View all threadsBernd,
I'm adding the usrp-users mailing list back to this conversation as someone
may have more insight on this than I do.
I was able to reproduce your CMake output by removing the Entry Values for
*LIBUSB_INCLUDE_DIRS *and *LIBUSB_LIBRARIES. *If, in your CMake Entries,
these have a big NOTFOUND in their value field, you need to manually locate
them. Here's the Windows Guide
https://kb.ettus.com/Building_and_Installing_the_USRP_Open_Source_Toolchain_(UHD_and_GNU_Radio)_on_Windows#Configuring_the_Building
that lays this out.
The guide above also mentions installing the USB driver on Windows machines
to ensure you can interface with USB Devices. Give that a shot as well.
Sam Reiter
SDR Support Engineer
Ettus Research
On Mon, Dec 17, 2018 at 2:56 AM Bernd Witzel berndwitzel@hotmail.com
wrote:
Dear Sam Reiter,
I am now able to build and build install without errors (but a lot of
warnings) when I run Visual Studio as an Administrator. The
problem is that I see in the cmade output that some features are disabled.
How can I enable them, because I want to use The B210 for my project.
LibUHD - Python API
LIBERIO
USB
GPSD
B100
B200
E300
USRP1
DPDK
Man Pages
Wen I use uhd_find_devices I got :
C:\Users\Bernd 2\uhd-master\host\build\utils\Release>uhd_find_devices
[INFO] [UHD] Win32; Microsoft Visual C++ version 14.1; Boost_106800;
UHD_3.14.0.0-0-unknown
[INFO] [NIRIO] rpc_client stopping...
[INFO] [NIRIO] rpc_client stopped.
No UHD Devices Found[
ERROR] [
When I use uhd_find_device from the binary files I download directly I
got :
Device Address:
type: b200
serial: 30BC5F1
product: B210
So the device is in principle working but the program I compiled does not
work.
How to go on ?
Thanks for your help
Bernd Witzel
Von: Sam Reiter sam.reiter@ettus.com
Gesendet: Sonntag, 16. Dezember 2018 20:33
An: Marcus Müller
Cc: Bernd Witzel; usrp-users@lists.ettus.com
Betreff: Re: [USRP-users] UHD still errors after build installation
I agree with Marcus as I ran into this recently myself. Make sure you're
running Visual Studio as an Administrator before attempting to install.
Sam Reiter
Ettus Research
On Sun, Dec 16, 2018 at 2:13 PM Marcus Müller via USRP-users <
Hi Bernd,
I'm really not versed in the ways of Windows, but might it simply be
the case that the user you're currently running as simply has no
permissions to create files in C:\Program Files?
Best regards,
Marcus
On Sun, 2018-12-16 at 16:12 +0000, Bernd Witzel via USRP-users wrote:
To Sam Reiter (I did not get the answer via email, i just saw it in
the net.)
I did not install now the Doxygen, but I get following errors now
in cmake I got this,
when I compile it it is without error, when I install it with Build
install I got one error, see file I have attached to the
email
Configuring the python interpreter...
Python interpreter: C:/Python27/python.exe
Override with: -DPYTHON_EXECUTABLE=<path-to-python>
Python runtime interpreter: C:/Python27/python.exe
Override with: -DRUNTIME_PYTHON_EXECUTABLE=<path-to-python>
CMake Warning at cmake/Modules/UHDVersion.cmake:65 (message):
Could not detect git executable! Could not determine exact version of
UHD!
Call Stack (most recent call first):
cmake/Modules/UHDPackage.cmake:9 (include)
CMakeLists.txt:110 (include)
Using UHD Images Directory: C:\Program Files\UHD\share\uhd\images
Configuring Boost C++ Libraries...
Looking for optional Boost components...
Boost version: 1.68.0
Found the following Boost libraries:
Looking for required Boost components...
Boost include directories: C:/local/boost_1_68_0
Boost library directories: C:/local/boost_1_68_0/lib64-msvc-14.1
Boost libraries:
Python checking for Python version 2.7 or greater
Python checking for Python version 2.7 or greater - found
Python checking for Mako templates 0.4.2 or greater
Python checking for Mako templates 0.4.2 or greater - found
Python checking for requests 2.0 or greater
Python checking for requests 2.0 or greater - "import requests"
failed
Python checking for numpy 1.7 or greater
Python checking for numpy 1.7 or greater - found
Configuring LibUHD support...
Dependency Boost_FOUND = 1
Dependency HAVE_PYTHON_PLAT_MIN_VERSION = TRUE
Dependency HAVE_PYTHON_MODULE_MAKO = TRUE
Enabling LibUHD support.
Override with -DENABLE_LIBUHD=ON/OFF
Configuring LibUHD - C API support...
Dependency ENABLE_LIBUHD = ON
Enabling LibUHD - C API support.
Override with -DENABLE_C_API=ON/OFF
Configuring LibUHD - Python API support...
Dependency BOOST_PYTHON_FOUND =
Dependency HAVE_PYTHON_MODULE_NUMPY = TRUE
Dependency PythonLibs_FOUND = TRUE
Disabling LibUHD - Python API support.
Override with -DENABLE_PYTHON_API=ON/OFF
Configuring Examples support...
Enabling Examples support.
Override with -DENABLE_EXAMPLES=ON/OFF
Configuring Utils support...
Enabling Utils support.
