View all threadsHello,
I'm trying to achieve a constant phase offset with multiple X310s each
using a UBX160 daughter card. My procedure is as follows:
The behavior I have seen is that the phase difference between radios is
constant only when using a low center frequency (tested on 40 MHz fc, 1 MHz
Fs). At 2.4 GHz and 920 Mhz the phase drifts between runs. Does anyone have
any insight into why this would be the case?
Things I have tried:
The UHD version is source built 3.13.0
https://github.com/EttusResearch/uhd/commit/f114cfa0ddf70228d10462758c2b8e878c993f5d
from git and I have rebuilt the FPGA image with these commits added:
https://github.com/EttusResearch/fpga/commit/205747dee8e73ec15f521e9363337c8c03582d91
https://github.com/EttusResearch/fpga/commit/0b2364653405612a6d5dfaa0e69b1c6798771e6d
I'm also going to try using the most up-to-date 3.14.1.0 release.
Mitchell J Grabner, PhD
Member, IEEE Communications Society
IEEE-HKN Lambda Zeta Chapter
My Linkedin http://www.linkedin.com/pub/mitch-grabner/43/23b/bb5
On 07/31/2019 09:38 AM, Mitch Grabner via USRP-users wrote:
Hello,
is constant only when using a low center frequency (tested on 40 MHz
fc, 1 MHz Fs). At 2.4 GHz and 920 Mhz the phase drifts between runs.
Does anyone have any insight into why this would be the case?
The UHD version is source built 3.13.0||||
Thanks,
Let us know whether the 3.14.1.0 release helps.
I'm a bit surprised by the problem showing up on the higher bands,
because below 500MHz, there are TWO layers of synthesizers and mixers
involved--you'd expect phase-coherence problems to be more likely in
that case.
The LOs have phase-reset features, which I'm fairly-sure are actually
implemented.
What is the magnitude of the phase offset in the high-band case?
