Bell wrote:
I have a binary FSK signal centered at 300 MHz with 160 kHz offset
peaks from the center freak. Therefore the lowest signal frequency of
interest is 300-0.16 = 299.84 MHz and the highest is 300.16 MHz.
I know the maximum sampling rate of the USRPN210 ADC is 100 MSPS. If
the
USRP uses that sample rate of 100 MSPS, it will alias my signal onto
itself
in an unwanted manor.
My question is, how does the USRPN210 decide what sample rate to set
the
ADC to? Is it a function of both the center frequency and the sample
rate
setting of the UHD source block?
Thanks,
Rich
Discuss-gnuradio mailing listDiscuss-gnuradio@gnu.orghttps://
lists.gnu.org/mailman/listinfo/discuss-gnuradio
www.ni.com/white-paper/14311/en/ Greetings, Marcus On 12/11/2014 04:54 PM, Richard Bell wrote: > That's perfect. Thanks a lot. I'm curious to know where this document came > from, so I can help myself later. Can you tell me? > > v/r, > Rich > > On Tue, Dec 9, 2014 at 8:52 AM, Marcus Müller <marcus.mueller@ettus.com> > wrote: > >> Hi Ian, >> thanks, I was looking for that. >> Richard: Everything left of the ADC/DAC is on the WBX daughterboard. >> >> Greetings, >> Marcus >> >> On 12/09/2014 05:41 PM, Ian Buckley wrote: >>> Block diagram USRP N210 + WBX: >>> >>> >> http://www.ni.com/white-paper/app/largeimage?lang=en&imageurl=%2Fcms%2Fimages%2Fdevzone%2Ftut%2FUSRP_Advanced_Diagram_smaller.png >>> On Dec 9, 2014, at 8:24 AM, Marcus Müller via USRP-users < >> usrp-users@lists.ettus.com> wrote: >>>> Hi Richard, >>>> it's a 300+-page PDF file, which works quite well on any computer that >> I tried -- maybe you need to wait a second for your PC to load that >> document? >>>> It doesn't contain a block diagram of the WBX, however. >>>> >>>> Greetings, >>>> Marcus >>>> >>>> On 12/09/2014 02:00 AM, Richard Bell wrote: >>>>> I've seen the the UHD manual but not the performance measures doc. It >> is >>>>> not opening for me. If it has a block diagram of the WBX board, then >> that >>>>> is what I was looking for. >>>>> >>>>> There is no more information I need at this time. Your previous answer >> was >>>>> helpful and what I was looking for. >>>>> >>>>> Yes you can move this to the usrp list. >>>>> >>>>> Thanks again, >>>>> Rich >>>>> >>>>> On Mon, Dec 8, 2014 at 12:24 PM, Marcus Müller < >> marcus.mueller@ettus.com> >>>>> wrote: >>>>> >>>>>> There's so much Marcus in here ;) so here's my answer: usually, >> you'd use >>>>>> the USRP+WBX as direct conversion receiver, not an IF one. >>>>>> >>>>>> Regarding WBX documentation: have you seen the performance >> measurements >>>>>> [1], and the UHD manual [2]? >>>>>> >>>>>> Is there some specific information you're missing? >>>>>> >>>>>> Best regards, >>>>>> Marcus >>>>>> >>>>>> PS: if you'd agree, I'd like to shift this discussion to >>>>>> usrp-users@lists.ettus.com . >>>>>> >>>>>> [1] http://files.ettus.com/performance_data/wbx/ >>>>>> [2] http://files.ettus.com/manual/page_dboards.html#dboards_wbx >>>>>> >>>>>> >>>>>> On 12/08/2014 08:57 PM, Richard Bell wrote: >>>>>> >>>>>> I think Marcus answered my question. Thank you. >>>>>> >>>>>> On Mon, Dec 8, 2014 at 11:53 AM, Richard Bell < >> richard.bell4@gmail.com> <richard.bell4@gmail.com> >>>>>> wrote: >>>>>> >>>>>> >>>>>> I'm apologize. I am using a WBX card. >>>>>> >>>>>> I forgot to mention that I've been looking for a datasheet for the >> WBX, >>>>>> but all I can find is the PCB schematic doc on the ettus website which >>>>>> isn't very useful. So I don't know what the IF frequency coming out >> of the >>>>>> WBX is. Does the WBX tune itself given the UHD source settings so >> that the >>>>>> IF it produces is proper for the USRP ADC? >>>>>> >>>>>> Rich >>>>>> >>>>>> On Mon, Dec 8, 2014 at 11:28 AM, <mleech@ripnet.com> < >> mleech@ripnet.com> wrote: >>>>>> >>>>>> The N2xx series use a fixed sample rate, so there's no "deciding >> what >>>>>> sample rate to use based on Fc". >>>>>> >>>>>> There's also the analog bandwidth of the ADC to consider. If you >> aren't >>>>>> going to use a downconverter card, then the analog bandwidth of the >> ADC >>>>>> will start to roll-off at some point, so even if you narrowband >> filter your >>>>>> input signal to remove aliasing possibilities, you will end up in the >>>>>> roll-off skirts of the analog bandwidth of the ADC. >>>>>> >>>>>> Is there some reason not to use a downconverter card, like the WBX for >>>>>> your application? >>>>>> >>>>>> >>>>>> >>>>>> >>>>>> >>>>>> >>>>>> On 2014-12-08 14:23, Richard Bell wrote: >>>>>> >>>>>> I have a binary FSK signal centered at 300 MHz with 160 kHz offset >>>>>> peaks from the center freak. Therefore the lowest signal frequency of >>>>>> interest is 300-0.16 = 299.84 MHz and the highest is 300.16 MHz. >>>>>> >>>>>> I know the maximum sampling rate of the USRPN210 ADC is 100 MSPS. If >> the >>>>>> USRP uses that sample rate of 100 MSPS, it will alias my signal onto >> itself >>>>>> in an unwanted manor. >>>>>> >>>>>> My question is, how does the USRPN210 decide what sample rate to set >> the >>>>>> ADC to? Is it a function of both the center frequency and the sample >> rate >>>>>> setting of the UHD source block? >>>>>> >>>>>> Thanks, >>>>>> Rich >>>>>> >>>>>> _______________________________________________ >>>>>> Discuss-gnuradio mailing listDiscuss-gnuradio@gnu.orghttps:// >> lists.gnu.org/mailman/listinfo/discuss-gnuradio >>>>>> >>>>>> >>>>>> _______________________________________________ >>>>>> Discuss-gnuradio mailing listDiscuss-gnuradio@gnu.orghttps:// >> lists.gnu.org/mailman/listinfo/discuss-gnuradio >>>>>> >>>>>> >>>>>> _______________________________________________ >>>>>> Discuss-gnuradio mailing list >>>>>> Discuss-gnuradio@gnu.org >>>>>> https://lists.gnu.org/mailman/listinfo/discuss-gnuradio >>>>>> >>>>>> >>>>> _______________________________________________ >>>>> Discuss-gnuradio mailing list >>>>> Discuss-gnuradio@gnu.org >>>>> https://lists.gnu.org/mailman/listinfo/discuss-gnuradio >>>> _______________________________________________ >>>> USRP-users mailing list >>>> USRP-users@lists.ettus.com >>>> http://lists.ettus.com/mailman/listinfo/usrp-users_lists.ettus.com >>
