time-nuts@lists.febo.com
1PPS users?
BS
Bob Stewart
Sun, Dec 18, 2016 11:16 PM
One thing I've never really understood is who actually uses the high-quality 1PPS output from a GPSDO.  I have spent a lot of time, effort, and money on developing my GPSDO without a whole of thought to the user base.  It was just a quest for the best result I could obtain with a particular technology.  The frequency standard users was a no brainer.  Everyone who wants a frequency standard eventually understands they need to get a GPSDO, or an Rb, or a Cs.  And that's all I thought I had: a good frequency standard.  And then Tom prodded me a bit and showed me the shortcomings of what I was doing, and I did something about it.  So, if an NTP user can get his time fix directly from a noisy receiver, who actually needs a time-accurate, low jitter 1PPS pulse?
Bob - AE6RV
AE6RV.com
GFS GPSDO list:
groups.yahoo.com/neo/groups/GFS-GPSDOs/info
One thing I've never really understood is who actually uses the high-quality 1PPS output from a GPSDO.  I have spent a lot of time, effort, and money on developing my GPSDO without a whole of thought to the user base.  It was just a quest for the best result I could obtain with a particular technology.  The frequency standard users was a no brainer.  Everyone who wants a frequency standard eventually understands they need to get a GPSDO, or an Rb, or a Cs.  And that's all I thought I had: a good frequency standard.  And then Tom prodded me a bit and showed me the shortcomings of what I was doing, and I did something about it.  So, if an NTP user can get his time fix directly from a noisy receiver, who actually needs a time-accurate, low jitter 1PPS pulse? Bob - AE6RV  ----------------------------------------------------------------- AE6RV.com GFS GPSDO list: groups.yahoo.com/neo/groups/GFS-GPSDOs/info
ES
Eric Scace
Mon, Dec 19, 2016 12:13 AM
Speaking as an owner of a well-behaved mechanical clock:
Clock rate performance over time can be done based on time interval measurements anchored to a solid frequency standard. No 1pps needed per se.
Bring a clock to time is simplified with a timescale-accurate 1pps source.
Bob - AE6RV
Speaking as an owner of a well-behaved mechanical clock: Clock rate performance over time can be done based on time interval measurements anchored to a solid frequency standard. No 1pps needed per se. Bring a clock to time is simplified with a timescale-accurate 1pps source. > On 2016 Dec 18, at 18:16 , Bob Stewart <bob@evoria.net> wrote: > > One thing I've never really understood is who actually uses the high-quality 1PPS output from a GPSDO. I have spent a lot of time, effort, and money on developing my GPSDO without a whole of thought to the user base. It was just a quest for the best result I could obtain with a particular technology. The frequency standard users was a no brainer. Everyone who wants a frequency standard eventually understands they need to get a GPSDO, or an Rb, or a Cs. And that's all I thought I had: a good frequency standard. And then Tom prodded me a bit and showed me the shortcomings of what I was doing, and I did something about it. So, if an NTP user can get his time fix directly from a noisy receiver, who actually needs a time-accurate, low jitter 1PPS pulse? > Bob - AE6RV
BC
Bob Camp
Mon, Dec 19, 2016 12:16 AM
Hi
Roughly 99% of all GPSDO’s are only used for the PPS output. They go into cell sites and the reason
they exist is to sync up the Gold Codes on CDMA. That’s also why you see a lot of PPS only Rb’s
on the surplus market. The ones that don’t get used for cell towers, mostly go into other com systems
that for some reason need to have accurate time (also involves codes …).
Bob
Bob - AE6RV
AE6RV.com
GFS GPSDO list:
Hi Roughly 99% of all GPSDO’s are only used for the PPS output. They go into cell sites and the reason they exist is to sync up the Gold Codes on CDMA. That’s also why you see a *lot* of PPS only Rb’s on the surplus market. The ones that don’t get used for cell towers, mostly go into other com systems that for some reason need to have accurate time (also involves codes …). Bob > On Dec 18, 2016, at 6:16 PM, Bob Stewart <bob@evoria.net> wrote: > > One thing I've never really understood is who actually uses the high-quality 1PPS output from a GPSDO. I have spent a lot of time, effort, and money on developing my GPSDO without a whole of thought to the user base. It was just a quest for the best result I could obtain with a particular technology. The frequency standard users was a no brainer. Everyone who wants a frequency standard eventually understands they need to get a GPSDO, or an Rb, or a Cs. And that's all I thought I had: a good frequency standard. And then Tom prodded me a bit and showed me the shortcomings of what I was doing, and I did something about it. So, if an NTP user can get his time fix directly from a noisy receiver, who actually needs a time-accurate, low jitter 1PPS pulse? > Bob - AE6RV > ----------------------------------------------------------------- > AE6RV.com > > GFS GPSDO list: > groups.yahoo.com/neo/groups/GFS-GPSDOs/info > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there.
