Version 0.9 has been released
BP
Benny Prijono
Sun, Jun 29, 2008 12:41 PM
Dear all,
FYI Version 0.9.0 is now available from the website. Please grab it
from http://www.pjsip.org/download.htm while it's hot. :)
Cheers
Benny
Dear all, FYI Version 0.9.0 is now available from the website. Please grab it from http://www.pjsip.org/download.htm while it's hot. :) Cheers Benny
P
programmer
Mon, Jun 30, 2008 8:51 AM
Thankyou so much Benny, your work
is great and very appreciated!!
Cheers!
Andrea / Italy / Florence
----- Original Message -----
To: "pjsip list" pjsip@lists.pjsip.org
Sent: Sunday, June 29, 2008 2:41 PM
Subject: [pjsip] Version 0.9 has been released
Dear all,
Cheers
Benny
Visit our blog: http://blog.pjsip.org
pjsip mailing list
http://lists.pjsip.org/mailman/listinfo/pjsip_lists.pjsip.org
Thankyou so much Benny, your work is great and very appreciated!! Cheers! Andrea / Italy / Florence ----- Original Message ----- From: "Benny Prijono" <bennylp@pjsip.org> To: "pjsip list" <pjsip@lists.pjsip.org> Sent: Sunday, June 29, 2008 2:41 PM Subject: [pjsip] Version 0.9 has been released > Dear all, > > FYI Version 0.9.0 is now available from the website. Please grab it > from http://www.pjsip.org/download.htm while it's hot. :) > > Cheers > Benny > > _______________________________________________ > Visit our blog: http://blog.pjsip.org > > pjsip mailing list > pjsip@lists.pjsip.org > http://lists.pjsip.org/mailman/listinfo/pjsip_lists.pjsip.org >
BP
Benny Prijono
Mon, Jun 30, 2008 9:32 AM
Thanks for the kind words. It's a joint effort from all of us and the
community of course. We wouldn't get this far if we don't constantly
get feedbacks, bug reports, suggestions, and sometimes hassling from
all of you (I could use less of the later ;-) ).
So kudos for everyone!
Cheers
Benny
On Mon, Jun 30, 2008 at 9:51 AM, programmer <programmer@supereva.it> wrote: > Thankyou so much Benny, your work > is great and very appreciated!! > Thanks for the kind words. It's a joint effort from all of us and the community of course. We wouldn't get this far if we don't constantly get feedbacks, bug reports, suggestions, and sometimes hassling from all of you (I could use less of the later ;-) ). So kudos for everyone! Cheers Benny
AR
Archie Rosenblum
Tue, Aug 19, 2008 3:32 AM
The IPP release is very exciting.  I found a couple of small compile issues
I would like to bring to your attention.
Instructions say to define PJMEDIA_HAS_INTEL_IPP.  I believe define should
be PJMEDIA_HAS_INTEL_IPP_CODECS
In ipp_codecs.c, the matching #endif for the line #if
defined(PJMEDIA_HAS_INTEL_IPP_CODEC_AMR) && PJMEDIA_HAS_INTEL_IPP_CODEC_AMR
!= 0 goes five lines too far.
Excellent job.  Thank you for including IPP support as part of your system.
Best regards,
Archie
The IPP release is very exciting. I found a couple of small compile issues I would like to bring to your attention. Instructions say to define PJMEDIA_HAS_INTEL_IPP. I believe define should be PJMEDIA_HAS_INTEL_IPP_CODECS In ipp_codecs.c, the matching #endif for the line #if defined(PJMEDIA_HAS_INTEL_IPP_CODEC_AMR) && PJMEDIA_HAS_INTEL_IPP_CODEC_AMR != 0 goes five lines too far. Excellent job. Thank you for including IPP support as part of your system. Best regards, Archie
A
atik
Tue, Aug 19, 2008 5:43 AM
also its time to have an update on this section :)
http://trac.pjsip.org/repos/wiki/FAQ#g729-g723
regards
atik
On Tue, Aug 19, 2008 at 11:32 AM, Archie Rosenblum <archie@bbsti.com> wrote: > Instructions say to define PJMEDIA_HAS_INTEL_IPP. I believe define > should be PJMEDIA_HAS_INTEL_IPP_CODECS > also its time to have an update on this section :) http://trac.pjsip.org/repos/wiki/FAQ#g729-g723 regards atik
MK
Manoj Kumar Joshi
Tue, Aug 19, 2008 6:52 AM
Hey Archie,
Where are the IPP related instructions?
Regards,
Manoj
-----Original Message-----
[mailto:pjsip-bounces@lists.pjsip.org]On Behalf Of Archie Rosenblum
Sent: Tuesday, August 19, 2008 9:03 AM
To: 'pjsip list'
Subject: [pjsip] Intel IPP Support
system.
