trawlers@lists.trawlering.com
TRAWLERS & TRAWLERING LIST
TWL: Leaking Water Tank
JH
Jim Hamlin
Mon, Feb 2, 2004 5:49 PM
Looking for a possible "easy" fix to a slow leak in a 250 gal. water tank.
It's on an old wooden Grand Banks ('74), and I can't tell if it's made of
aluminum or stainless.  Slow seeping leak somewhere along the base, where the
weld is, but can't get to it for an external repair without tearing the engine
compartment apart.  (Or worse yet, cutting into ribs, etc. for an exit thru
the hull!)  Has anyone been successful with any of the sealant materials you
pour into the tank?  This tank has an inspection plate, but with all the
internal baffles,  the inner/lower corners aren't even visable with the plate
off.  Thanx in advance for any suggestions.
Looking for a possible "easy" fix to a slow leak in a 250 gal. water tank. It's on an old wooden Grand Banks ('74), and I can't tell if it's made of aluminum or stainless. Slow seeping leak somewhere along the base, where the weld is, but can't get to it for an external repair without tearing the engine compartment apart. (Or worse yet, cutting into ribs, etc. for an exit thru the hull!) Has anyone been successful with any of the sealant materials you pour into the tank? This tank has an inspection plate, but with all the internal baffles, the inner/lower corners aren't even visable with the plate off. Thanx in advance for any suggestions.
JA
Jim Alexander
Mon, Feb 2, 2004 10:40 PM
Jim, Can you get to the top of the tank in such a way as to remove a large
portion of it?  I repaired a couple of tanks on a previous sail boat by
cutting about a 2'x3' hole in the top, these were aluminum tanks.  After
cutting the large holes I was able to remove the baffles and then I was
able to seal up the tanks using marine-tex followed by painting with a
product called "glove-it" which is available at West Marine.  Then I sealed
up the tanks using pieces of 1/2" Lexan which were cut to overlap the holes
by about 2" around.  I drilled pilot holes into both the Lexan and the
tanks and then treaded the aluminum to accept 1/4x20 stainless
screws.  Space the screws about every two inches. Then re-drill the holes
in the Lexan with a 9/32 bit to allow for expansion so that you will not
get cracks at the holes.  Seal all around with silicone sealant and screw
the top into place (after replacing the baffles), you now have not only a
permanent inspection and repair hole, but one that allows visual inspection
of the tank as well.
Jim Alexander, Realtor
Boatless again (but not for long)
Port Charlotte, FL
At 12:49 PM 2/2/04 -0500, you wrote: >Looking for a possible "easy" fix to a slow leak in a 250 gal. water tank. >It's on an old wooden Grand Banks ('74), and I can't tell if it's made of >aluminum or stainless. Slow seeping leak somewhere along the base, where the >weld is, but can't get to it for an external repair without tearing the engine >compartment apart. (Or worse yet, cutting into ribs, etc. for an exit thru >the hull!) Has anyone been successful with any of the sealant materials you >pour into the tank? This tank has an inspection plate, but with all the >internal baffles, the inner/lower corners aren't even visable with the plate >off. Thanx in advance for any suggestions. >_______________________________________________ Jim, Can you get to the top of the tank in such a way as to remove a large portion of it? I repaired a couple of tanks on a previous sail boat by cutting about a 2'x3' hole in the top, these were aluminum tanks. After cutting the large holes I was able to remove the baffles and then I was able to seal up the tanks using marine-tex followed by painting with a product called "glove-it" which is available at West Marine. Then I sealed up the tanks using pieces of 1/2" Lexan which were cut to overlap the holes by about 2" around. I drilled pilot holes into both the Lexan and the tanks and then treaded the aluminum to accept 1/4x20 stainless screws. Space the screws about every two inches. Then re-drill the holes in the Lexan with a 9/32 bit to allow for expansion so that you will not get cracks at the holes. Seal all around with silicone sealant and screw the top into place (after replacing the baffles), you now have not only a permanent inspection and repair hole, but one that allows visual inspection of the tank as well. Jim Alexander, Realtor Boatless again (but not for long) Port Charlotte, FL
CC
Charles Culotta
Tue, Feb 3, 2004 12:09 AM
49 AM
Subject: TWL: Leaking Water Tank
engine
compartment apart.
pour into the tank?
