great-loop@lists.trawlering.com
Cruising America's Great Loop and other inland routes
Re: GL: name removal
L
Luther
Fri, Apr 17, 2009 2:46 PM
You are correct Jake, I have used Easy Off many times.
My recommendation are:
crack open a beer
spray on the Easy Off (to the painted surface)
drink the beer
hose off the Easy Off
sometimes a second beer required
Good Luck to All,
Luther Carrier
www.AbsoluteTankCleaning.com
St Petersburg, Fl
--- On Fri, 4/17/09, Jake2124@aol.com Jake2124@aol.com wrote:
Subject: GL: name removal
To: great-loop@lists.samurai.com
Date: Friday, April 17, 2009, 8:43 AM
Using Easy Off is NOT an urban
legend!!. I used plain old Easy Off Oven
cleaner to remove the painted on name from my boat. It
takes a few seconds,
not  even minutes, no harm at all to the gel coat. The
gelcoat will always
have a  slight "impression" of the removed name
because it ages different
under
the  paint than it does in the sun. Another removal
use is to remove
Penetrol if you  were unfortunate enough to have used
it on fiberglass as the
directions on the  can suggest. Nothing else I have
tried works at all, easy
off
does the  job.
Jake
**************Join ChristianMingle.com. FREE! Meet
Christian Singles in
your area. Start now!
://www.christianmingle.com/campaign.html?cat=adbuy&src=pl
atforma&adid=aolfooter&newurl=reg_path.html)
http://lists.samurai.com/mailman/listinfo/great-loop
To modify your Great-Loop subscription options (change
email address,
unsubscribe, etc.) go to:
You are correct Jake, I have used Easy Off many times. My recommendation are: crack open a beer spray on the Easy Off (to the painted surface) drink the beer hose off the Easy Off sometimes a second beer required Good Luck to All, Luther Carrier www.AbsoluteTankCleaning.com St Petersburg, Fl --- On Fri, 4/17/09, Jake2124@aol.com <Jake2124@aol.com> wrote: > From: Jake2124@aol.com <Jake2124@aol.com> > Subject: GL: name removal > To: great-loop@lists.samurai.com > Date: Friday, April 17, 2009, 8:43 AM > Using Easy Off is NOT an urban > legend!!. I used plain old Easy Off Oven > cleaner to remove the painted on name from my boat. It > takes a few seconds, > not even minutes, no harm at all to the gel coat. The > gelcoat will always > have a slight "impression" of the removed name > because it ages different > under > the paint than it does in the sun. Another removal > use is to remove > Penetrol if you were unfortunate enough to have used > it on fiberglass as the > directions on the can suggest. Nothing else I have > tried works at all, easy > off > does the job. > > Jake > **************Join ChristianMingle.com. FREE! Meet > Christian Singles in > your area. Start now! > (http://pr.atwola.com/promoclk/100126575x1221246370x1201421635/aol?redir=http > ://www.christianmingle.com/campaign.html?cat=adbuy&src=pl > atforma&adid=aolfooter&newurl=reg_path.html) > _______________________________________________ > http://lists.samurai.com/mailman/listinfo/great-loop > > To modify your Great-Loop subscription options (change > email address, > unsubscribe, etc.) go to: http://lists.samurai.com/mailman/options/great-loop
