Cole, if you follow the wiring from the back of your rotary switch plate you
will come to a terminal strip. The purple wire from the off-run-fan switch
controls the a/c compressor. The red wire from the same switch thru the
terminal strip controls the water pump ( either directly on self contained
units or thru a pump relay box if remote compressors are cooled by a single
pump ). Removing the red signal wire from the switch side of the terminal
strip, and adding a jumper across the purple and red wire on the opposite
side of the terminal strip will power the pump only when the signal is sent
to the compressor. A single water pump with multiple remote compressors is
powered from this same signal but thru a pump relay box using a trigger for
each switch turning on a triac which in turn powers pump.
As a reference please search www.cruisair.com click products, click
DX REMOTE SYS WATER, and then select L2086 PFD. You will have a complete
installation and operators manual with wiring diagrams. Page 32 (top), 33,
& 34 will show switches, terminal strips, relay box, and color coding. This
manual covers both self contained and remote units. Make sure this
reference covers your application.
Frank,
LUV'N LIFE
47' Atlantic
Thank you very much Frank!
I was hoping someone would know the wire colors, that makes it easy.
I looked around the Cruiseair website and didn't find anything before,
but now that I know what to look for I'll go get that manual.
Thanks again,
Cole
Frank,
LUV'N LIFE
47' Atlantic
http://lists.samurai.com/mailman/listinfo/trawlers-and-trawlering
To unsubscribe or modify your subscription options (get password, change email address, etc) go to: http://lists.samurai.com/mailman/options/trawlers-and-trawlering
Trawlers & Trawlering and T&T are trademarks of Water World
Productions. Unauthorized use is prohibited.
