RE
Randy Evans
Thu, Nov 10, 2011 3:45 PM
I am in the process of designing a homebrew DVM that initially will only cover 0 to 12VDC measurement range. Perhaps in the future it could be expended for a wider range but the issue is getting very accurate and stable (stable is the key operative issue) range divider resistors. The design is based on the National Semiconductor app note 260, but modified with more modern components such as low charge injection analog switches, faster comparators, LTZ1000 reference, extremely linear integrator, low cost uprocessor, etc. My hope is that the DVM will be able to measure to 8.5 digits over this limited range. We shall see. It should be a fun project, regardless.
The big issue is the lack of noise rejection characteristics. A substantial amount of averaging may be required so fast 8.5 digit measurements might be out of the question. However, it should be a low cost measurement technique for high accuracy measurements of stable voltages. Obviously, the measurement accuracy would be largely determined by the accuracy of the LTZ1000 reference.
Since the integrator is the key circuit for this design, I would really like to see the integrator design in the HP-3458A, if anyone could provide a copy of the circuit. Comments on the approach would be apprecitated.
Thanks,
Randy Evans
Thanks,
Randy Evans
PK
Poul-Henning Kamp
Thu, Nov 10, 2011 3:51 PM
My hope is that the DVM will be able to measure to 8.5 digits [...]
Do you mean 8.5 digits single-shot, or 8.5 digits with averaging ?
Considering that you can get off-the shelf ADC's where 24 bit is routine
and 26 bits available, I'm not sure I'd bother...
http://ohh.de/5610.htm
Poul-Henning Kamp | UNIX since Zilog Zeus 3.20
phk@FreeBSD.ORG | TCP/IP since RFC 956
FreeBSD committer | BSD since 4.3-tahoe
Never attribute to malice what can adequately be explained by incompetence.
In message <1320939951.98248.YahooMailNeo@web37902.mail.mud.yahoo.com>, Randy E
vans writes:
RE
Randy Evans
Thu, Nov 10, 2011 4:20 PM
8.5 digits with averaging.
I did consider that but the ADCs I am familiar with only have a 5V input range so range resistors would be required, not desirable for me. Also, they won't directly take the 7.2V ref input from a LTZ1000. Plus the AN-260 circuitry is not too complex. Otherwise, I agree with you.
Randy
To: Randy Evans randallgrayevans@yahoo.com; Discussion of precise voltage measurement volt-nuts@febo.com
Sent: Thursday, November 10, 2011 7:51 AM
Subject: Re: [volt-nuts] Homebrew DVM
In message 1320939951.98248.YahooMailNeo@web37902.mail.mud.yahoo.com, Randy E
vans writes:
Randy
________________________________
To: Randy Evans <randallgrayevans@yahoo.com>; Discussion of precise voltage measurement <volt-nuts@febo.com>
vans writes:
RK
Rob Klein
Thu, Nov 10, 2011 4:24 PM
Oooh, gorgeous!
Where do I buy one and what does it cost?
Oooh, gorgeous!
- Rob.
Thu, Nov 10, 2011 5:17 PM
Hi, Randy!
AN-260 is a very bad example of slow medium scale ADC.
I think that 130 db SNR ADS1282 is much better. Also, 8,5-digit Solartron 7081
have a simple and cheap delta-sigma ADC with 0.06 ppm noise and 51 sec.
integration time.
Mickle T.
Thursday, November 10, 2011, 8:20:58 PM, you wrote:
RE> 8.5 digits with averaging.
RE>
RE> I did consider that but the ADCs I am familiar with only have a 5V input
RE> range so range resistors would be required, not desirable for me. Also,
RE> they won't directly take the 7.2V ref input from a LTZ1000. Plus the AN-260
RE> circuitry is not too complex. Otherwise, I agree with you.
RE>
RE> Randy
Hi, Randy!
integration time.
Mickle T.
RE>
RE>
RE> Randy
MK
m k
Thu, Nov 10, 2011 7:39 PM
Oooh, gorgeous!