J
jimlux
Mon, Dec 19, 2016 12:56 AM
Anyone who needs to trigger events at a precise time or log the
occurrence of an event uses the 1 pps - the serial port (or other
interface) gives you the "at the tone the time will be" message, and the
edge of the 1pps is the "tone".
I've got several systems flying in space (or soon to fly in space) that
use the 1pps from GPS to calibrate their internal clocks and/or to
provide an absolute time reference (along with the aforesaid time message).
For example, one needs to have your carrier frequency within a certain
tolerance for communications with the ground stations: you can either
fly a precision oscillator with an oven (big, heavy, high power) or you
can measure a not-so-precision oscillator (small, cheap, low power)
against a 1pps, and adjust your frequency that way.
I grant you that this is really more like building a GPSDO than
using a GPSDO.
I've used the 1pps from a GPSDO as a common trigger to synchronize
timing and timestamping for separate systems.
On 12/18/16 3:16 PM, Bob Stewart wrote: > One thing I've never really understood is who actually uses the high-quality 1PPS output from a GPSDO. I have spent a lot of time, effort, and money on developing my GPSDO without a whole of thought to the user base. It was just a quest for the best result I could obtain with a particular technology. The frequency standard users was a no brainer. Everyone who wants a frequency standard eventually understands they need to get a GPSDO, or an Rb, or a Cs. And that's all I thought I had: a good frequency standard. And then Tom prodded me a bit and showed me the shortcomings of what I was doing, and I did something about it. So, if an NTP user can get his time fix directly from a noisy receiver, who actually needs a time-accurate, low jitter 1PPS pulse? Anyone who needs to trigger events at a precise time or log the occurrence of an event uses the 1 pps - the serial port (or other interface) gives you the "at the tone the time will be" message, and the edge of the 1pps is the "tone". I've got several systems flying in space (or soon to fly in space) that use the 1pps from GPS to calibrate their internal clocks and/or to provide an absolute time reference (along with the aforesaid time message). For example, one needs to have your carrier frequency within a certain tolerance for communications with the ground stations: you can either fly a precision oscillator with an oven (big, heavy, high power) or you can measure a not-so-precision oscillator (small, cheap, low power) against a 1pps, and adjust your frequency that way. I grant you that this is really more like *building* a GPSDO than *using* a GPSDO. I've used the 1pps from a GPSDO as a common trigger to synchronize timing and timestamping for separate systems.
BS
Bob Stewart
Mon, Dec 19, 2016 1:33 AM
Hi Jim,
Thanks Jim,
So, what I'm seeing so far, assuming I'm interpreting it correctly, is big budget commercial and government applications, generally clustering around time-controlled multiplexing, as well as the niche that is the space industry.  Then there's the hobbyist, such as Eric who wants to control a Fedchenko clock, or similar type of application, such as whatever sort of spread spectrum that ham radio may morph into, or perhaps the low S/N EME guys.  Any others?
Bob
To: time-nuts@febo.com
Sent: Sunday, December 18, 2016 6:56 PM
Subject: Re: [time-nuts] 1PPS users?
using a GPSDO.
Hi Jim, Thanks Jim, So, what I'm seeing so far, assuming I'm interpreting it correctly, is big budget commercial and government applications, generally clustering around time-controlled multiplexing, as well as the niche that is the space industry.  Then there's the hobbyist, such as Eric who wants to control a Fedchenko clock, or similar type of application, such as whatever sort of spread spectrum that ham radio may morph into, or perhaps the low S/N EME guys.  Any others? Bob From: jimlux <jimlux@earthlink.net> To: time-nuts@febo.com Sent: Sunday, December 18, 2016 6:56 PM Subject: Re: [time-nuts] 1PPS users? On 12/18/16 3:16 PM, Bob Stewart wrote: > One thing I've never really understood is who actually uses the high-quality 1PPS output from a GPSDO.  I have spent a lot of time, effort, and money on developing my GPSDO without a whole of thought to the user base.  It was just a quest for the best result I could obtain with a particular technology.  The frequency standard users was a no brainer.  Everyone who wants a frequency standard eventually understands they need to get a GPSDO, or an Rb, or a Cs.  And that's all I thought I had: a good frequency standard.  And then Tom prodded me a bit and showed me the shortcomings of what I was doing, and I did something about it.  So, if an NTP user can get his time fix directly from a noisy receiver, who actually needs a time-accurate, low jitter 1PPS pulse? Anyone who needs to trigger events at a precise time or log the occurrence of an event uses the 1 pps - the serial port (or other interface) gives you the "at the tone the time will be" message, and the edge of the 1pps is the "tone". I've got several systems flying in space (or soon to fly in space) that use the 1pps from GPS to calibrate their internal clocks and/or to provide an absolute time reference (along with the aforesaid time message). For example, one needs to have your carrier frequency within a certain tolerance for communications with the ground stations: you can either fly a precision oscillator with an oven (big, heavy, high power) or you can measure a not-so-precision oscillator (small, cheap, low power) against a 1pps, and adjust your frequency that way. I grant you that this is really more like *building* a GPSDO than *using* a GPSDO. I've used the 1pps from a GPSDO as a common trigger to synchronize timing and timestamping for separate systems. _______________________________________________ time-nuts mailing list -- time-nuts@febo.com To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts and follow the instructions there.
