Why RFNOC gain example building FPGA, I faced with module 'rfnoc_block_gain' not found?
SH
sp h
Tue, Feb 8, 2022 7:34 AM
I copied RFNOC gain example from UHD folder, I installed it successfully in
Gnuradio, But for building FPGA
I was faced with these errors.
How can I solve this problem?
Thanks in advance
ERROR: [Synth 8-439] module 'rfnoc_block_gain' not found
[/home/sp/Documents/rfnoc-tutorial/rfnoc/icores/x310_rfnoc_image_core.v:1055]
ERROR: [Synth 8-6156] failed synthesizing module 'rfnoc_image_core'
[/home/sp/Documents/rfnoc-tutorial/rfnoc/icores/x310_rfnoc_image_core.v:24]
ERROR: [Synth 8-6156] failed synthesizing module 'bus_int'
[/home/sp/Documents/uhd-4.1.0.5/fpga/usrp3/top/x300/bus_int.v:9]
ERROR: [Synth 8-6156] failed synthesizing module 'x300_core'
[/home/sp/Documents/uhd-4.1.0.5/fpga/usrp3/top/x300/x300_core.v:9]
ERROR: [Synth 8-6156] failed synthesizing module 'x300'
[/home/sp/Documents/uhd-4.1.0.5/fpga/usrp3/top/x300/x300.v:20]
ERROR: [Common 17-69] Command failed: Synthesis failed - please see the
console or run log file for details
[00:04:05] Current task: Synthesis +++ Current Phase: Starting
[00:04:05] Current task: Synthesis +++ Current Phase: Finished
[00:04:05] Process terminated. Status: Failure
I copied RFNOC gain example from UHD folder, I installed it successfully in Gnuradio, But for building FPGA I was faced with these errors. How can I solve this problem? Thanks in advance ERROR: [Synth 8-439] module 'rfnoc_block_gain' not found [/home/sp/Documents/rfnoc-tutorial/rfnoc/icores/x310_rfnoc_image_core.v:1055] ERROR: [Synth 8-6156] failed synthesizing module 'rfnoc_image_core' [/home/sp/Documents/rfnoc-tutorial/rfnoc/icores/x310_rfnoc_image_core.v:24] ERROR: [Synth 8-6156] failed synthesizing module 'bus_int' [/home/sp/Documents/uhd-4.1.0.5/fpga/usrp3/top/x300/bus_int.v:9] ERROR: [Synth 8-6156] failed synthesizing module 'x300_core' [/home/sp/Documents/uhd-4.1.0.5/fpga/usrp3/top/x300/x300_core.v:9] ERROR: [Synth 8-6156] failed synthesizing module 'x300' [/home/sp/Documents/uhd-4.1.0.5/fpga/usrp3/top/x300/x300.v:20] ERROR: [Common 17-69] Command failed: Synthesis failed - please see the console or run log file for details [00:04:05] Current task: Synthesis +++ Current Phase: Starting [00:04:05] Current task: Synthesis +++ Current Phase: Finished [00:04:05] Process terminated. Status: Failure
WF
Wade Fife
Wed, Feb 9, 2022 7:22 PM
That error means the source code for your gain block wasn't included. My
guess is that the include path was wrong, so your Makefile.srcs wasn't
added. If you're coping the rfnoc-example, here's how to build it (I've
attempted to use your file paths in this example):
cd /home/sp/Documents/rfnoc-tutorial
mkdir build
cd build
cmake -DUHD_FPGA_DIR=/home/sp/Documents/uhd-4.1.0.5/fpga ../
make x310_rfnoc_image_core
If you want to build without using cmake, you could do this:
rfnoc_image_builder -F /home/sp/Documents/uhd-4.1.0.5/fpga -I
/home/sp/Documents/rfnoc-tutorial -p /home/sp/xilinx/Vivado -y
/home/sp/Documents/rfnoc-tutorial/rfnoc/icores/x310_rfnoc_image_core.yml
Note the include path is the base of the OOT module. Please check that all
the paths are correct for your setup when trying.