Hi Rob,
Try the LTC2441, 8.5 hz updates at about 26 bits with pretty good linearity.
Most of the "24 bit" DAC are only really good for about 20-22 bits due to noise and non-linearity.
MK
> Date: Thu, 10 Nov 2011 17:24:02 +0100
> From: rob.klein@smalldesign.nl
> To: volt-nuts@febo.com
> Oooh, gorgeous!
> - Rob.
Hi Rob,
MK
RK
Rob Klein
Thu, Nov 10, 2011 9:36 PM
Op 10-11-2011 20:39, m k schreef:
Ehm, a search on LTC's website for "LTC2441" returns this:
Your search - ltc2441 - did not match any documents.
No pages were found containing "ltc2441".
No 8.5Hz, 26-bit converter shows up in the parametric search, either.
> Hi Rob, Try the LTC2441
Your search - *ltc2441* - did not match any documents.
No pages were found containing *"ltc2441"*.
- Rob.
MK
m k
Thu, Nov 10, 2011 9:50 PM
Hi Rob,
It was the LTC 2440 and 2442.
volt-nuts mailing list -- volt-nuts@febo.com
To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/volt-nuts
Hi Rob,
> Date: Thu, 10 Nov 2011 22:36:10 +0100
> - Rob.
> _______________________________________________
AJ
Andreas Jahn
Thu, Nov 10, 2011 10:48 PM
Hello MK,
did you already build a real cirquit with the LTC2440?
It has a differential input 2.5+/-2.5V for bridge measurement cirquits like
weight scales.
So I think it will be difficult to get a unipolar 0..5V measurement out of
this device without resistive divider.
Which buffer cirquits do you use to feed the low-impedant (capacitive)
inputs?
With best regards
Andreas
----- Original Message -----
Sent: Thursday, November 10, 2011 10:50 PM
Hi Rob,
Hello MK,
weight scales.
inputs?
With best regards
Andreas
To: <volt-nuts@febo.com>
> Hi Rob,
>> - Rob.
RE
Randy Evans
Fri, Nov 11, 2011 4:01 AM
The ADS1282 alswo only has a 5V unipolar input range and I want a 0 to 12V input range without dividers. I don't have any information on the Solartron 7081.
Randy
Sent: Thursday, November 10, 2011 9:17 AM
Subject: Re[2]: [volt-nuts] Homebrew DVM
Hi, Randy!
integration time.
Mickle T.
RE>
RE>
RE> Randy
Randy
Hi, Randy!
integration time.
Mickle T.
RE>
RE>
RE> Randy
AJ
Andreas Jahn
Fri, Nov 11, 2011 5:33 AM
Hello Randy,
with a capacitive divider 2:1 or 3:1 based on a LTC1043 + LT1051
you can extend the 5V range to 10 or 15 V. The capacitive divider
is very stable over temperature and time.
With my 2:1 dividers I have less than 1 ppm drift over a
10-40 degrees (celsius) temperature range.
Absolute accuracy of the divider factor depends mainly on
charge injection of the switch and capacitor losses.
I measured values between 2-10ppm depending on different
pin configurations. Im not shure wether the examples in the
datasheet are using the correct pin numbers for minimum charge injection.
Another Question: how do you get a unipolar 0..5V range with a ADS1282?
The absolute input of the PGA-Amplifier is specified from 0.7 .. 3.75V.
With best regards
Andreas
To: "Михаил" timka2k@yandex.ru; "Discussion of precise voltage
measurement" volt-nuts@febo.com
Sent: Friday, November 11, 2011 5:01 AM
Solartron 7081.
Randy
Hi, Randy!
7081
integration time.
Mickle T.
RE>
input
Also,
AN-260
RE>
RE> Randy
Hello Randy,
With best regards
Andreas
To: "Михаил" <timka2k@yandex.ru>; "Discussion of precise voltage
measurement" <volt-nuts@febo.com>
> Solartron 7081.
> Randy
> From: Михаил <timka2k@yandex.ru>
> Hi, Randy!
> 7081
> integration time.
> Mickle T.
