trawlers@lists.trawlering.com
TRAWLERS & TRAWLERING LIST
Notice to Mariners: Lock E-25 to Lock E-26 & Champlain
WH
Winter Harbor Marina
Fri, Aug 13, 2004 7:49 PM
Aug 13, 2004
Greetings from; "Hannah's Mommy" on the Erie Canal,
Mariners are advised of a temporary reduction in available water depth on the
Erie Canal between Lock E-25 and Lock E-26. Operational problems with a water
control structure at Lock-E-25 have left the water level nearly one foot below
normal levels.  The canal Corp. is working to resolve this problem and return
water levels to normal.  Any updates and changes in canal status will be
available at www.canals.state.ny.us and 1800-4canal4
Also-Champlain Canal has re-open from Lock C-11 to Lock C-12. Be advised that
the controlling vertical clearance for the Champlain Canal has been reduced to
15.5'. Watch out for Debris!!!! Closures may be necessary over the weekend
depending on the track of Hurricane Charlie.
Update: OOPS!  For any of you that read my desperate plea for a MHJ7103
PRESTOLITE STARTER. I said it was for 24volt-It's actually 32volt.  If anyone
has any leads-Please send them my way or contact me- Thank you-
Wishing you safe and healthy travels......
"Hannah's Mommy"
Aug 13, 2004 Greetings from; "Hannah's Mommy" on the Erie Canal, Mariners are advised of a temporary reduction in available water depth on the Erie Canal between Lock E-25 and Lock E-26. Operational problems with a water control structure at Lock-E-25 have left the water level nearly one foot below normal levels. The canal Corp. is working to resolve this problem and return water levels to normal. Any updates and changes in canal status will be available at www.canals.state.ny.us and 1800-4canal4 Also-Champlain Canal has re-open from Lock C-11 to Lock C-12. Be advised that the controlling vertical clearance for the Champlain Canal has been reduced to 15.5'. Watch out for Debris!!!! Closures may be necessary over the weekend depending on the track of Hurricane Charlie. Update: OOPS! For any of you that read my desperate plea for a MHJ7103 PRESTOLITE STARTER. I said it was for 24volt-It's actually 32volt. If anyone has any leads-Please send them my way or contact me- Thank you- Wishing you safe and healthy travels...... "Hannah's Mommy"