Jim,
Been there  done that.
The following  is a copy of a post  that I made several yrs. ago.
I did the repair yrs ago and have had no additional leaks since.
There are several articles on my web page involving leak repair to :
Windows, Teak Decks , Fuel Tanks and the like.
CCC
M/V CC RIDER
CHARLES C. and PAT CULOTTA, Jr.
Patterson, La.
http://www.geocities.com/charlesculotta/
Message:
Stainless Steel Water Tank Leak
"What a bummer, I had one recently. Note the past tense. Fortunately I
could get to one side of the stainless steel tank that had two small
leaks. Since it is a ss tank they were in the weld. The other was a
whole different scene as it was against a bulkhead on the far side of
the tank. Moving the tank would be a big problem even the few inches
required. The tank is 26" frt to back 29" high and 48 inches long with
an inspection hatch midway on the long side it is 7" in diameter.
After much thought measuring and commiserating with friends the
consensus was that I use a product called SPLASH ZONE by Devoe Co. It is
an epoxy resin, 2 part.
I have used it often in the past and had some on hand . It's shelf life
seems interminable as my cans of it are over 6 yrs old!
Any way it is the consistency of stiff putty, one black and the other
white. These are mixed equally in your hand.
It is applied with your fingers as this gives excellent control or with
a putty knife this project req finger work! I rubbed it onto the seams
of the tank all around I mean really put it on there as there was no
need for pretty work here just cover every bit as I could not see where
the leak was on one part of the tank.
Note that this stuff hardens like steel and is then treated as such. It
can be ground ,drilled filed and painted if need be. It adheres to
almost any surface glass, steel , ss , alum. fiberglass and the like.
Given the dimensions of the tank I was able to reach all seems except
the top far corners , so I just applied it to the OUTSIDE of the tank.
With its adhering properties this was no problem. END OF LEAKS
A friend of mine had a commercial wood fishing boat that developed a
leak under water, a diver went down and applied it UNDER WATER it held
for years.
CCRIDER , my trawler ,sustained a deck leak , a hole 15 inches long and
5 inches wide during Hurricane Andrew . While it was still pouring
rain I applied SPLASH ZONE and it held until I could get the boat to a
ship yd months later. This is one of its greatest attributes , that it
can be applied to a wet surface.
There are similar products on the mkt such as JB WELD that comes in very
small tubes. S. Z. is packaged in 1 gal cans and I think 1 qt cans , Of
course you need one of each. A qt goes a long way as I probably used
about 1 pint or so on this 130 gal tank.
I have kept it on hand for my various boats for over 20 yrs.
There was a fitting on top of one of my diesel tanks that was
impossible to get to and it would drip a small amt of fuel when the tank
was completely full so I puttied around it with S.Z. and end of leak.
That was 12 yrs ago.
As to the handling of the product I usually wear surgical gloves but it
is not really necessary just makes cleanup faster. By the way clean up
is with water just wash your hands! If you let it dry on your skin you
must rub harder.
Keep your hands wet while working the product and it will not stick to
your hands Just like using silicon sealant.
This is grt stuff and I highly recommend it. I am not a dealer , or any
thing else! If you desire more info email me off list.