> RE>
> input
> Also,
> AN-260
> RE>
> RE> Randy
MK
m k
Fri, Nov 11, 2011 7:28 AM
Hi,
I have not built one yet, but it seems to be one of a very few that goes beyond 24 bits.
MK
Date: Thu, 10 Nov 2011 23:48:10 +0100
Hello MK,
weight scales.
inputs?
With best regards
Andreas
Hi Rob,
Hi,
MK
> From: Andreas_-_Jahn@t-online.de
> Hello MK,
> weight scales.
> inputs?
> With best regards
> Andreas
> From: "m k" <m1k3k1@hotmail.com>
> > Hi Rob,
> >> - Rob.
JD
John Devereux
Mon, Nov 14, 2011 7:42 AM
be apprecitated.
Hi Randy,
I have an ambition to do this too. But I think there are better circuit
arrangements that are not really any more complicated. Or at least it
seems that way right now, before I have tried to make them work!
Firstly you have to make a pretty good circuit before you can beat a
cheap single-chip sigma-delta ADC, as others have pointed out. That
application note predates these I think.
You could look at some of the patents on multislope converters (as used
in the HP3458A, and all the top meters as far as I know). They are
surprisingly readable. Also many of them have expired by now, although
that does not matter for educational use.
The "basic" HP patent is 4357600:
http://www.google.com/patents?id=vCUxAAAAEBAJ
I think this is the HP3458A.
There is a later HP one 4951053 which refines it with a greatly improved
switching technique http://www.google.com/patents?id=INImAAAAEBAJ. But
the 3458A does not use it AFAIK.
Then fluke get in the game with 5321403 and 5565869, describing a
switching sequence with imnproved elimination of charge injection
errors. (These have not expired).
There are lots of others if you search on "multislope" but I found these
the most interesting.
John Devereux
Randy Evans <randallgrayevans@yahoo.com> writes:
> be apprecitated.
Hi Randy,
<http://www.google.com/patents?id=vCUxAAAAEBAJ>
switching technique <http://www.google.com/patents?id=INImAAAAEBAJ>. But
John Devereux
RE
Randy Evans
Mon, Nov 14, 2011 11:10 PM
John,
Thanks for the info. I will read them tonight and assess wether I want to proceed with my original plan or revisit it. I have no particular preference, just what is easiest and cheapest but high resolution and accurate.
Randy
Cc: Discussion of precise voltage measurement volt-nuts@febo.com
Sent: Sunday, November 13, 2011 11:42 PM
Randy Evans randallgrayevans@yahoo.com writes:
be apprecitated.
Hi Randy,
John Devereux
John,
Randy
Cc: Discussion of precise voltage measurement <volt-nuts@febo.com>
> be apprecitated.
Hi Randy,
John Devereux
RS
Randy Scott
Mon, Nov 14, 2011 11:42 PM
Thanks for the info. I will read them tonight and assess whether
The Wikipedia page on the integrating ADC also has some more
description on the basic dual-slope ADC as well as some of the
enhancements that have been made to it over the years. Some
of the material from the patents is mentioned as well.
http://en.wikipedia.org/wiki/Integrating_ADC
Many of the designs end up being quite simple, but the devil
is in the details, obviously.
What I find most interesting about the design is that, in many
cases, components with absolute precision are not required.
Stability and low TC are what is needed and sometimes the
ratio of certain critical values are important. Everything
else can be calibrated out at the end (within reason, of course).
Randy.
Randy.
FS
Fred Schneider
Mon, Nov 14, 2011 11:56 PM
I did some dual slope ADC experiments. Just on a breadboard and using an Arduino for the math and display. No fancy stuff. The VRef was just a resistive divider from the 5 V. It was just an experiment. Used a 4066, LF356 and a LM339 but the thing worked wonderfull. Got it stable up to 1 mV in a 1 V range. Not shocking but with a nice Vref, better switches, a real good capacitor it can be made better. While figuring out how that worked I misunderstood how it should work and by accident re-invented a ( self nulling) VF converter, using my counter as display. That was fun too.
