Using TLS support for SRTP for PJSUA-lib
CI
CalvIA IA
Thu, Oct 16, 2008 2:59 AM
Hi,
I'm trying to set up a TLS transport on my WM 6 app built using PJSUA.
I have installed the OpenSSL SDK for Windows.
included the library files,
  • For Debug build: libeay32MTd and ssleay32MTd.
  • For Release build: libeay32MT and ssleay32MT.
set PJSIP_HAS_TLS_TRANSPORT = 1 in config_site.h
added a tls transport to my WM6 app
"status = pjsua_transport_create(PJSIP_TRANSPORT_TLS, &tcp_cfg,
&transport_id);"
when compiled i get this error:
Error 1 error LNK2019: unresolved external symbol pjsip_tls_transport_start
referenced in function pjsua_transport_create pjsua_lib_wince.lib
Error 2 fatal error LNK1120: 1 unresolved externals Windows Mobile 6
Professional SDK
Any one can help?
Thanks.
Calvin
Hi, I'm trying to set up a TLS transport on my WM 6 app built using PJSUA. I have installed the OpenSSL SDK for Windows. included the library files, - For Debug build: libeay32MTd and ssleay32MTd. - For Release build: libeay32MT and ssleay32MT. set PJSIP_HAS_TLS_TRANSPORT = 1 in config_site.h added a tls transport to my WM6 app "status = pjsua_transport_create(PJSIP_TRANSPORT_TLS, &tcp_cfg, &transport_id);" when compiled i get this error: Error 1 error LNK2019: unresolved external symbol pjsip_tls_transport_start referenced in function pjsua_transport_create pjsua_lib_wince.lib Error 2 fatal error LNK1120: 1 unresolved externals Windows Mobile 6 Professional SDK Any one can help? Thanks. Calvin
NI
Nanang Izzuddin
Thu, Oct 16, 2008 4:20 PM
Hi,
It seems TLS on WM platform is disabled on purpose (sorry, not sure
what the reason is). However regarding linking problem, it is caused
by file pjsip/sip_transport_tls_ossl.c is not part of pjsip_core_wince
project, please try to add that file to pjsip_core_wince project, not
sure if that file could be compiled fine on WM platform though.
Regards,
nanang
On Thu, Oct 16, 2008 at 9:59 AM, CalvIA IA calvia08@gmail.com wrote:
Hi,
&transport_id);"
Professional SDK
Any one can help?
Thanks.
Calvin
Visit our blog: http://blog.pjsip.org
pjsip mailing list
pjsip@lists.pjsip.org
http://lists.pjsip.org/mailman/listinfo/pjsip_lists.pjsip.org
Hi, It seems TLS on WM platform is disabled on purpose (sorry, not sure what the reason is). However regarding linking problem, it is caused by file pjsip/sip_transport_tls_ossl.c is not part of pjsip_core_wince project, please try to add that file to pjsip_core_wince project, not sure if that file could be compiled fine on WM platform though. Regards, nanang On Thu, Oct 16, 2008 at 9:59 AM, CalvIA IA <calvia08@gmail.com> wrote: > Hi, > I'm trying to set up a TLS transport on my WM 6 app built using PJSUA. > I have installed the OpenSSL SDK for Windows. > included the library files, > > For Debug build: libeay32MTd and ssleay32MTd. > For Release build: libeay32MT and ssleay32MT. > > set PJSIP_HAS_TLS_TRANSPORT = 1 in config_site.h > added a tls transport to my WM6 app > "status = pjsua_transport_create(PJSIP_TRANSPORT_TLS, &tcp_cfg, > &transport_id);" > > when compiled i get this error: > Error 1 error LNK2019: unresolved external symbol pjsip_tls_transport_start > referenced in function pjsua_transport_create pjsua_lib_wince.lib > Error 2 fatal error LNK1120: 1 unresolved externals Windows Mobile 6 > Professional SDK > Any one can help? > Thanks. > Calvin > > > _______________________________________________ > Visit our blog: http://blog.pjsip.org > > pjsip mailing list > pjsip@lists.pjsip.org > http://lists.pjsip.org/mailman/listinfo/pjsip_lists.pjsip.org > >
CI
CalvIA IA
Fri, Oct 17, 2008 1:07 AM
Hi Nanang,
Yep, after posting I did try including sip_transport_tls.h
and sip_transport_tls_ossl.c into wince project.
The result is still unable to compile.
Anyone tried implementing TLS on PJSUA/Wince?
I am sure SSL/TLS works on WM cause I have tried OpenVPN on WM 6 devices and
it too uses OpenSSL.
Regards,
Calvin
On Fri, Oct 17, 2008 at 12:20 AM, Nanang Izzuddin nanang@pjsip.org wrote:
Hi,
Regards,
nanang
Hi,
&transport_id);"
Professional SDK
Any one can help?
Thanks.
