Hi All,
There is issue with GPSDO when PCIe connection is used on USRP X310.
On each start of any UHD based program GPSDO gets reset/power cycle.
Just after starting any program that streams/receives samples GPSDO
sends through UART following text:
**************************************************************Firmware:
rev 0.929b , built: Nov 6 2018 14:03:58
and UHD prints warning message:
[WARNING] [GPS] update_cache: Malformed GPSDO string: LC_XO, Firmware
Rev 0.929b
This issue makes internal GPSDO in X310 useless when PCIe connection is
used as it loses gps lock.
When using Ethernet there's no such issue.
I think it's because that for PCIe FPGA binary is reloaded on each UHD
based application start. During programing FPGA lines change state,
among them probably GPSDO_PWR_ENA line, what causes GPSDO power to go
down for a moment.
Is it possible to avoid reloading FPGA code when PCIe is used, without
changing UHD source?
Best Regards,
Piotr Krysik
Hi All,
Rev 0.929b
down for a moment.
Best Regards,
Piotr Krysik
