trawlers@lists.trawlering.com
TRAWLERS & TRAWLERING LIST
Re: T&T: batteries for 43 gulfstar
A
AgajanianYS@aol.com
Mon, Apr 20, 2009 9:19 PM
When I bought my current boat, I chucked all the 8D's.....I replaced the
starting ones with 3 group 31's (AGM) and 6-6 volt AGM Lifelines for the
house/inverter...
Interesting side note....I had some loose cables on the starting batteries
and for quite a while I was only using ONE group 31 to start my Cat 3208's,
which it did with no complaint. Being redundant I use a 4th group 31 to
start  the Generator in case I need to cannibalize anything
Sam Agajanian
In a message dated 4/20/2009 1:55:31 P.M. Pacific Daylight Time,
rcrogers6@kennett.net writes:
It is  the Optima Red Top that is designed for starting. The Blue Top D34M
is
a  dual-purpose battery which can serve as a starting battery. Neither I
nor
Optima have any clue what the Yellow Tops are for! All retain a  charge
astonishingly well, but, owing to their small size are not suitable  (IMHO)
for a house bank which requires the batteries recommended by Arild  or their
expensive AGM 6V equivalents.
Ron  Rogers
http://lists.samurai.com/mailman/listinfo/trawlers-and-trawlering
To  unsubscribe or modify your subscription options (get password, change
email  address, etc) go to:
http://lists.samurai.com/mailman/options/trawlers-and-trawlering
Trawlers  & Trawlering and T&T are trademarks of Water World
Productions.  Unauthorized use is  prohibited.
When I bought my current boat, I chucked all the 8D's.....I replaced the starting ones with 3 group 31's (AGM) and 6-6 volt AGM Lifelines for the house/inverter... Interesting side note....I had some loose cables on the starting batteries and for quite a while I was only using ONE group 31 to start my Cat 3208's, which it did with no complaint. Being redundant I use a 4th group 31 to start the Generator in case I need to cannibalize anything Sam Agajanian In a message dated 4/20/2009 1:55:31 P.M. Pacific Daylight Time, rcrogers6@kennett.net writes: It is the Optima Red Top that is designed for starting. The Blue Top D34M is a dual-purpose battery which can serve as a starting battery. Neither I nor Optima have any clue what the Yellow Tops are for! All retain a charge astonishingly well, but, owing to their small size are not suitable (IMHO) for a house bank which requires the batteries recommended by Arild or their expensive AGM 6V equivalents. Ron Rogers _______________________________________________ http://lists.samurai.com/mailman/listinfo/trawlers-and-trawlering To unsubscribe or modify your subscription options (get password, change email address, etc) go to: http://lists.samurai.com/mailman/options/trawlers-and-trawlering Trawlers & Trawlering and T&T are trademarks of Water World Productions. Unauthorized use is prohibited.