Calvin
pjsip mailing list
Hi Nanang, Yep, after posting I did try including sip_transport_tls.h and sip_transport_tls_ossl.c into wince project. The result is still unable to compile. Anyone tried implementing TLS on PJSUA/Wince? I am sure SSL/TLS works on WM cause I have tried OpenVPN on WM 6 devices and it too uses OpenSSL. Regards, Calvin On Fri, Oct 17, 2008 at 12:20 AM, Nanang Izzuddin <nanang@pjsip.org> wrote: > Hi, > > It seems TLS on WM platform is disabled on purpose (sorry, not sure > what the reason is). However regarding linking problem, it is caused > by file pjsip/sip_transport_tls_ossl.c is not part of pjsip_core_wince > project, please try to add that file to pjsip_core_wince project, not > sure if that file could be compiled fine on WM platform though. > > Regards, > nanang > > > On Thu, Oct 16, 2008 at 9:59 AM, CalvIA IA <calvia08@gmail.com> wrote: > > Hi, > > I'm trying to set up a TLS transport on my WM 6 app built using PJSUA. > > I have installed the OpenSSL SDK for Windows. > > included the library files, > > > > For Debug build: libeay32MTd and ssleay32MTd. > > For Release build: libeay32MT and ssleay32MT. > > > > set PJSIP_HAS_TLS_TRANSPORT = 1 in config_site.h > > added a tls transport to my WM6 app > > "status = pjsua_transport_create(PJSIP_TRANSPORT_TLS, &tcp_cfg, > > &transport_id);" > > > > when compiled i get this error: > > Error 1 error LNK2019: unresolved external symbol > pjsip_tls_transport_start > > referenced in function pjsua_transport_create pjsua_lib_wince.lib > > Error 2 fatal error LNK1120: 1 unresolved externals Windows Mobile 6 > > Professional SDK > > Any one can help? > > Thanks. > > Calvin > > > > > > _______________________________________________ > > Visit our blog: http://blog.pjsip.org > > > > pjsip mailing list > > pjsip@lists.pjsip.org > > http://lists.pjsip.org/mailman/listinfo/pjsip_lists.pjsip.org > > > > > > _______________________________________________ > Visit our blog: http://blog.pjsip.org > > pjsip mailing list > pjsip@lists.pjsip.org > http://lists.pjsip.org/mailman/listinfo/pjsip_lists.pjsip.org >
NI
Nanang Izzuddin
Fri, Oct 17, 2008 5:05 PM
Hi,
In case the compile errors are related to OpenSSL header, then you may
need to 'include' some part of the OpenSSL WINCE build configurations
(e.g: preprocessor settings) into pjsip_core_wince projects.
Regards,
nanang
On Fri, Oct 17, 2008 at 8:07 AM, CalvIA IA calvia08@gmail.com wrote:
Hi Nanang,
Regards,
Calvin
Hi,
Regards,
nanang
Hi,
&transport_id);"
Professional SDK
Any one can help?
Thanks.
Calvin
pjsip mailing list
Hi, In case the compile errors are related to OpenSSL header, then you may need to 'include' some part of the OpenSSL WINCE build configurations (e.g: preprocessor settings) into pjsip_core_wince projects. Regards, nanang On Fri, Oct 17, 2008 at 8:07 AM, CalvIA IA <calvia08@gmail.com> wrote: > Hi Nanang, > Yep, after posting I did try including sip_transport_tls.h > and sip_transport_tls_ossl.c into wince project. > > The result is still unable to compile. > Anyone tried implementing TLS on PJSUA/Wince? > I am sure SSL/TLS works on WM cause I have tried OpenVPN on WM 6 devices and > it too uses OpenSSL. > Regards, > Calvin > > On Fri, Oct 17, 2008 at 12:20 AM, Nanang Izzuddin <nanang@pjsip.org> wrote: >> >> Hi, >> >> It seems TLS on WM platform is disabled on purpose (sorry, not sure >> what the reason is). However regarding linking problem, it is caused >> by file pjsip/sip_transport_tls_ossl.c is not part of pjsip_core_wince >> project, please try to add that file to pjsip_core_wince project, not >> sure if that file could be compiled fine on WM platform though. >> >> Regards, >> nanang >> >> >> On Thu, Oct 16, 2008 at 9:59 AM, CalvIA IA <calvia08@gmail.com> wrote: >> > Hi, >> > I'm trying to set up a TLS transport on my WM 6 app built using PJSUA. >> > I have installed the OpenSSL SDK for Windows. >> > included the library files, >> > >> > For Debug build: libeay32MTd and ssleay32MTd. >> > For Release build: libeay32MT and ssleay32MT. >> > >> > set PJSIP_HAS_TLS_TRANSPORT = 1 in config_site.h >> > added a tls transport to my WM6 app >> > "status = pjsua_transport_create(PJSIP_TRANSPORT_TLS, &tcp_cfg, >> > &transport_id);" >> > >> > when compiled i get this error: >> > Error 1 error LNK2019: unresolved external symbol >> > pjsip_tls_transport_start >> > referenced in function pjsua_transport_create pjsua_lib_wince.lib >> > Error 2 fatal error LNK1120: 1 unresolved externals Windows Mobile 6 >> > Professional SDK >> > Any one can help? >> > Thanks. >> > Calvin >> > >> > >> > _______________________________________________ >> > Visit our blog: http://blog.pjsip.org >> > >> > pjsip mailing list >> > pjsip@lists.pjsip.org >> > http://lists.pjsip.org/mailman/listinfo/pjsip_lists.pjsip.org >> > >> > >> >> _______________________________________________ >> Visit our blog: http://blog.pjsip.org >> >> pjsip mailing list >> pjsip@lists.pjsip.org >> http://lists.pjsip.org/mailman/listinfo/pjsip_lists.pjsip.org > > > _______________________________________________ > Visit our blog: http://blog.pjsip.org > > pjsip mailing list > pjsip@lists.pjsip.org > http://lists.pjsip.org/mailman/listinfo/pjsip_lists.pjsip.org > >