49 AM Subject: TWL: Leaking Water Tank > Looking for a possible "easy" fix to a slow leak in a 250 gal. water tank. Slow seeping leak somewhere along the base, where the > weld is, but can't get to it for an external repair without tearing the engine > compartment apart. Has anyone been successful with any of the sealant materials you > pour into the tank? Jim, Been there done that. The following is a copy of a post that I made several yrs. ago. I did the repair yrs ago and have had no additional leaks since. There are several articles on my web page involving leak repair to : Windows, Teak Decks , Fuel Tanks and the like. CCC M/V CC RIDER CHARLES C. and PAT CULOTTA, Jr. Patterson, La. http://www.geocities.com/charlesculotta/ Message: Stainless Steel Water Tank Leak "What a bummer, I had one recently. Note the past tense. Fortunately I could get to one side of the stainless steel tank that had two small leaks. Since it is a ss tank they were in the weld. The other was a whole different scene as it was against a bulkhead on the far side of the tank. Moving the tank would be a big problem even the few inches required. The tank is 26" frt to back 29" high and 48 inches long with an inspection hatch midway on the long side it is 7" in diameter. After much thought measuring and commiserating with friends the consensus was that I use a product called SPLASH ZONE by Devoe Co. It is an epoxy resin, 2 part. I have used it often in the past and had some on hand . It's shelf life seems interminable as my cans of it are over 6 yrs old! Any way it is the consistency of stiff putty, one black and the other white. These are mixed equally in your hand. It is applied with your fingers as this gives excellent control or with a putty knife this project req finger work! I rubbed it onto the seams of the tank all around I mean really put it on there as there was no need for pretty work here just cover every bit as I could not see where the leak was on one part of the tank. Note that this stuff hardens like steel and is then treated as such. It can be ground ,drilled filed and painted if need be. It adheres to almost any surface glass, steel , ss , alum. fiberglass and the like. Given the dimensions of the tank I was able to reach all seems except the top far corners , so I just applied it to the OUTSIDE of the tank. With its adhering properties this was no problem. END OF LEAKS A friend of mine had a commercial wood fishing boat that developed a leak under water, a diver went down and applied it UNDER WATER it held for years. CCRIDER , my trawler ,sustained a deck leak , a hole 15 inches long and 5 inches wide during Hurricane Andrew . While it was still pouring rain I applied SPLASH ZONE and it held until I could get the boat to a ship yd months later. This is one of its greatest attributes , that it can be applied to a wet surface. There are similar products on the mkt such as JB WELD that comes in very small tubes. S. Z. is packaged in 1 gal cans and I think 1 qt cans , Of course you need one of each. A qt goes a long way as I probably used about 1 pint or so on this 130 gal tank. I have kept it on hand for my various boats for over 20 yrs. There was a fitting on top of one of my diesel tanks that was impossible to get to and it would drip a small amt of fuel when the tank was completely full so I puttied around it with S.Z. and end of leak. That was 12 yrs ago. As to the handling of the product I usually wear surgical gloves but it is not really necessary just makes cleanup faster. By the way clean up is with water just wash your hands! If you let it dry on your skin you must rub harder. Keep your hands wet while working the product and it will not stick to your hands Just like using silicon sealant. This is grt stuff and I highly recommend it. I am not a dealer , or any thing else! If you desire more info email me off list.
K
Keith
Tue, Feb 3, 2004 11:19 AM
I think I saw this originally in Passagemaker, but it may have been in
another boating rag. http://www.microleak.com/brochnew.htm. It's a solvent
based sealer that you can pour or spray, and is OK for potable water
systems.
Keith
__
"Application denied.  One cannot fertilize with flatus."
-Abraham Lincoln, on rejecting homeopathic medications for the
dispensary of the US troops.
----- Original Message -----
tank.
weld is,
I think I saw this originally in Passagemaker, but it may have been in another boating rag. http://www.microleak.com/brochnew.htm. It's a solvent based sealer that you can pour or spray, and is OK for potable water systems. Keith __ "Application denied. One cannot fertilize with flatus." -Abraham Lincoln, on rejecting homeopathic medications for the dispensary of the US troops. ----- Original Message ----- > > > Looking for a possible "easy" fix to a slow leak in a 250 gal. water tank. > Slow seeping leak somewhere along the base, where the > > weld is,