CA
Chris Albertson
Mon, Dec 19, 2016 1:35 AM
Who uses 1PPS?  In industry they are used to phase lock various
oscillators.  I would bet most of those oscillators are used in the
telecommunications industry both for bit rate clocks and for carrier
frequency synthesis.
We also see a lot of 1 PPS used for NTP servers that in turn are used to
keep computer internal time of day clocks running at the correct rate.
Bob - AE6RV
AE6RV.com
GFS GPSDO list:
Chris Albertson
Redondo Beach, California
Who uses 1PPS? In industry they are used to phase lock various oscillators. I would bet most of those oscillators are used in the telecommunications industry both for bit rate clocks and for carrier frequency synthesis. We also see a lot of 1 PPS used for NTP servers that in turn are used to keep computer internal time of day clocks running at the correct rate. On Sun, Dec 18, 2016 at 3:16 PM, Bob Stewart <bob@evoria.net> wrote: > One thing I've never really understood is who actually uses the > high-quality 1PPS output from a GPSDO. I have spent a lot of time, effort, > and money on developing my GPSDO without a whole of thought to the user > base. It was just a quest for the best result I could obtain with a > particular technology. The frequency standard users was a no brainer. > Everyone who wants a frequency standard eventually understands they need to > get a GPSDO, or an Rb, or a Cs. And that's all I thought I had: a good > frequency standard. And then Tom prodded me a bit and showed me the > shortcomings of what I was doing, and I did something about it. So, if an > NTP user can get his time fix directly from a noisy receiver, who actually > needs a time-accurate, low jitter 1PPS pulse? > Bob - AE6RV > ----------------------------------------------------------------- > AE6RV.com > > GFS GPSDO list: > groups.yahoo.com/neo/groups/GFS-GPSDOs/info > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to https://www.febo.com/cgi-bin/ > mailman/listinfo/time-nuts > and follow the instructions there. > -- Chris Albertson Redondo Beach, California
JA
John Ackermann N8UR
Mon, Dec 19, 2016 1:54 AM
For amateur use, PPS comparison requires less equipment and can be more
accurate than trying to measure RF rates like 10 MHz.
When comparing two PPS signals, phase slips are very infrequent so you
can observe drift rate over minutes/hours/days with an oscilloscope or
simple time interval counter to get much better resolution than most
frequency counters can provide.  (Of course, a GPS works as well for
this as a GPSDO, albeit with more short term jitter.)
John
On 12/18/2016 08:33 PM, Bob Stewart wrote:
Hi Jim,
Thanks Jim,
Bob
using a GPSDO.
For amateur use, PPS comparison requires less equipment and can be more accurate than trying to measure RF rates like 10 MHz. When comparing two PPS signals, phase slips are very infrequent so you can observe drift rate over minutes/hours/days with an oscilloscope or simple time interval counter to get much better resolution than most frequency counters can provide. (Of course, a GPS works as well for this as a GPSDO, albeit with more short term jitter.) John ---- On 12/18/2016 08:33 PM, Bob Stewart wrote: > Hi Jim, > Thanks Jim, > > So, what I'm seeing so far, assuming I'm interpreting it correctly, is big budget commercial and government applications, generally clustering around time-controlled multiplexing, as well as the niche that is the space industry. Then there's the hobbyist, such as Eric who wants to control a Fedchenko clock, or similar type of application, such as whatever sort of spread spectrum that ham radio may morph into, or perhaps the low S/N EME guys. Any others? > Bob > > From: jimlux <jimlux@earthlink.net> > To: time-nuts@febo.com > Sent: Sunday, December 18, 2016 6:56 PM > Subject: Re: [time-nuts] 1PPS users? > > On 12/18/16 3:16 PM, Bob Stewart wrote: >> One thing I've never really understood is who actually uses the high-quality 1PPS output from a GPSDO. I have spent a lot of time, effort, and money on developing my GPSDO without a whole of thought to the user base. It was just a quest for the best result I could obtain with a particular technology. The frequency standard users was a no brainer. Everyone who wants a frequency standard eventually understands they need to get a GPSDO, or an Rb, or a Cs. And that's all I thought I had: a good frequency standard. And then Tom prodded me a bit and showed me the shortcomings of what I was doing, and I did something about it. So, if an NTP user can get his time fix directly from a noisy receiver, who actually needs a time-accurate, low jitter 1PPS pulse? > > Anyone who needs to trigger events at a precise time or log the > occurrence of an event uses the 1 pps - the serial port (or other > interface) gives you the "at the tone the time will be" message, and the > edge of the 1pps is the "tone". > > > I've got several systems flying in space (or soon to fly in space) that > use the 1pps from GPS to calibrate their internal clocks and/or to > provide an absolute time reference (along with the aforesaid time message). > > For example, one needs to have your carrier frequency within a certain > tolerance for communications with the ground stations: you can either > fly a precision oscillator with an oven (big, heavy, high power) or you > can measure a not-so-precision oscillator (small, cheap, low power) > against a 1pps, and adjust your frequency that way. > > I grant you that this is really more like *building* a GPSDO than > *using* a GPSDO. > > I've used the 1pps from a GPSDO as a common trigger to synchronize > timing and timestamping for separate systems. > > > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. > > > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. >
PR
Peter Reilley
Mon, Dec 19, 2016 1:59 AM
There was a discussion here a while ago about synchronizing radio
telescopes that
were separated by some miles.  The 1PPS from GPS was suggested as a
possibility.
