trawlers@lists.trawlering.com
TRAWLERS & TRAWLERING LIST
Shaft support and alignment
PB
Paul Brannon
Fri, Nov 4, 2005 3:13 AM
After all of the conversations regarding dripless shaft seals, cutless
bearings, and engine alignment I disconnected the shaft from my starboard
transmission to correct a problem with a seal leaking.  I noticed that when I
disconnected the flange that the shaft could drop a ways (maybe a half inch?).
There was lots of play in the stern tube.  Is this normal?  If so, how would
one check alignment with all of this play in the shaft?  I may be hauling out
for bottom paint and want to make any corrections while it is out.
Thank you,
Paul Brannon
1978 Gulfstar 44 MC
After all of the conversations regarding dripless shaft seals, cutless bearings, and engine alignment I disconnected the shaft from my starboard transmission to correct a problem with a seal leaking. I noticed that when I disconnected the flange that the shaft could drop a ways (maybe a half inch?). There was lots of play in the stern tube. Is this normal? If so, how would one check alignment with all of this play in the shaft? I may be hauling out for bottom paint and want to make any corrections while it is out. Thank you, Paul Brannon 1978 Gulfstar 44 MC
G
Grace
Fri, Nov 4, 2005 8:55 PM
Paul:
I block my shaft as near the flange as possible to maintain the alignment.
I also do the adjustments in the water, and not right after launch.  I
know my boat changes shape from the hard vs in water.
Regards,
Bob Davis
Thank you,
Paul Brannon
1978 Gulfstar 44 MC
http://lists.samurai.com/mailman/listinfo/trawlers-and-trawlering
To unsubscribe send email to
trawlers-and-trawlering-request@lists.samurai.com with the word
UNSUBSCRIBE and nothing else in the subject or body of the message.
Trawlers & Trawlering and T&T are trademarks of Water World
Productions. Unauthorized use is prohibited.
Grace, a Mainship 400
www.grace.crdavis.com
Paul: I block my shaft as near the flange as possible to maintain the alignment. I also do the adjustments in the water, and not right after launch. I know my boat changes shape from the hard vs in water. Regards, Bob Davis Paul Brannon wrote: >After all of the conversations regarding dripless shaft seals, cutless >bearings, and engine alignment I disconnected the shaft from my starboard >transmission to correct a problem with a seal leaking. I noticed that when I >disconnected the flange that the shaft could drop a ways (maybe a half inch?). >There was lots of play in the stern tube. Is this normal? If so, how would >one check alignment with all of this play in the shaft? I may be hauling out >for bottom paint and want to make any corrections while it is out. > >Thank you, > >Paul Brannon >1978 Gulfstar 44 MC >_______________________________________________ >http://lists.samurai.com/mailman/listinfo/trawlers-and-trawlering > >To unsubscribe send email to >trawlers-and-trawlering-request@lists.samurai.com with the word >UNSUBSCRIBE and nothing else in the subject or body of the message. > >Trawlers & Trawlering and T&T are trademarks of Water World >Productions. Unauthorized use is prohibited. > > > -- Grace, a Mainship 400 www.grace.crdavis.com
D
David&Joan
Sat, Nov 5, 2005 2:31 AM
Paul:
It all depends on the design and layout of your prop shaft support system.
Designs with a stern tube and a separate prop shaft strut with a cutless
bearing will support the prop shaft very well at two points and since two
points define a straight line, it will stay pretty true even when you unbolt
the coupling.
But if the only support is a stern tube cutless bearing, then the prop shaft
will sag a lot when you unbolt the coupling. In this case the only support
is a 4" or so long cutless bearing and it will sag quite a bit.
It sounds like you may have the latter design and you can wiggle the prop
shaft up and down to get a feel for its real center absent gravity. But a
half inch is probably close enough.
David
Paul: It all depends on the design and layout of your prop shaft support system. Designs with a stern tube and a separate prop shaft strut with a cutless bearing will support the prop shaft very well at two points and since two points define a straight line, it will stay pretty true even when you unbolt the coupling. But if the only support is a stern tube cutless bearing, then the prop shaft will sag a lot when you unbolt the coupling. In this case the only support is a 4" or so long cutless bearing and it will sag quite a bit. It sounds like you may have the latter design and you can wiggle the prop shaft up and down to get a feel for its real center absent gravity. But a half inch is probably close enough. David