Best regards,
Archie
Hey Archie, Where are the IPP related instructions? Regards, Manoj -----Original Message----- From: pjsip-bounces@lists.pjsip.org [mailto:pjsip-bounces@lists.pjsip.org]On Behalf Of Archie Rosenblum Sent: Tuesday, August 19, 2008 9:03 AM To: 'pjsip list' Subject: [pjsip] Intel IPP Support The IPP release is very exciting. I found a couple of small compile issues I would like to bring to your attention. Instructions say to define PJMEDIA_HAS_INTEL_IPP. I believe define should be PJMEDIA_HAS_INTEL_IPP_CODECS In ipp_codecs.c, the matching #endif for the line #if defined(PJMEDIA_HAS_INTEL_IPP_CODEC_AMR) && PJMEDIA_HAS_INTEL_IPP_CODEC_AMR != 0 goes five lines too far. Excellent job. Thank you for including IPP support as part of your system. Best regards, Archie
MK
Manoj Kumar Joshi
Tue, Aug 19, 2008 7:20 AM
Hello,
I have seen IPP related release. Are these codecs supposed to work with
Symbian port as well?
Regards,
Manoj
Hello, I have seen IPP related release. Are these codecs supposed to work with Symbian port as well? Regards, Manoj
FP
Fabio Pietrosanti (naif)
Tue, Aug 19, 2008 7:39 AM
Manoj Kumar Joshi wrote:
Hello,
If you want to achieve something similar to IPP, the S60 APS for Symbian
9 should be integrated inside PJMEDIA to handle directly the hardware
codec support of S60 APS.
This will cut-off some feature like "conference calling", but this would
be the best approach in terms of performance and integration of pjsip on
S60.
Consider that APS provide you even AMR 4.75 with DTX (statistically
average 2.36kbit)!
If you want to invest following that path let me know
Fabio
Manoj Kumar Joshi wrote: > Hello, > > I have seen IPP related release. Are these codecs supposed to work > with Symbian port as well? If you want to achieve something similar to IPP, the S60 APS for Symbian 9 should be integrated inside PJMEDIA to handle directly the hardware codec support of S60 APS. This will cut-off some feature like "conference calling", but this would be the best approach in terms of performance and integration of pjsip on S60. Consider that APS provide you even AMR 4.75 with DTX (statistically average 2.36kbit)! If you want to invest following that path let me know Fabio
MK
Manoj Kumar Joshi
Tue, Aug 19, 2008 8:08 AM
Thanks for replying Fabio. What about open g729 ?...i guess someone has
already integrated it?
[mailto:pjsip-bounces@lists.pjsip.org]On Behalf Of Fabio Pietrosanti
(naif)
Sent: Tuesday, August 19, 2008 1:10 PM
To: pjsip list
Subject: Re: [pjsip] Intel IPP Question
Hello,
S60.
average 2.36kbit)!
Fabio
pjsip mailing list
No virus found in this incoming message.
Checked by AVG.
Version: 7.5.524 / Virus Database: 270.6.3/1612 - Release Date: 8/14/2008
6:03 PM
Thanks for replying Fabio. What about open g729 ?...i guess someone has already integrated it? -----Original Message----- From: pjsip-bounces@lists.pjsip.org [mailto:pjsip-bounces@lists.pjsip.org]On Behalf Of Fabio Pietrosanti (naif) Sent: Tuesday, August 19, 2008 1:10 PM To: pjsip list Subject: Re: [pjsip] Intel IPP Question Manoj Kumar Joshi wrote: > Hello, > > I have seen IPP related release. Are these codecs supposed to work > with Symbian port as well? If you want to achieve something similar to IPP, the S60 APS for Symbian 9 should be integrated inside PJMEDIA to handle directly the hardware codec support of S60 APS. This will cut-off some feature like "conference calling", but this would be the best approach in terms of performance and integration of pjsip on S60. Consider that APS provide you even AMR 4.75 with DTX (statistically average 2.36kbit)! If you want to invest following that path let me know Fabio _______________________________________________ Visit our blog: http://blog.pjsip.org pjsip mailing list pjsip@lists.pjsip.org http://lists.pjsip.org/mailman/listinfo/pjsip_lists.pjsip.org -- No virus found in this incoming message. Checked by AVG. Version: 7.5.524 / Virus Database: 270.6.3/1612 - Release Date: 8/14/2008 6:03 PM
FP
Tue, Aug 19, 2008 8:16 AM
If you want to stay on S60 Symbian, like it seems to me, again the APS
provide you also the G729 codec:
http://wiki.forum.nokia.com/index.php/Audio_Proxy_Server
APS supports audio streaming using the following codecs:
AMR
G711
G729
iLBC
Fabio
Ok..i guess open g729 is a bad idea. I guess i will go ahead with the
apprroach you suggest. However I tried to compile with IPP code and getting
issues ...may be i am missing somthing.
First i got usc*.h files issues which were solved when i copied these files
....after that i am getting ippcore.lib issuess...do i need to download this
file from somewhere else?
If you want to stay on S60 Symbian, like it seems to me, again the APS provide you also the G729 codec: http://wiki.forum.nokia.com/index.php/Audio_Proxy_Server APS supports audio streaming using the following codecs: AMR G711 G729 iLBC Fabio Manoj Kumar Joshi wrote: > Ok..i guess open g729 is a bad idea. I guess i will go ahead with the > apprroach you suggest. However I tried to compile with IPP code and getting > issues ...may be i am missing somthing. > First i got usc*.h files issues which were solved when i copied these files > ....after that i am getting ippcore.lib issuess...do i need to download this > file from somewhere else? >