I am working on a project to do location by triangulation that uses the
1PPS signal.
I would like to get better than the +-10 nS that the better receivers
provide.
Pete.
Bob - AE6RV
AE6RV.com
GFS GPSDO list:
There was a discussion here a while ago about synchronizing radio telescopes that were separated by some miles. The 1PPS from GPS was suggested as a possibility. I am working on a project to do location by triangulation that uses the 1PPS signal. I would like to get better than the +-10 nS that the better receivers provide. Pete. On 12/18/2016 6:16 PM, Bob Stewart wrote: > One thing I've never really understood is who actually uses the high-quality 1PPS output from a GPSDO. I have spent a lot of time, effort, and money on developing my GPSDO without a whole of thought to the user base. It was just a quest for the best result I could obtain with a particular technology. The frequency standard users was a no brainer. Everyone who wants a frequency standard eventually understands they need to get a GPSDO, or an Rb, or a Cs. And that's all I thought I had: a good frequency standard. And then Tom prodded me a bit and showed me the shortcomings of what I was doing, and I did something about it. So, if an NTP user can get his time fix directly from a noisy receiver, who actually needs a time-accurate, low jitter 1PPS pulse? > Bob - AE6RV > ----------------------------------------------------------------- > AE6RV.com > > GFS GPSDO list: > groups.yahoo.com/neo/groups/GFS-GPSDOs/info > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. >
SS
Scott Stobbe
Mon, Dec 19, 2016 2:22 AM
Part of the reason 1PPS needs to be so clean is because you are
continuously integrating phase noise of the LO (hopefully an OCXO). While
10 uS is pretty trivial off a gps receiver. Without gps, 10 us over 24 hrs
with a plane jane AT-cut crystal subject environmental dynamics becomes
ludicrous. More than likely the short term stability of GPSDO is cleaner
than it needs to be for many applications, but that is so holdover over an
hour or day remains reasonable.
Bob - AE6RV
AE6RV.com
GFS GPSDO list:
Part of the reason 1PPS needs to be so clean is because you are continuously integrating phase noise of the LO (hopefully an OCXO). While 10 uS is pretty trivial off a gps receiver. Without gps, 10 us over 24 hrs with a plane jane AT-cut crystal subject environmental dynamics becomes ludicrous. More than likely the short term stability of GPSDO is cleaner than it needs to be for many applications, but that is so holdover over an hour or day remains reasonable. On Sun, Dec 18, 2016 at 6:16 PM, Bob Stewart <bob@evoria.net> wrote: > One thing I've never really understood is who actually uses the > high-quality 1PPS output from a GPSDO. I have spent a lot of time, effort, > and money on developing my GPSDO without a whole of thought to the user > base. It was just a quest for the best result I could obtain with a > particular technology. The frequency standard users was a no brainer. > Everyone who wants a frequency standard eventually understands they need to > get a GPSDO, or an Rb, or a Cs. And that's all I thought I had: a good > frequency standard. And then Tom prodded me a bit and showed me the > shortcomings of what I was doing, and I did something about it. So, if an > NTP user can get his time fix directly from a noisy receiver, who actually > needs a time-accurate, low jitter 1PPS pulse? > Bob - AE6RV > ----------------------------------------------------------------- > AE6RV.com > > GFS GPSDO list: > groups.yahoo.com/neo/groups/GFS-GPSDOs/info > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to https://www.febo.com/cgi-bin/ > mailman/listinfo/time-nuts > and follow the instructions there. >
BS
Bob Stewart
Mon, Dec 19, 2016 4:20 AM
Hi Scott,
I do understand the reasons that these users want this quality of output.  It's who these users are, what fields, industries, etc, that I didn't quite understand.
