In a message dated 10/18/2006 12:26:09 A.M. Eastern Daylight Time,
kb7nie@arrl.net writes:
The November QST has an announcement for the "2006 Frequency Measuring Test"
( www.arrl.org/w1aw/fmt - though the 2006 announcement has not made it to
the website yet). The object is to determine as accurately as possible the
carrier frequency of a signal sent from W1AW on the 160m, 80m and 40m
bands. There will also be a signal sent from the west coast on the 40m
band. A lot of time nuts are hams. Who plans on participating?
Henry
time-nuts mailing list
time-nuts@febo.com
Henry...
The FMT is a must on my calendar!!
73, Don, W4WJ
I had planned to participate the last 2 years, but got distracted both
times. Hopefully, this year will be the charm :-)
I better have my GPS stabilized clock working by then (to drive the HP
3586A receiver, and the HP 3570A counter for the decoded audio), no more
excuses...
Interestingly, the HP 5370A measures the 10 MHz timebase of the 3586 as
10,000,000.010 Hz after warmup (0.1sec gate time), and without any
adjustment. Both use 10811 crystal ovens (high stability option). I
calibrated the 3586 against WWV earlier this year, which could only get
me to within 0.1Hz anyhow) but I would be surprised if the 5370A (just
purchased) has been calibrated in the last 10 years.
Didier KO4BB
Henry
I have participated the past few years mostly with the N8UR multi-op group.
My setup is as follows:
The process is to locate the W1AW signal on the receiver and Spectrum Lab
waterfall display. I then bring the signal generator online and insert a
carrier near the W1AW signal. I measure the difference between the signal
generator audio tone and the W1AW audio tone as observed by Spectrum Lab.
Spectrum Lab is setup to record a WAV file so I can post-process the data if
needed. I also have Spectrum Lab set to output the readings to a text file.
This way I can pull them into a spreadsheet to do the calculations and
average the readings. Since I know the frequency of the signal generator I
can calculate the carrier of W1AW using the difference in audio tone between
my generator and W1AW. If they want us to measure an audio tone as last year
the same setup applies. When doing the calculations you just have to
remember if the receiver was in LSB or USB and which side of the W1AW signal
the signal generator was on.
I participated last year but ended up messing up the data files so I did not
make a submission. In the tests I participated my readings were within the
same range as N8UR's.
I have used the same setup for measuring signals on HF, TV carriers and the
HDTV pilot signals. It is amazing how many TV signals I can detect using
the ICOM R-7000 receiver, Discone antenna up 60-feet, and Spectrum Lab to
dig the carriers out of the noise. In the case of channel 3 I can detect
three analog TV carriers because of the carrier offsets (+/-/0). I think
they are from Huntington, WV, Louisville, KY, and Cleveland, OH.
Mike
WB8GXB
Test"
the
Henry
time-nuts@febo.com