Now I have a 26 bit ( 24 bit usable) ADC waiting to be used interfaced to the arduino, I am making/experimenting with some Vrefs and have parts for a compound chopper based on a LT1052. But the realisation will be up in the future, first gathering more knowledge about percision and micro volt techniques.
Fred PA4TIM
Op 15 nov. 2011 om 00:10 heeft Randy Evans randallgrayevans@yahoo.com het volgende geschreven:
John,
Randy
be apprecitated.
Hi Randy,
John Devereux
Fred PA4TIM
Op 15 nov. 2011 om 00:10 heeft Randy Evans <randallgrayevans@yahoo.com> het volgende geschreven:
> John,
> Randy
> From: John Devereux <john@devereux.me.uk>
>> be apprecitated.
> Hi Randy,
> John Devereux
PK
Poul-Henning Kamp
Tue, Nov 15, 2011 12:17 AM
Well, that's the fundamental trick of the integrating A/D: You
move the precision requirement to your timebase, and we are
much better at those, than at precision resistors/capacitors etc.
In message <1321314126.66316.YahooMailNeo@web161704.mail.bf1.yahoo.com>, Randy
Scott writes:
AJ
Andreas Jahn
Tue, Nov 15, 2011 5:38 AM
Did you check only noise and temperature or also linearity?
My experience is that with a simple dual slope integrator the capacitor
soaking creates big linearity errors.
I built my first dual slope with a 2,49V LM336 reference a 4051 and a TLC271
and a simple 1uF mylar capacitor.
Due to single supply I used the 2,5V of the reference as vitual ground. So
the input range of 0..5V was
divided into two ranges from 0..2.5 (negative with respect to virtual
ground) and from 2.5 to 5V. (positive).
With a simple mylar capacitor the non-linear gap between negative and
positive range was around 1 mV.
So linearity is only around 12 bits with this design. To reach this
linearity I had to do some software
trick to deal with the soakage. After each switching of the input
multiplexer to another channel I did
some waste A/D conversions with the new channel to let the capacitor
stabilize.
Years later I read the article of Bob Pease about capacitor soaking and
exchanged the mylar against
polypropylene. The non-linear gap is now around 100uV wich is around 15 bits
linearity.
At the moment I'm experimenting with the 24 bit LTC2400.
He has a unipolar input range of 0..5V (+ some mV overrange) with a 5V
reference.
The best results I get with a LT1027CCN8-5 reference. From the many
references
I tried up to now the LT1027 and MAX6250A in DIL-housing seem to be the best
when regarding hysteresis.
The effort to get around 10 ppm stability is enormous:
Galvanic isolated battery powered design.
Temperature of reference is measured and compensated by a NTC (3rd order
polynominal compensation)
Linearity of A/D-Converter is compensated. (see AN86 of LT)
The main issue is noise of the converter of around 20uVpp.
So to get less than 1 uV I have to integrate measurements over 10 minutes.
Reference drift is around 10 ppm over 1 year.
I am looking now for a converter with less noise.
So what ADC are You using?
With best regards
Andreas
To: "Randy Evans" randallgrayevans@yahoo.com; "Discussion of
precisevoltage measurement" volt-nuts@febo.com
Sent: Tuesday, November 15, 2011 12:56 AM
techniques.
Fred PA4TIM
John,
accurate.
Randy
be apprecitated.
Hi Randy,
John Devereux
Hello Fred,
stabilize.
linearity.
reference.
references
With best regards
Andreas
To: "Randy Evans" <randallgrayevans@yahoo.com>; "Discussion of
precisevoltage measurement" <volt-nuts@febo.com>
> techniques.
> Fred PA4TIM
>> John,
>> accurate.
>> Randy
>>> be apprecitated.
>> Hi Randy,
>> John Devereux
BG
Bruce Griffiths
Tue, Nov 15, 2011 5:54 AM
capacitor soaking creates big linearity errors.
TLC271 and a simple 1uF mylar capacitor.
ground. So the input range of 0..5V was
stabilize.
and exchanged the mylar against
15 bits linearity.