Bob -----------------------------------------------------------------
AE6RV.com
GFS GPSDO list:
To: Bob Stewart bob@evoria.net; Discussion of precise time and frequency measurement time-nuts@febo.com
Sent: Sunday, December 18, 2016 8:22 PM
Bob - AE6RV
AE6RV.com
GFS GPSDO list:
groups.yahoo.com/neo/groups/ GFS-GPSDOs/info
To unsubscribe, go to https://www.febo.com/cgi-bin/ mailman/listinfo/time-nuts
Hi Scott, I do understand the reasons that these users want this quality of output.  It's who these users are, what fields, industries, etc, that I didn't quite understand. Bob ----------------------------------------------------------------- AE6RV.com GFS GPSDO list: groups.yahoo.com/neo/groups/GFS-GPSDOs/info From: Scott Stobbe <scott.j.stobbe@gmail.com> To: Bob Stewart <bob@evoria.net>; Discussion of precise time and frequency measurement <time-nuts@febo.com> Sent: Sunday, December 18, 2016 8:22 PM Subject: Re: [time-nuts] 1PPS users? Part of the reason 1PPS needs to be so clean is because you are continuously integrating phase noise of the LO (hopefully an OCXO). While 10 uS is pretty trivial off a gps receiver. Without gps, 10 us over 24 hrs with a plane jane AT-cut crystal subject environmental dynamics becomes ludicrous. More than likely the short term stability of GPSDO is cleaner than it needs to be for many applications, but that is so holdover over an hour or day remains reasonable. On Sun, Dec 18, 2016 at 6:16 PM, Bob Stewart <bob@evoria.net> wrote: One thing I've never really understood is who actually uses the high-quality 1PPS output from a GPSDO.  I have spent a lot of time, effort, and money on developing my GPSDO without a whole of thought to the user base.  It was just a quest for the best result I could obtain with a particular technology.  The frequency standard users was a no brainer.  Everyone who wants a frequency standard eventually understands they need to get a GPSDO, or an Rb, or a Cs.  And that's all I thought I had: a good frequency standard.  And then Tom prodded me a bit and showed me the shortcomings of what I was doing, and I did something about it.  So, if an NTP user can get his time fix directly from a noisy receiver, who actually needs a time-accurate, low jitter 1PPS pulse? Bob - AE6RV  ----------------------------- ------------------------------ ------ AE6RV.com GFS GPSDO list: groups.yahoo.com/neo/groups/ GFS-GPSDOs/info ______________________________ _________________ time-nuts mailing list -- time-nuts@febo.com To unsubscribe, go to https://www.febo.com/cgi-bin/ mailman/listinfo/time-nuts and follow the instructions there.
MW
Michael Wouters
Mon, Dec 19, 2016 5:44 AM
One application is advanced network diagnostics eg cards like this:
https://www.endace.com/endace-dag-high-speed-packet-capture-cards.html
So for a 40 GbE card, time-stamping 1 kilobyte packets demands
sub-microsecond accuracy, if you want to compare at different points
in your network.
Cheers
Michael
Bob - AE6RV
AE6RV.com
GFS GPSDO list:
One application is advanced network diagnostics eg cards like this: https://www.endace.com/endace-dag-high-speed-packet-capture-cards.html So for a 40 GbE card, time-stamping 1 kilobyte packets demands sub-microsecond accuracy, if you want to compare at different points in your network. Cheers Michael On Mon, Dec 19, 2016 at 10:16 AM, Bob Stewart <bob@evoria.net> wrote: > One thing I've never really understood is who actually uses the high-quality 1PPS output from a GPSDO. I have spent a lot of time, effort, and money on developing my GPSDO without a whole of thought to the user base. It was just a quest for the best result I could obtain with a particular technology. The frequency standard users was a no brainer. Everyone who wants a frequency standard eventually understands they need to get a GPSDO, or an Rb, or a Cs. And that's all I thought I had: a good frequency standard. And then Tom prodded me a bit and showed me the shortcomings of what I was doing, and I did something about it. So, if an NTP user can get his time fix directly from a noisy receiver, who actually needs a time-accurate, low jitter 1PPS pulse? > Bob - AE6RV > ----------------------------------------------------------------- > AE6RV.com > > GFS GPSDO list: > groups.yahoo.com/neo/groups/GFS-GPSDOs/info > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there.
EH
Esa Heikkinen
Mon, Dec 19, 2016 7:13 AM
Hi Bob,
I use it for NTP server, like many others also do around the world.