Wade
Thanks in advance
That error means the source code for your gain block wasn't included. My guess is that the include path was wrong, so your Makefile.srcs wasn't added. If you're coping the rfnoc-example, here's how to build it (I've attempted to use your file paths in this example): cd /home/sp/Documents/rfnoc-tutorial mkdir build cd build cmake -DUHD_FPGA_DIR=/home/sp/Documents/uhd-4.1.0.5/fpga ../ make x310_rfnoc_image_core If you want to build without using cmake, you could do this: rfnoc_image_builder -F /home/sp/Documents/uhd-4.1.0.5/fpga -I /home/sp/Documents/rfnoc-tutorial -p /home/sp/xilinx/Vivado -y /home/sp/Documents/rfnoc-tutorial/rfnoc/icores/x310_rfnoc_image_core.yml Note the include path is the base of the OOT module. Please check that all the paths are correct for your setup when trying. Wade On Tue, Feb 8, 2022 at 1:35 AM sp h <stackprogramer@gmail.com> wrote: > I copied RFNOC gain example from UHD folder, I installed it > successfully in Gnuradio, But for building FPGA > I was faced with these errors. > How can I solve this problem? > > Thanks in advance > > ERROR: [Synth 8-439] module 'rfnoc_block_gain' not found > [/home/sp/Documents/rfnoc-tutorial/rfnoc/icores/x310_rfnoc_image_core.v:1055] > ERROR: [Synth 8-6156] failed synthesizing module 'rfnoc_image_core' > [/home/sp/Documents/rfnoc-tutorial/rfnoc/icores/x310_rfnoc_image_core.v:24] > ERROR: [Synth 8-6156] failed synthesizing module 'bus_int' > [/home/sp/Documents/uhd-4.1.0.5/fpga/usrp3/top/x300/bus_int.v:9] > ERROR: [Synth 8-6156] failed synthesizing module 'x300_core' > [/home/sp/Documents/uhd-4.1.0.5/fpga/usrp3/top/x300/x300_core.v:9] > ERROR: [Synth 8-6156] failed synthesizing module 'x300' > [/home/sp/Documents/uhd-4.1.0.5/fpga/usrp3/top/x300/x300.v:20] > ERROR: [Common 17-69] Command failed: Synthesis failed - please see the > console or run log file for details > [00:04:05] Current task: Synthesis +++ Current Phase: Starting > [00:04:05] Current task: Synthesis +++ Current Phase: Finished > [00:04:05] Process terminated. Status: Failure > _______________________________________________ > USRP-users mailing list -- usrp-users@lists.ettus.com > To unsubscribe send an email to usrp-users-leave@lists.ettus.com >
SH
sp h
Sat, Feb 12, 2022 4:47 AM
Thanks, I checked your guidance. I am sure that everything is true but I
faced past errors:
module 'rfnoc_block_gain' not found....
mkdir build
cd build
Wade
Thanks in advance
Thanks, I checked your guidance. I am sure that everything is true but I faced past errors: module 'rfnoc_block_gain' not found.... On Wed, Feb 9, 2022 at 10:52 PM Wade Fife <wade.fife@ettus.com> wrote: > That error means the source code for your gain block wasn't included. My > guess is that the include path was wrong, so your Makefile.srcs wasn't > added. If you're coping the rfnoc-example, here's how to build it (I've > attempted to use your file paths in this example): > > cd /home/sp/Documents/rfnoc-tutorial > mkdir build > cd build > cmake -DUHD_FPGA_DIR=/home/sp/Documents/uhd-4.1.0.5/fpga ../ > make x310_rfnoc_image_core > > If you want to build without using cmake, you could do this: > > rfnoc_image_builder -F /home/sp/Documents/uhd-4.1.0.5/fpga -I > /home/sp/Documents/rfnoc-tutorial -p /home/sp/xilinx/Vivado -y > /home/sp/Documents/rfnoc-tutorial/rfnoc/icores/x310_rfnoc_image_core.yml > > Note the include path is the base of the OOT module. Please check that all > the paths are