Someone a while back made the observation that a "dry wall router" with a
"very dull" 1/8th inch drill bit could be used to clean out caulking when
re-doing teak decks. I had never heard of such a router but have come to
believe that they were talking about a rotozip type tool. Can the rotozip
be used for such purposes? Is there a better "dry wall router" around for
re-doing teak decks?
dick jurgensen
To: trawler-world-list@samurai.com
Subject: Re: Rotozip Tool
Date: Tuesday, July 06, 1999 11:33 AM
I own a rotozip tool. I have used it mostly on dry wall and some on
plaster
and tile. It works well for its designed applications. I have also used
it
on fiberglass. I find that on tougher materials that the saber saw or
sawzall is better. The problem with the rotozip is that the bearings are
not
designed for heavy side loading, and that the cooling is marginal. I
have
had to disassemble mine several times to clean out the interior, the
cooling
blades began hitting the housing and I had to make slight modifications.
For
really heavy grinding I find an air driven die grinder much better. They
are
in expensive (about $19) run cool and have lots of power. Mine air
grinder
has colletts for 1/8 and 1/4 bits. Also the air grinder speed is
controlable. Only problem is you need a decent compressor and tank. I
first
used one at the shipyard which has air at each stall. I liked it so much
I
got a 5 hp compressor with 15 gallon tank (I do use many other air tools
now).
Bob Austin
Symbol 42
Pensacola, FL