73s!
Esa
OH4KJU
Hi Bob, > One thing I've never really understood is who actually uses the high-quality 1PPS output from a GPSDO. I use it for NTP server, like many others also do around the world. -- 73s! Esa OH4KJU
BC
Bob Camp
Mon, Dec 19, 2016 12:06 PM
Hi
The vast bulk of all GPSDO’s sold over the last three decades were sold because the first
CDMA specification required that the basestation operate without a GPS signal for
24 hours. During that time the alignment of the Gold Codes is required to be within
10 us of “GPS time”. Once the codes go out of alignment, the cell phone takes an
interference hit, so the the basestation must be shut down.
The time and code alignment requirement has “evolved” over time. Various 3G, 4G, 5G, 6G ..
systems have tighter timing specs (or apparently none at all). Technology has also evolved.
A self contained GPSDO located at each and every transmitter is no longer the only way to do this.
We have 1588 and a number of other tools that didn’t exist in the 1980’s.
Bob
On Dec 18, 2016, at 11:20 PM, Bob Stewart bob@evoria.net wrote:
Hi Scott,
AE6RV.com
GFS GPSDO list:
Bob - AE6RV
AE6RV.com
GFS GPSDO list:
Hi The vast bulk of all GPSDO’s sold over the last three decades were sold because the first CDMA specification required that the basestation operate without a GPS signal for 24 hours. During that time the alignment of the Gold Codes is required to be within 10 us of “GPS time”. Once the codes go out of alignment, the cell phone takes an interference hit, so the the basestation must be shut down. The time and code alignment requirement has “evolved” over time. Various 3G, 4G, 5G, 6G .. systems have tighter timing specs (or apparently none at all). Technology has also evolved. A self contained GPSDO located at each and every transmitter is no longer the only way to do this. We have 1588 and a number of other tools that didn’t exist in the 1980’s. Bob > On Dec 18, 2016, at 11:20 PM, Bob Stewart <bob@evoria.net> wrote: > > Hi Scott, > I do understand the reasons that these users want this quality of output. It's who these users are, what fields, industries, etc, that I didn't quite understand. > Bob ----------------------------------------------------------------- > AE6RV.com > > GFS GPSDO list: > groups.yahoo.com/neo/groups/GFS-GPSDOs/info > > From: Scott Stobbe <scott.j.stobbe@gmail.com> > To: Bob Stewart <bob@evoria.net>; Discussion of precise time and frequency measurement <time-nuts@febo.com> > Sent: Sunday, December 18, 2016 8:22 PM > Subject: Re: [time-nuts] 1PPS users? > > Part of the reason 1PPS needs to be so clean is because you are continuously integrating phase noise of the LO (hopefully an OCXO). While 10 uS is pretty trivial off a gps receiver. Without gps, 10 us over 24 hrs with a plane jane AT-cut crystal subject environmental dynamics becomes ludicrous. More than likely the short term stability of GPSDO is cleaner than it needs to be for many applications, but that is so holdover over an hour or day remains reasonable. > On Sun, Dec 18, 2016 at 6:16 PM, Bob Stewart <bob@evoria.net> wrote: > > One thing I've never really understood is who actually uses the high-quality 1PPS output from a GPSDO. I have spent a lot of time, effort, and money on developing my GPSDO without a whole of thought to the user base. It was just a quest for the best result I could obtain with a particular technology. The frequency standard users was a no brainer. Everyone who wants a frequency standard eventually understands they need to get a GPSDO, or an Rb, or a Cs. And that's all I thought I had: a good frequency standard. And then Tom prodded me a bit and showed me the shortcomings of what I was doing, and I did something about it. So, if an NTP user can get his time fix directly from a noisy receiver, who actually needs a time-accurate, low jitter 1PPS pulse? > Bob - AE6RV > ----------------------------- ------------------------------ ------ > AE6RV.com > > GFS GPSDO list: > groups.yahoo.com/neo/groups/ GFS-GPSDOs/info > ______________________________ _________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to https://www.febo.com/cgi-bin/ mailman/listinfo/time-nuts > and follow the instructions there. > > > > > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there.
TS
Tim Shoppa
Mon, Dec 19, 2016 12:24 PM
You know, there's a reason this list is called "time-nuts" and not
"frequency-nuts" :-).
But sometimes I wonder if "phase-nuts" might be a better term.
It is so incredibly useful to put your best 1 PPS into a scope and use that
to watch for systemic effects on your second-best clock. That's why we then
end up with a third, fourth, fifth, etc. clock :-)
So many newcomer GPSDO makers seem to just do frequency lock but rarely do
they or their users know the difference.
At same time there are so many non-ntpd NTP implementations that just jump
instead of slew the clock.