The HP3458A and the HP34401A ensure that the integrator output voltage
only represents a small fraction of the integral of the signal input.
This significantly reduces the effect of dielectric absorption in the
integrator feedback capacitor.
The integrator and control logic act somewhat like a sigma-delta
integrator during the runup phase.
The effect of dielectric absorption can be further reduced by suitable
choice of runup algorithm.
The on resistance modulation of analog switches in series with the
resistor connected between the signal and the integrator summing
junction can be a significant source of nonlinearity, however it is, in
principle, possible to correct for this.
Bruce
Andreas Jahn wrote:
> Hello Fred,
> stabilize.
> 15 bits linearity.
Bruce
FS
Fred Schneider
Tue, Nov 15, 2011 7:46 AM
No, did not check all. Just hooked up a powersupply and looked what it did. It was at first absolute not lineair. Before it was finished my ardiuno went up in smoke because of the breadboard ( +5 V jumped out and I did not think and just pushed it back in the +15V rail) but It was not very lineair until I made a sort of autozero and used a correction factor. After that it was sort of lineair, I had made it so that it did a measurement of the test-voltage then It switched the input to ground and made a second measurement. That value I used to correct the other.
It was just for fun, to learn about the principle of ADCs. But it infected me with the volt nut virus.
It was not intended to become a real meter.
http://www.pa4tim.nl/?p=2482 there you see the schematic and some pictures ( the top one is from the circuit that, i was told, turned out to be a VF converter)
Fred PA4TIM
Op 15 nov. 2011 om 06:38 heeft "Andreas Jahn" Andreas_-_Jahn@t-online.de het volgende geschreven:
My experience is that with a simple dual slope integrator the capacitor soaking creates big linearity errors.
I built my first dual slope with a 2,49V LM336 reference a 4051 and a TLC271 and a simple 1uF mylar capacitor.
Due to single supply I used the 2,5V of the reference as vitual ground. So the input range of 0..5V was
divided into two ranges from 0..2.5 (negative with respect to virtual ground) and from 2.5 to 5V. (positive).
With a simple mylar capacitor the non-linear gap between negative and positive range was around 1 mV.
So linearity is only around 12 bits with this design. To reach this linearity I had to do some software
trick to deal with the soakage. After each switching of the input multiplexer to another channel I did
some waste A/D conversions with the new channel to let the capacitor stabilize.
Years later I read the article of Bob Pease about capacitor soaking and exchanged the mylar against
polypropylene. The non-linear gap is now around 100uV wich is around 15 bits linearity.
He has a unipolar input range of 0..5V (+ some mV overrange) with a 5V reference.
The best results I get with a LT1027CCN8-5 reference. From the many references
Temperature of reference is measured and compensated by a NTC (3rd order polynominal compensation)
With best regards
Andreas
----- Original Message ----- From: "Fred Schneider" pa4tim@gmail.com
To: "Randy Evans" randallgrayevans@yahoo.com; "Discussion of precisevoltage measurement" volt-nuts@febo.com
Fred PA4TIM
John,
Randy
be apprecitated.
Hi Randy,
John Devereux
Fred PA4TIM
Op 15 nov. 2011 om 06:38 heeft "Andreas Jahn" <Andreas_-_Jahn@t-online.de> het volgende geschreven:
> Hello Fred,
> With best regards
> Andreas
> ----- Original Message ----- From: "Fred Schneider" <pa4tim@gmail.com>
> To: "Randy Evans" <randallgrayevans@yahoo.com>; "Discussion of precisevoltage measurement" <volt-nuts@febo.com>
>> Fred PA4TIM
>>> John,
>>> Randy
>>>> be apprecitated.
>>> Hi Randy,
>>> John Devereux
AJ
Andreas Jahn
Tue, Nov 15, 2011 10:19 PM
Hello Fred,
I asked for the 26 bit (24 bit usable) ADC.
Do you really get this (noiseless) resolution with a simple dual slope ADC?
With best regards
Andreas
converter)
Fred PA4TIM
volt techniques.
