Hi All,
I hope everyone is doing well.
I discovered that my stbd Spurs disappeared from the shaft. I inquired
about the price and discovered that to replace it is almost $800.
I was never happy with this system as I caught a net once and the Spurs
didn't cut it. I guess they're good for fishing line but if I'm going to
replace it I want something more robust if possible and less expensive if
that's possible.
Please share your experiences with these systems and recommend what you are
happy with. Thank you.
Regards,
Jim
Jim Felds
M/Y Kokomo
Hatteras 48 LRC
Lying Falmouth Harbour, Antigua
Jim,
Put the $800 in the "cruising kitty" to pay for a diver if one is ever
needed. Odds are in 5 to 10 years you'll still have most if not all of the
$800 still in the kitty. Or for about $800 you can rig yourself up a nice
little hookah rig set using an oiless air compressor, regulator, mask, fins,
knife, etc. to use to check/clear things as needed.
Just my two cents worth,
George
MV-Valhalla
"And the sea will grant each man new hope, as sleep brings dreams of home."
-----Original Message-----
From: Trawlers-and-Trawlering [mailto:trawlers-bounces@lists.trawlering.com]
On Behalf Of Felds, James via Trawlers-and-Trawlering
Sent: Friday, February 19, 2021 6:11 AM
To: Trawlers and Trawlering
Cc: Felds, James
Subject: T&T: Shaft rope cutters
Hi All,
that's possible.
Regards,
Jim
Jim Felds
M/Y Kokomo
Hatteras 48 LRC
http://lists.trawlering.com/mailman/listinfo/trawlers_lists.trawlering.com
To unsubscribe or modify your subscription options (get password, change
email address, etc) go to:
Trawlers & Trawlering and T&T are trademarks of Water World
Productions. Unauthorized use is prohibited.
Thanks for your input George. I have a hookah kit just as you describe
which is great if you're inshore in relatively calm seas. We however
cruise offshore and near shore and in the Caribbean, where we presently
lie, there are fish traps where you least expect them.
Jim Felds
M/Y Kokomo
Hatteras 48 LRC
On Fri, Feb 19, 2021, 11:39 AM George@mv-valhalla.com wrote:
Jim,
fins,
George
MV-Valhalla
Cc: Felds, James
Hi All,
that's possible.
Regards,
Jim
Jim Felds
M/Y Kokomo
Hatteras 48 LRC
Consider the Shaft Razor, $346 for 3” shaft. We had good experience with this unit on Winnie the Pooh, cutting a pot line on Florida Bay in rough weather at 5am when it would have been risky to get in the water.
Mark Richter
On Feb 19, 2021, at 10:39 AM, DieselTrawlerGuy via Trawlers-and-Trawlering trawlers@lists.trawlering.com wrote:
Jim,
George
MV-Valhalla
Cc: Felds, James
Hi All,
that's possible.
Regards,
Jim
Jim Felds
M/Y Kokomo
Hatteras 48 LRC
To unsubscribe or modify your subscription options (get password, change email address, etc) go to: http://lists.trawlering.com/mailman/listinfo/trawlers_lists.trawlering.com