Tim N3QE
Bob - AE6RV
AE6RV.com
GFS GPSDO list:
You know, there's a reason this list is called "time-nuts" and not "frequency-nuts" :-). But sometimes I wonder if "phase-nuts" might be a better term. It is so incredibly useful to put your best 1 PPS into a scope and use that to watch for systemic effects on your second-best clock. That's why we then end up with a third, fourth, fifth, etc. clock :-) So many newcomer GPSDO makers seem to just do frequency lock but rarely do they or their users know the difference. At same time there are so many non-ntpd NTP implementations that just jump instead of slew the clock. Tim N3QE On Sun, Dec 18, 2016 at 6:16 PM, Bob Stewart <bob@evoria.net> wrote: > One thing I've never really understood is who actually uses the > high-quality 1PPS output from a GPSDO. I have spent a lot of time, effort, > and money on developing my GPSDO without a whole of thought to the user > base. It was just a quest for the best result I could obtain with a > particular technology. The frequency standard users was a no brainer. > Everyone who wants a frequency standard eventually understands they need to > get a GPSDO, or an Rb, or a Cs. And that's all I thought I had: a good > frequency standard. And then Tom prodded me a bit and showed me the > shortcomings of what I was doing, and I did something about it. So, if an > NTP user can get his time fix directly from a noisy receiver, who actually > needs a time-accurate, low jitter 1PPS pulse? > Bob - AE6RV > ----------------------------------------------------------------- > AE6RV.com > > GFS GPSDO list: > groups.yahoo.com/neo/groups/GFS-GPSDOs/info > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to https://www.febo.com/cgi-bin/ > mailman/listinfo/time-nuts > and follow the instructions there. >
CC
Chris Caudle
Mon, Dec 19, 2016 2:28 PM
Magnus wrote a paper recently on effects of the GPS time slip (recent
error in data upload) on the broadcast industry which uses GPS time to
synchronize widely separated transmitters so that they can overlap their
broadcast coverage areas without interference.
I believe the power industry is using GPS provided time to stamp power
events for analysis as well.
Chris Caudle
On Sun, December 18, 2016 10:20 pm, Bob Stewart wrote: > I do understand the reasons that these users want this quality of > output. It's who these users are, what fields, industries, etc, that I > didn't quite understand. Magnus wrote a paper recently on effects of the GPS time slip (recent error in data upload) on the broadcast industry which uses GPS time to synchronize widely separated transmitters so that they can overlap their broadcast coverage areas without interference. I believe the power industry is using GPS provided time to stamp power events for analysis as well. -- Chris Caudle
J
jimlux
Mon, Dec 19, 2016 3:07 PM
And pretty much any of these will ingest a 1pps + message, rather than,
say, a 10 MHz reference.
Why not just use the raw GPS 1pps (which is typically good to a few tens
of ns)?  GPS coverage/outage and random variation in the GPS 1pps
A lot of them use a disciplined oscillator to generate the 1pps, so the
oscillator is essentially a long term averager/low pass filter on the
raw GPS output -
On 12/19/16 6:28 AM, Chris Caudle wrote: > On Sun, December 18, 2016 10:20 pm, Bob Stewart wrote: >> I do understand the reasons that these users want this quality of >> output. It's who these users are, what fields, industries, etc, that I >> didn't quite understand. > > Magnus wrote a paper recently on effects of the GPS time slip (recent > error in data upload) on the broadcast industry which uses GPS time to > synchronize widely separated transmitters so that they can overlap their > broadcast coverage areas without interference. > > I believe the power industry is using GPS provided time to stamp power > events for analysis as well. > And pretty much any of these will ingest a 1pps + message, rather than, say, a 10 MHz reference. Why not just use the raw GPS 1pps (which is typically good to a few tens of ns)? GPS coverage/outage and random variation in the GPS 1pps A lot of them use a disciplined oscillator to generate the 1pps, so the oscillator is essentially a long term averager/low pass filter on the raw GPS output -
TV
Tom Van Baak
Mon, Dec 19, 2016 3:11 PM
Chris,
Yes, in fact one of the first applications of hp's SmartClock was just that:
"Accurate Transmission Line Fault Location Using Synchronized Sampling"
http://leapsecond.com/hpan/an1276-1.pdf
Bob,
For more background on 1PPS and time synchronization see:
"GPS and Precision Timing Applications"
http://www.hpmemoryproject.org/an/pdf/an_1272.pdf
"The Global Positioning System and HP SmartClock"
http://www.hpl.hp.com/hpjournal/96dec/dec96a9.pdf
Other useful hp app notes for time nuts:
http://leapsecond.com/hpan/list.htm
/tvb
> I believe the power industry is using GPS provided time to stamp power > events for analysis as well. Chris, Yes, in fact one of the first applications of hp's SmartClock was just that: "Accurate Transmission Line Fault Location Using Synchronized Sampling" http://leapsecond.com/hpan/an1276-1.pdf Bob, For more background on 1PPS and time synchronization see: "GPS and Precision Timing Applications" http://www.hpmemoryproject.org/an/pdf/an_1272.pdf "The Global Positioning System and HP SmartClock" http://www.hpl.hp.com/hpjournal/96dec/dec96a9.pdf Other useful hp app notes for time nuts: http://leapsecond.com/hpan/list.htm /tvb
BC
Bob Camp
Mon, Dec 19, 2016 4:46 PM
Hi
Chris,
There is an FCS paper that pre-dates that by about a decade. The guys at
Quebec Hydro set up GPS to monitor the phase state in their main distribution
network and wrote the paper. I don’t have an FCS DVD handy to dig it up. I
also have no idea if there is a copy outside a pay wall. They went into a bit
more detail on what they saw. It gives you a bit better feel for how it works
in the real world.