Fred PA4TIM
Hello Fred,
With best regards
Andreas
> converter)
> Fred PA4TIM
>>> volt techniques.
>>> Fred PA4TIM
F
Fred
Wed, Nov 16, 2011 12:20 AM
The ADC I am gonna use is the LTC2400. A friend who is a digit-nut made
the pcb and will make the software for me.
About the dual slope experiment. I could look better as it is. The
arduino died before I could do more tests but first results amazed me.
Remember it was just breadboard, no Vref (just resistive divider from
Vcc and, I do not dare to say, but the measurement pictures were taken
after I blew up my last 4066, so I used optocouplers to switch and
strange enough that went very well.
The drift you see in the measurements is more because the powersupply I
measured the voltage from, is not realy stable. Noise I do not know.
The experiment was after a discussion on a Dutch forum. There was some
talk about multimeters and ADCs and the a member who works at ST as an
EE told the top meters used dual slope about how easy it is to make a
dual slope ADC. He told us to just try it on a breadboard and gave some
tips. A few of us including me started experimenting with it and I was
trilled it was so easy to get it working like it did. Was fun too. I'm
now reading a lot of literature and your interesting discussions to
learn more before I build my meter using the LTC2400. So thanks for all
the valuable information. As a beginner I appreciate it very much.
Fred PA4TIM
Andreas Jahn schreef op di 15-11-2011 om 23:19 [+0100]:
Hello Fred,
With best regards
Andreas
converter)
Fred PA4TIM
volt techniques.
Fred PA4TIM
Fred PA4TIM
> Hello Fred,
> With best regards
> Andreas
> > converter)
> > Fred PA4TIM
> >>> volt techniques.
> >>> Fred PA4TIM
SK
Stan Katz
Wed, Nov 16, 2011 1:47 AM
I would think that Ron Tipton's 6 1/2 digit diy DVM, based on LTC2400 and a
statistical pool of Thaler(now Cirrus) VRE305A's would be the baseline
design to beat in this thread's quest for excellence. Yes?
www.tdl-tech.com/hires-vm.pdf
Stan
Fred PA4TIM
Hello Fred,
With best regards
Andreas
volt techniques.
Fred PA4TIM
Stan
> Fred PA4TIM
> > Hello Fred,
> ADC?
> > With best regards
> > Andreas
> pictures
> VF
> > > converter)
> > > Fred PA4TIM
> interfaced
> parts
> be up
> micro
> > >>> volt techniques.
> > >>> Fred PA4TIM
AJ
Andreas Jahn
Wed, Nov 16, 2011 7:50 AM
Ok Fred,
thats the ADC im currently using too.
Although he has internally a readout of 28 Bits due to noise only 18-19 Bits
are usable.
To further reduce noise you will have to average many measurement values.
On the other side against many other sigma delta chips the LT2400
has very low offset and gain drift over temperature. And the main advantage
is the Overrange feature of +/-12% which makes offset and full scale
adjustment easy.
Im still hoping that someone knows a ADC chip with less noise
and true 0..5V (or even 0..10V) input with the overrange feature.
With best regards
Andreas
To: "Discussion of precise voltage measurement" volt-nuts@febo.com
Sent: Wednesday, November 16, 2011 1:20 AM
the valuable information. As a beginner I appreciateitverymuch.
Fred PA4TIM
Hello Fred,
ADC?
With best regards
Andreas
pictures
VF
converter)
Fred PA4TIM
interfaced
parts
up
micro
volt techniques.
Fred PA4TIM
Ok Fred,
are usable.
adjustment easy.
With best regards
Andreas
To: "Discussion of precise voltage measurement" <volt-nuts@febo.com>
> Fred PA4TIM
>> Hello Fred,
>> ADC?
>> With best regards
>> Andreas
>> > pictures
>> > VF
>> > converter)
>> > Fred PA4TIM
>> >>> interfaced
>> >>> parts
>> >>> up
>> >>> micro
>> >>> volt techniques.
>> >>> Fred PA4TIM
AJ
Andreas Jahn
Wed, Nov 16, 2011 8:10 AM
Hello Stan,
thanks for the article
he shows some of the key issues with precision A/D converters.