Override with -DENABLE_UTILS=ON/OFF
Configuring Tests support...
Enabling Tests support.
Override with -DENABLE_TESTS=ON/OFF
Could NOT find PkgConfig (missing: PKG_CONFIG_EXECUTABLE)
Could NOT find LIBUSB (missing: LIBUSB_LIBRARIES LIBUSB_INCLUDE_DIRS)
Could NOT find LIBGPS (missing: LIBGPS_LIBRARY LIBGPS_INCLUDE_DIR)
Could NOT find LIBERIO (missing: LIBERIO_LIBRARY LIBERIO_INCLUDE_DIR)
Could NOT find dpdk (missing: DPDK_INCLUDE_DIR)
Configuring LIBERIO support...
Dependency LIBERIO_FOUND = FALSE
Disabling LIBERIO support.
Override with -DENABLE_LIBERIO=ON/OFF
Configuring USB support...
Dependency LIBUSB_FOUND = FALSE
Disabling USB support.
Override with -DENABLE_USB=ON/OFF
Configuring GPSD support...
Dependency ENABLE_GPSD =
Dependency LIBGPS_FOUND = FALSE
Disabling GPSD support.
Override with -DENABLE_GPSD=ON/OFF
Configuring B100 support...
Dependency ENABLE_USB = OFF
Disabling B100 support.
Override with -DENABLE_B100=ON/OFF
Configuring B200 support...
Disabling B200 support.
Override with -DENABLE_B200=ON/OFF
Configuring E300 support...
Disabling E300 support.
Override with -DENABLE_E300=ON/OFF
Configuring USRP1 support...
Disabling USRP1 support.
Override with -DENABLE_USRP1=ON/OFF
Configuring USRP2 support...
Enabling USRP2 support.
Override with -DENABLE_USRP2=ON/OFF
Configuring X300 support...
Enabling X300 support.
Override with -DENABLE_X300=ON/OFF
Configuring N230 support...
Enabling N230 support.
Override with -DENABLE_N230=ON/OFF
Configuring MPMD support...
Enabling MPMD support.
Override with -DENABLE_MPMD=ON/OFF
Configuring N300 support...
Dependency ENABLE_MPMD = ON
Enabling N300 support.
Override with -DENABLE_N300=ON/OFF
Configuring E320 support...
Enabling E320 support.
Override with -DENABLE_E320=ON/OFF
Configuring OctoClock support...
Enabling OctoClock support.
Override with -DENABLE_OCTOCLOCK=ON/OFF
Configuring DPDK support...
Dependency DPDK_FOUND = FALSE
Disabling DPDK support.
Override with -DENABLE_DPDK=ON/OFF
Could NOT find UDev (missing: UDEV_INCLUDE_DIR UDEV_LIBS)
Configuring priority scheduling...
Priority scheduling supported through windows SetThreadPriority.
Setting thread names is not supported.
Configuring high resolution timing...
High resolution timing supported through QueryPerformanceCounter.
Configuring module loading...
Module loading supported through LoadLibrary.
Processing NI-RIO FPGA LVBITX Bitstreams...
Using x300.lvbitx_base for codegen
Using x310.lvbitx_base for codegen
Configuring interface address discovery...
Interface address discovery supported through SIO_GET_INTERFACE_LIST.
Loading build info.
CMake Warning (dev) at lib/deps/rpclib/CMakeLists.txt:22 (elseif):
Policy CMP0054 is not set: Only interpret if() arguments as variables
or
keywords when unquoted. Run "cmake --help-policy CMP0054" for policy
details. Use the cmake_policy command to set the policy and suppress
this
warning.
Quoted variables like "MSVC" will no longer be dereferenced when the
policy
is set to NEW. Since the policy is not set the OLD behavior will be
used.
This warning is for project developers. Use -Wno-dev to suppress it.
Could NOT find Curses (missing: CURSES_LIBRARY CURSES_INCLUDE_PATH)
Adding X3x0 device test target
Adding N3XX device test target
CMake Warning (dev) in tests/devtest/CMakeLists.txt:
A logical block opening on the line
C:/Users/Bernd 2/uhd-master/host/tests/devtest/CMakeLists.txt:49 (if)
closes on the line
C:/Users/Bernd 2/uhd-master/host/tests/devtest/CMakeLists.txt:51
(endif)
with mis-matching arguments.
Adding E32x device test target
CMake Warning at utils/CMakeLists.txt:123 (message):
Python module `requests' not found -- uhd_images_downloader.py will
not
work without it.
CMake Warning at utils/CMakeLists.txt:124 (message):
You may be able to install this by running 'pip install requests'
Configuring Manual support...
Dependency DOXYGEN_FOUND = YES
Disabling Manual support.
Override with -DENABLE_MANUAL=ON/OFF
Configuring API/Doxygen support...
Disabling API/Doxygen support.
Override with -DENABLE_DOXYGEN=ON/OFF
Could NOT find GZip (missing: GZIP_EXECUTABLE)
Configuring Man Pages support...
Dependency GZIP_FOUND = FALSE
Dependency NOT_WIN32 =
Disabling Man Pages support.
Override with -DENABLE_MAN_PAGES=ON/OFF
Building version: 3.14.0.0-0-unknown
Using install prefix: C:/Program Files/UHD
Configuring done
Generating done
USRP-users mailing list
USRP-users@lists.ettus.com