correct for your setup when trying. > > Wade > > > On Tue, Feb 8, 2022 at 1:35 AM sp h <stackprogramer@gmail.com> wrote: > >> I copied RFNOC gain example from UHD folder, I installed it >> successfully in Gnuradio, But for building FPGA >> I was faced with these errors. >> How can I solve this problem? >> >> Thanks in advance >> >> ERROR: [Synth 8-439] module 'rfnoc_block_gain' not found >> [/home/sp/Documents/rfnoc-tutorial/rfnoc/icores/x310_rfnoc_image_core.v:1055] >> ERROR: [Synth 8-6156] failed synthesizing module 'rfnoc_image_core' >> [/home/sp/Documents/rfnoc-tutorial/rfnoc/icores/x310_rfnoc_image_core.v:24] >> ERROR: [Synth 8-6156] failed synthesizing module 'bus_int' >> [/home/sp/Documents/uhd-4.1.0.5/fpga/usrp3/top/x300/bus_int.v:9] >> ERROR: [Synth 8-6156] failed synthesizing module 'x300_core' >> [/home/sp/Documents/uhd-4.1.0.5/fpga/usrp3/top/x300/x300_core.v:9] >> ERROR: [Synth 8-6156] failed synthesizing module 'x300' >> [/home/sp/Documents/uhd-4.1.0.5/fpga/usrp3/top/x300/x300.v:20] >> ERROR: [Common 17-69] Command failed: Synthesis failed - please see the >> console or run log file for details >> [00:04:05] Current task: Synthesis +++ Current Phase: Starting >> [00:04:05] Current task: Synthesis +++ Current Phase: Finished >> [00:04:05] Process terminated. Status: Failure >> _______________________________________________ >> USRP-users mailing list -- usrp-users@lists.ettus.com >> To unsubscribe send an email to usrp-users-leave@lists.ettus.com >> >
WF
Wade Fife
Sat, Feb 12, 2022 4:16 PM
I'm sorry to hear it's still not working for you. Can you try a clean repo
and use the unmodified example from the repo? If that works then you could
compare your copy to the example to see what's different.
The way the build-process works with OOT modules is that
rfnoc_image_builder looks for the Makefile.srcs for your OOT module, which,
in the example, includes the Makefile.srcs for the gain block. The HDL
files get added to a variable named RFNOC_OOT_SRCS. So it could be one of
these files has a mistake in your OOT module:
https://github.com/EttusResearch/uhd/blob/master/host/examples/rfnoc-example/fpga/Makefile.srcs
https://github.com/EttusResearch/uhd/blob/master/host/examples/rfnoc-example/fpga/rfnoc_block_gain/Makefile.srcs
Or it could be that the path provided to rfnoc_image_builder is not
correct, which would prevent it from finding the Makefile.srcs. It did look
like the path was incorrect in one of your other email threads.
If nothing else works, you can modify the Makefile.inc for X300 and add the
missing files directly.
https://github.com/EttusResearch/uhd/blob/master/fpga/usrp3/top/x300/Makefile.x300.inc
Thanks,
Wade
faced past errors:
mkdir build
cd build
Wade
Thanks in advance
I'm sorry to hear it's still not working for you. Can you try a clean repo and use the unmodified example from the repo? If that works then you could compare your copy to the example to see what's different. The way the build-process works with OOT modules is that rfnoc_image_builder looks for the Makefile.srcs for your OOT module, which, in the example, includes the Makefile.srcs for the gain block. The HDL files get added to a variable named RFNOC_OOT_SRCS. So it could be one of these files has a mistake in your OOT module: https://github.com/EttusResearch/uhd/blob/master/host/examples/rfnoc-example/fpga/Makefile.srcs https://github.com/EttusResearch/uhd/blob/master/host/examples/rfnoc-example/fpga/rfnoc_block_gain/Makefile.srcs