Although with the noise he mixes Vpp with rms values.
On the other side I have bougth recently two VRE3050A-References from
Cirrus.
(speced nearly the same than VRE305A but only usable with lower minimum
power supply voltage)
For the 3uVpp noise I found something around 9uVpp. (0.1-10 Hz)
Whereas on a LT1027C I measure around 1.9uVpp with the same
filter-amplifier.
And even with temperature hysteresis the VRE3050A that I have measured
is much worse than a LT1027 in a 10-40 degree (Celsius) range.
So I would be interested if the VRE305A is much better than the VRE3050A or
if the specs have
changed when renaming the references from Thaler to Cirrus.
Do you have any measurement values of some recently bought Cirrus VRE305?
With best regards
Andreas
To: pa4tim@gmail.com; "Discussion of precise voltage measurement"
volt-nuts@febo.com
Sent: Wednesday, November 16, 2011 2:47 AM
Stan
Fred PA4TIM
Hello Fred,
With best regards
Andreas
a
volt techniques.
Fred PA4TIM
Hello Stan,
Cirrus.
filter-amplifier.
if the specs have
With best regards
Andreas
To: <pa4tim@gmail.com>; "Discussion of precise voltage measurement"
> Stan
>> Fred PA4TIM
>> > Hello Fred,
>> ADC?
>> > With best regards
>> > Andreas
>> pictures
>> > > a
>> VF
>> > > converter)
>> > > Fred PA4TIM
>> interfaced
>> parts
>> be up
>> micro
>> > >>> volt techniques.
>> > >>> Fred PA4TIM
SK
Stan Katz
Wed, Nov 16, 2011 9:48 PM
Hi Andreas,
I own no VRE305A references. However, if you take a look at a co-marketing
article between TI and Thaler in the Nov. 1999 TI Applications Journal, the
typical noise spec for the VRE3050 back then was listed as 3uv between
.1-10hz, just as good as the VRE305A references Tipton used. However, when
one looks at the noise specs in the datasheets for VRE3050 on the current
Cirrus site, and at the original Thaler datasheets for VRE305/VRE3050 the
maximum/minimum noise specs bounding the 3uv typical are unspecified. I
find this unusual for such a pricey unit.
Stan
On Wed, Nov 16, 2011 at 3:10 AM, Andreas Jahn Andreas_-_Jahn@t-online.dewrote:
Hello Stan,
Cirrus.
filter-amplifier.
or if the specs have
With best regards
Andreas
----- Original Message ----- From: "Stan Katz" stan.katz.hk@gmail.com
To: pa4tim@gmail.com; "Discussion of precise voltage measurement" <
volt-nuts@febo.com>
a
Stan
Fred PA4TIM
Hello Fred,
With best regards
Andreas
a
volt techniques.
Fred PA4TIM
Hi Andreas,
Stan
On Wed, Nov 16, 2011 at 3:10 AM, Andreas Jahn <Andreas_-_Jahn@t-online.de>wrote:
> Hello Stan,
> Cirrus.
> filter-amplifier.
> With best regards
> Andreas
> ----- Original Message ----- From: "Stan Katz" <stan.katz.hk@gmail.com>
> To: <pa4tim@gmail.com>; "Discussion of precise voltage measurement" <
> volt-nuts@febo.com>
>> a
>> Stan
>>> Fred PA4TIM
>>> > Hello Fred,
>>> ADC?
>>> > With best regards
>>> > Andreas
>>> pictures
>>> > > a
>>> VF
>>> > > converter)
>>> > > Fred PA4TIM
>>> interfaced
>>> parts
>>> be up
>>> micro
>>> > >>> volt techniques.
>>> > >>> Fred PA4TIM
>>> > ______________________________**_________________
>>> https://www.febo.com/cgi-bin/**mailman/listinfo/volt-nuts<https://www.febo.com/cgi-bin/mailman/listinfo/volt-nuts>
>> To unsubscribe, go to https://www.febo.com/cgi-bin/**