Bob
Bob,
/tvb
Hi > On Dec 19, 2016, at 10:11 AM, Tom Van Baak <tvb@LeapSecond.com> wrote: > >> I believe the power industry is using GPS provided time to stamp power >> events for analysis as well. > > Chris, > > Yes, in fact one of the first applications of hp's SmartClock was just that: > > "Accurate Transmission Line Fault Location Using Synchronized Sampling" > http://leapsecond.com/hpan/an1276-1.pdf There is an FCS paper that pre-dates that by about a decade. The guys at Quebec Hydro set up GPS to monitor the phase state in their main distribution network and wrote the paper. I don’t have an FCS DVD handy to dig it up. I also have no idea if there is a copy outside a pay wall. They went into a bit more detail on what they saw. It gives you a bit better feel for how it works in the real world. Bob > > > Bob, > > For more background on 1PPS and time synchronization see: > > "GPS and Precision Timing Applications" > http://www.hpmemoryproject.org/an/pdf/an_1272.pdf > > "The Global Positioning System and HP SmartClock" > http://www.hpl.hp.com/hpjournal/96dec/dec96a9.pdf > > Other useful hp app notes for time nuts: > http://leapsecond.com/hpan/list.htm > > /tvb > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there.
DJ
David J Taylor
Mon, Dec 19, 2016 4:55 PM
raw GPS output -
Having the GPSDO/PPS is handy when someone parks outside your location and
carries a GPS jammer.
Cheers,
David
SatSignal Software - Quality software written to your requirements
Web: http://www.satsignal.eu
Email: david-taylor@blueyonder.co.uk
Twitter: @gm8arv
From: jimlux And pretty much any of these will ingest a 1pps + message, rather than, say, a 10 MHz reference. Why not just use the raw GPS 1pps (which is typically good to a few tens of ns)? GPS coverage/outage and random variation in the GPS 1pps A lot of them use a disciplined oscillator to generate the 1pps, so the oscillator is essentially a long term averager/low pass filter on the raw GPS output - ===================================== Having the GPSDO/PPS is handy when someone parks outside your location and carries a GPS jammer. Cheers, David -- SatSignal Software - Quality software written to your requirements Web: http://www.satsignal.eu Email: david-taylor@blueyonder.co.uk Twitter: @gm8arv
BC
Bob Camp
Mon, Dec 19, 2016 6:21 PM
Hi
On Dec 19, 2016, at 11:55 AM, David J Taylor david-taylor@blueyonder.co.uk wrote:
raw GPS output -
Unless the jammer causes the GPS receiver to go a bit nuts and the GPSDO is dumb enough to
follow it. Don’t ask how I know about this particular situation :)
Bob
Cheers,
David
Twitter: @gm8arv
Hi > On Dec 19, 2016, at 11:55 AM, David J Taylor <david-taylor@blueyonder.co.uk> wrote: > > From: jimlux > > And pretty much any of these will ingest a 1pps + message, rather than, > say, a 10 MHz reference. > > Why not just use the raw GPS 1pps (which is typically good to a few tens > of ns)? GPS coverage/outage and random variation in the GPS 1pps > > A lot of them use a disciplined oscillator to generate the 1pps, so the > oscillator is essentially a long term averager/low pass filter on the > raw GPS output - > ===================================== > > Having the GPSDO/PPS is handy when someone parks outside your location and carries a GPS jammer. Unless the jammer causes the GPS receiver to go a bit nuts and the GPSDO is dumb enough to follow it. Don’t ask how I know about this particular situation :) Bob > > Cheers, > David > -- > SatSignal Software - Quality software written to your requirements > Web: http://www.satsignal.eu > Email: david-taylor@blueyonder.co.uk > Twitter: @gm8arv > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there.