Or it could be that the path provided to rfnoc_image_builder is not correct, which would prevent it from finding the Makefile.srcs. It did look like the path was incorrect in one of your other email threads. If nothing else works, you can modify the Makefile.inc for X300 and add the missing files directly. https://github.com/EttusResearch/uhd/blob/master/fpga/usrp3/top/x300/Makefile.x300.inc Thanks, Wade On Fri, Feb 11, 2022 at 10:47 PM sp h <stackprogramer@gmail.com> wrote: > Thanks, I checked your guidance. I am sure that everything is true but I > faced past errors: > module 'rfnoc_block_gain' not found.... > > On Wed, Feb 9, 2022 at 10:52 PM Wade Fife <wade.fife@ettus.com> wrote: > >> That error means the source code for your gain block wasn't included. My >> guess is that the include path was wrong, so your Makefile.srcs wasn't >> added. If you're coping the rfnoc-example, here's how to build it (I've >> attempted to use your file paths in this example): >> >> cd /home/sp/Documents/rfnoc-tutorial >> mkdir build >> cd build >> cmake -DUHD_FPGA_DIR=/home/sp/Documents/uhd-4.1.0.5/fpga ../ >> make x310_rfnoc_image_core >> >> If you want to build without using cmake, you could do this: >> >> rfnoc_image_builder -F /home/sp/Documents/uhd-4.1.0.5/fpga -I >> /home/sp/Documents/rfnoc-tutorial -p /home/sp/xilinx/Vivado -y >> /home/sp/Documents/rfnoc-tutorial/rfnoc/icores/x310_rfnoc_image_core.yml >> >> Note the include path is the base of the OOT module. Please check that >> all the paths are correct for your setup when trying. >> >> Wade >> >> >> On Tue, Feb 8, 2022 at 1:35 AM sp h <stackprogramer@gmail.com> wrote: >> >>> I copied RFNOC gain example from UHD folder, I installed it >>> successfully in Gnuradio, But for building FPGA >>> I was faced with these errors. >>> How can I solve this problem? >>> >>> Thanks in advance >>> >>> ERROR: [Synth 8-439] module 'rfnoc_block_gain' not found >>> [/home/sp/Documents/rfnoc-tutorial/rfnoc/icores/x310_rfnoc_image_core.v:1055] >>> ERROR: [Synth 8-6156] failed synthesizing module 'rfnoc_image_core' >>> [/home/sp/Documents/rfnoc-tutorial/rfnoc/icores/x310_rfnoc_image_core.v:24] >>> ERROR: [Synth 8-6156] failed synthesizing module 'bus_int' >>> [/home/sp/Documents/uhd-4.1.0.5/fpga/usrp3/top/x300/bus_int.v:9] >>> ERROR: [Synth 8-6156] failed synthesizing module 'x300_core' >>> [/home/sp/Documents/uhd-4.1.0.5/fpga/usrp3/top/x300/x300_core.v:9] >>> ERROR: [Synth 8-6156] failed synthesizing module 'x300' >>> [/home/sp/Documents/uhd-4.1.0.5/fpga/usrp3/top/x300/x300.v:20] >>> ERROR: [Common 17-69] Command failed: Synthesis failed - please see the >>> console or run log file for details >>> [00:04:05] Current task: Synthesis +++ Current Phase: Starting >>> [00:04:05] Current task: Synthesis +++ Current Phase: Finished >>> [00:04:05] Process terminated. Status: Failure >>> _______________________________________________ >>> USRP-users mailing list -- usrp-users@lists.ettus.com >>> To unsubscribe send an email to usrp-users-leave@lists.ettus.com >>> >>
SH
sp h
Sun, Feb 13, 2022 7:00 AM
Thank you Wade Fife, I checked it. Finally, my problem is solved... When I
create a new project with the below command, now everything works.
$rfnocmodtool newmod transceiver
$cd rfnoc-transceiver
$ rfnocmodtool add gain
After it I don't edit in clone file...
My Gnuradio 3.8.1,UHD 4.1.0.5, I attached example clone file here for
futures...
