trawlers@lists.trawlering.com
TRAWLERS & TRAWLERING LIST
Re: T&T: Two batteries/one bilge pump
PB
Peter Bennett
Thu, Apr 26, 2018 10:30 PM
It's not clear to me what he is trying to accomplish.
If the battery switch is set to "both", both batteries will be
discharged equally, regardless of where the pump is physically connected.
If the switch is set to "1", "2", or "Off", and the pump is connected
directly to one battery, only that battery will be discharged.  The
other battery will be unaffected.
On 2018-04-26 11:58 AM, Rich Gano via Trawlers-and-Trawlering wrote:
So a friend has a 25 foot sailbote which has two batteries independently
connected to a 1/2/BOTH/Off type battery switch and he has to leave it in
the water with no shore power available for an extended time.  He wants to
leave his one bilge pump connected directly to one or both batteries
(probably with the battery switch in Both) but is concerned about the chance
of a failing battery dragging the other one down with it.
So a question for the electronics gurus.  Can he find a switching device
which will sit between the batteries and his pump which can shut down a
power leg to a low voltage battery?  I guess a Blueseas ACR could function
here, but I think he is looking for setting well below the voltage they are
set for.
Another option would be to toss another pump into the bilge connected to the
other battery and just turn the battery switch off, but then we are looking
at a plumbing issue for a second overboard discharge.
Rich Gano
FROLIC 2005 Mainship 30 Pilot II
Panama City, FL
http://lists.trawlering.com/mailman/listinfo/trawlers_lists.trawlering.com
To unsubscribe or modify your subscription options (get password, change email address, etc) go to: http://lists.trawlering.com/mailman/listinfo/trawlers_lists.trawlering.com
Trawlers & Trawlering and T&T are trademarks of Water World
Productions. Unauthorized use is prohibited.
Peter Bennett, VE7CEI    Vancouver, B.C., Canada
Vancouver Power Squadron: http://vpsboat.org
It's not clear to me what he is trying to accomplish. If the battery switch is set to "both", both batteries will be discharged equally, regardless of where the pump is physically connected. If the switch is set to "1", "2", or "Off", and the pump is connected directly to one battery, only that battery will be discharged. The other battery will be unaffected. On 2018-04-26 11:58 AM, Rich Gano via Trawlers-and-Trawlering wrote: > So a friend has a 25 foot sailbote which has two batteries independently > connected to a 1/2/BOTH/Off type battery switch and he has to leave it in > the water with no shore power available for an extended time. He wants to > leave his one bilge pump connected directly to one or both batteries > (probably with the battery switch in Both) but is concerned about the chance > of a failing battery dragging the other one down with it. > > So a question for the electronics gurus. Can he find a switching device > which will sit between the batteries and his pump which can shut down a > power leg to a low voltage battery? I guess a Blueseas ACR could function > here, but I think he is looking for setting well below the voltage they are > set for. > > Another option would be to toss another pump into the bilge connected to the > other battery and just turn the battery switch off, but then we are looking > at a plumbing issue for a second overboard discharge. > > > Rich Gano > FROLIC 2005 Mainship 30 Pilot II > Panama City, FL > > > > > _______________________________________________ > http://lists.trawlering.com/mailman/listinfo/trawlers_lists.trawlering.com > > To unsubscribe or modify your subscription options (get password, change email address, etc) go to: http://lists.trawlering.com/mailman/listinfo/trawlers_lists.trawlering.com > Trawlers & Trawlering and T&T are trademarks of Water World > Productions. Unauthorized use is prohibited. > -- Peter Bennett, VE7CEI Vancouver, B.C., Canada Vancouver Power Squadron: http://vpsboat.org
RG
Rich Gano
Fri, Apr 27, 2018 3:08 AM
If a battery is dying and the switch is on both, both batteries die; then
the bilge starts to fill.  You are correct about both discharging equally if
the switch is on BOTH, as long as they are at the same capacity AND state of
charge.  But if one is weak, it will soon be discharged and take the good
one with it.  What he does not want to happen is to have his boat sink with
a perfectly good, unaffected battery aboard which could have saved it.
Rich Gano
Panama City, FL
directly to
be
unaffected.
If a battery is dying and the switch is on both, both batteries die; then the bilge starts to fill. You are correct about both discharging equally if the switch is on BOTH, as long as they are at the same capacity AND state of charge. But if one is weak, it will soon be discharged and take the good one with it. What he does not want to happen is to have his boat sink with a perfectly good, unaffected battery aboard which could have saved it. Rich Gano FROLIC 2005 Mainship 30 Pilot II Panama City, FL > It's not clear to me what he is trying to accomplish. > > If the battery switch is set to "both", both batteries will be discharged > equally, regardless of where the pump is physically connected. > > If the switch is set to "1", "2", or "Off", and the pump is connected directly to > one battery, only that battery will be discharged. The other battery will be > unaffected.
