time-nuts@lists.febo.com
Re: [time-nuts] HP 5335A counter top cover
RR
Russ Ramirez
Sat, Jun 14, 2014 5:11 PM
Thanks for the info Dan.
Russ
On 6/13/2014 12:58 PM, Russ Ramirez wrote:
I just acquired one of these on the cheap but when I received the unit,
it
did not come with the top cover. I'm reaching out to see if any of you
would have one from a parts mule, or one you might think would fit. For
example, the top cover of a 8640 is the same design, but I'm not sure
it's
the exact same size.
It's not, the 5335 is a bit less deep than most of that series
instruments at around 12.5 inches as opposed to the 15.5 of the 8640B,
and I'm sorry, I don't have a spare.  I don't have any others with that
depth.
Dan
Thanks for the info Dan. Russ > On 6/13/2014 12:58 PM, Russ Ramirez wrote: > > I just acquired one of these on the cheap but when I received the unit, > it > > did not come with the top cover. I'm reaching out to see if any of you > > would have one from a parts mule, or one you might think would fit. For > > example, the top cover of a 8640 is the same design, but I'm not sure > it's > > the exact same size. > It's not, the 5335 is a bit less deep than most of that series > instruments at around 12.5 inches as opposed to the 15.5 of the 8640B, > and I'm sorry, I don't have a spare. I don't have any others with that > depth. > > Dan >