Thanks,
Wade
faced past errors:
mkdir build
cd build
Wade
Thanks in advance
Thank you Wade Fife, I checked it. Finally, my problem is solved... When I create a new project with the below command, now everything works. $rfnocmodtool newmod transceiver $cd rfnoc-transceiver $ rfnocmodtool add gain After it I don't edit in clone file... My Gnuradio 3.8.1,UHD 4.1.0.5, I attached example clone file here for futures... On Sat, Feb 12, 2022 at 7:46 PM Wade Fife <wade.fife@ettus.com> wrote: > I'm sorry to hear it's still not working for you. Can you try a clean repo > and use the unmodified example from the repo? If that works then you could > compare your copy to the example to see what's different. > > The way the build-process works with OOT modules is that > rfnoc_image_builder looks for the Makefile.srcs for your OOT module, which, > in the example, includes the Makefile.srcs for the gain block. The HDL > files get added to a variable named RFNOC_OOT_SRCS. So it could be one of > these files has a mistake in your OOT module: > > > https://github.com/EttusResearch/uhd/blob/master/host/examples/rfnoc-example/fpga/Makefile.srcs > > https://github.com/EttusResearch/uhd/blob/master/host/examples/rfnoc-example/fpga/rfnoc_block_gain/Makefile.srcs > > Or it could be that the path provided to rfnoc_image_builder is not > correct, which would prevent it from finding the Makefile.srcs. It did look > like the path was incorrect in one of your other email threads. > > If nothing else works, you can modify the Makefile.inc for X300 and add > the missing files directly. > > > https://github.com/EttusResearch/uhd/blob/master/fpga/usrp3/top/x300/Makefile.x300.inc > > Thanks, > > Wade > > On Fri, Feb 11, 2022 at 10:47 PM sp h <stackprogramer@gmail.com> wrote: > >> Thanks, I checked your guidance. I am sure that everything is true but I >> faced past errors: >> module 'rfnoc_block_gain' not found.... >> >> On Wed, Feb 9, 2022 at 10:52 PM Wade Fife <wade.fife@ettus.com> wrote: >> >>> That error means the source code for your gain block wasn't included. My >>> guess is that the include path was wrong, so your Makefile.srcs wasn't >>> added. If you're coping the rfnoc-example, here's how to build it (I've >>> attempted to use your file paths in this example): >>> >>> cd /home/sp/Documents/rfnoc-tutorial >>> mkdir build >>> cd build >>> cmake -DUHD_FPGA_DIR=/home/sp/Documents/uhd-4.1.0.5/fpga ../ >>> make x310_rfnoc_image_core >>> >>> If you want to build without using cmake, you could do this: >>> >>> rfnoc_image_builder -F /home/sp/Documents/uhd-4.1.0.5/fpga -I >>> /home/sp/Documents/rfnoc-tutorial -p /home/sp/xilinx/Vivado -y >>> /home/sp/Documents/rfnoc-tutorial/rfnoc/icores/x310_rfnoc_image_core.yml >>> >>> Note the include path is the base of the OOT module. Please check that >>> all the paths are correct for your setup when trying. >>> >>> Wade >>> >>> >>> On Tue, Feb 8, 2022 at 1:35 AM sp h <stackprogramer@gmail.com> wrote: >>> >>>> I copied RFNOC gain example from UHD folder, I installed it >>>> successfully in Gnuradio, But for building FPGA >>>> I was faced with these errors. >>>> How can I solve this problem? >>>> >>>> Thanks in advance >>>> >>>> ERROR: [Synth 8-439] module 'rfnoc_block_gain' not found >>>> [/home/sp/Documents/rfnoc-tutorial/rfnoc/icores/x310_rfnoc_image_core.v:1055] >>>> ERROR: [Synth 8-6156] failed synthesizing module 'rfnoc_image_core' >>>> [/home/sp/Documents/rfnoc-tutorial/rfnoc/icores/x310_rfnoc_image_core.v:24] >>>> ERROR: [Synth 8-6156] failed synthesizing module 'bus_int' >>>> [/home/sp/Documents/uhd-4.1.0.5/fpga/usrp3/top/x300/bus_int.v:9] >>>> ERROR: [Synth 8-6156] failed synthesizing module 'x300_core' >>>> [/home/sp/Documents/uhd-4.1.0.5/fpga/usrp3/top/x300/x300_core.v:9] >>>> ERROR: [Synth 8-6156] failed synthesizing module 'x300' >>>> [/home/sp/Documents/uhd-4.1.0.5/fpga/usrp3/top/x300/x300.v:20] >>>> ERROR: [Common 17-69] Command failed: Synthesis failed - please see the >>>> console or run log file for details >>>> [00:04:05] Current task: Synthesis +++ Current Phase: Starting >>>> [00:04:05] Current task: Synthesis +++ Current Phase: Finished >>>> [00:04:05] Process terminated. Status: Failure >>>> _______________________________________________ >>>> USRP-users mailing list -- usrp-users@lists.ettus.com >>>> To unsubscribe send an email to usrp-users-leave@lists.ettus.com >>>> >>>
